Repairing Rotted Door Frames
Old 11-24-2009, 06:43 PM   #1
Five Star's Avatar
Rewards Points: 1,010
Been coming across this alot lately, and usually try to get people to change the door, but with times being hard i started repairing them!
i t turns out you can make a decent days pay or better and not really bust your back tearing out doors ive done about 10 of these already and each time it seams that it gets easier and easier!
Heres were the fein multimaster shines and you quickly forget how much the MM cost!
this is a 6 year old home!
Repairing rotted door frames-dsc01311.jpg   Repairing rotted door frames-dsc01312.jpg   Repairing rotted door frames-dsc01313.jpg
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
Old 11-24-2009, 06:46 PM   #2
Five Star's Avatar
Re: Repairing Rotted Door Frames
Some more
Repairing rotted door frames-dsc01314.jpg   Repairing rotted door frames-dsc01316.jpg   Repairing rotted door frames-dsc01319.jpg
Old 11-24-2009, 06:51 PM   #3
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
It looks like that door needed a carpet shim under it. Does that butt-ugly rug get stuck under that door?
loneframer is offline
Old 11-24-2009, 06:55 PM   #4
Five Star's Avatar
They took all the furniture but left the rug for the new owners!
That putty job lasted about 2 mnths from what i was told by the realtor!
painters think the caulk and putty is the answer to everything!
Old 11-24-2009, 06:58 PM   #5
KemoSabe
loneframer's Avatar
I would have used Azek. Looks good on the repair.
Old 11-24-2009, 07:02 PM   #6
Five Star's Avatar
I was considering that but the azek is to smooth and doent look natural as you cant really sand it to @ the joint!
Old 11-24-2009, 07:13 PM   #7
oldfrt's Avatar
Rewards Points: 94
You should tack your Business Card inside the door jamb,so you can get the call in 6 more years for either another repair, or replacement.
oldfrt is offline
Old 11-24-2009, 07:14 PM   #8
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,984
Just curious, not trying to start something here.....do you ever apply 2 part penetrating epoxy sealer to the areas that you removed the rot ? Rot is a living organism as you probably know. Looks like you got most of it out.
I found out about these products on these forums.
I use http://www.rotdoctor.com/products/product.html and http://www.abatron.com/cms/
I too do a lot of rot repair also. Just got a FMM about 6 months ago. Its true. How did I get by without it ?
We Fix Houses is offline
Old 11-24-2009, 07:24 PM   #9
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
Rewards Points: 256
I have been using No Rot door frames. The bottom 4 inches is fiberglass.
I measure the hinge and latch distances, give that info to my door company and in a few days have a new frame. The old door hinges fit without any adjustment and all is good. I will hold up better than a patch.
BACKWOODS is offline
Old 11-24-2009, 07:26 PM   #10
Five Star's Avatar
No i do not use the 2 part apoxy, and to tell you the truth 2 yrs ago i would of only replaced the door or walked away from this!
I just cut the rot out and use white gorilla glue at all connections! it is just a repair!
Old 11-24-2009, 07:26 PM   #11
KemoSabe
loneframer's Avatar
We've been using the units with composite bottoms on the jamb legs. It seems to put an end to that problem.
Old 11-24-2009, 07:27 PM   #12
Five Star's Avatar
yes built in 03 ! unbelievable!
Old 11-24-2009, 07:28 PM   #13
Five Star's Avatar
Thanks lone, There goes my job security
Old 11-24-2009, 07:40 PM   #14
KemoSabe
loneframer's Avatar
Should be plenty of those plywood paneled window bays for you to wrap with Azek, no?
Old 11-24-2009, 08:02 PM   #15
stp57's Avatar
Trade: carpenter/ handyman
Rewards Points: 1,000
Wow! 6 years & it had already been bondoed before. Go figure?
Steve
stp57 is offline
Old 11-24-2009, 08:04 PM   #16
oldfrt's Avatar
Rewards Points: 94
Just installed 13 Replacement windows in a Cape today for a "Flipper".Just tacked them in place till HO makes a decision.
75% of the sills were shot,as well as the bottom 6" of the most window trim.
Someone had already scabbed on new sill faces,leaving a gaping hole for water to enter.
Tomorrow I'll talk the painter into convincing HO to replace rather than patch as planned.
By the time I get done,they would have been better off replacing with Prime windows as first suggested.
It'll be interesting to see what the decision is.
I would think the labor involved in patching is more than replacement in this situation.
I'll probably figure the price that way,just so I don't have to deal with the aggravation of trying to get it so it doesn't look like a patch,and the next HO won't have a problem.
oldfrt is offline
Old 11-24-2009, 08:11 PM   #17
Five Star's Avatar
i know, but to tell you the truth i kinda like the repairing now, The Homeowners think they know whats best and for me its cake work! No helper needed, i,ll do this all week long
The Following User Says Thank You to Five Star For This Useful Post:
Tom Struble (11-24-2009)
Old 11-24-2009, 08:14 PM   #18
oldfrt's Avatar
Rewards Points: 94
or..........
At least till loneframer puts you out of business with his composite door bottoms!
oldfrt is offline
The Following User Says Thank You to oldfrt For This Useful Post:
Five Star (11-24-2009)
Old 11-24-2009, 08:18 PM   #19
stp57's Avatar
I buy a solid pvc jamb from the supplier & use 6" pieces off of it to do repairs. I do a 45 cut to splice it to the existing jamb, shim & seal off the seam.
I would rather use a composite jamb, but I haven't found full jambs made of composite material.
Steve
Some more
stp57 is offline
The Following User Says Thank You to stp57 For This Useful Post:
Old 11-24-2009, 08:27 PM   #20
Five Star's Avatar
Steve
Yes but thats thicker than a jamb, that piece is 2" x 2 1/2" i never seen around here pvc trim 2" thick
repairing trim coil wrapped garage Home Serve Windows, Siding and Doors 17 08-18-2009 07:10 AM
Repairing freeze damaged plumbing -whole house. matt832 Plumbing 5 08-09-2009 02:23 PM
Repairing Ni Cad batteries 7.2v checkin General Discussion 0 05-29-2009 02:27 AM
Repairing a broken business relationship StairJunkie Business 9 01-24-2009 12:57 AM
Rotted out window sills ronm1974 Carpentry 25 09-23-2008 09:29 PM
