Removing Crook
Old 01-11-2018, 07:00 PM   #1
TheConstruct's Avatar
Rewards Points: 22
Removing Crook
Will be installing some 1x4 VG fir window sills that I've pre fabbed, stained and varnished. A few have minor crooks in them. When I push them in on either end they fit nicely into the drywall return opening and against window but if I let go of one side it will pull away etc.
I'm hoping to use minimal, if any nails in the surface so looking for a way to reduce the amount of force required for them to sit nicely. The worst is only 1/4" but I have to push fairly hard to get both ends tight. I imagine removing some stock from the underside would help but worry I'm asking to damage one in the process.
I made up some elongated cove from the same material as an apron.
Picture just for reference. Doesn't show the crooked peice.
TheConstruct is online now
Old 01-11-2018, 07:27 PM   #2
avenge's Avatar
Rewards Points: 2,796
Re: Removing Crook
What are you saying that the window has a bow or the framing? If it's the window scribe it if it's the framing shim it. Your're a carpenter right?
avenge is online now
Old 01-11-2018, 07:41 PM   #3
Rewards Points: 22
Re: Removing Crook
I'm saying the sill has a crook in it. We can call it a bow if you want. There is no scribing involved here.
Old 01-11-2018, 07:44 PM   #4
Pro something
M.F Custom's Avatar
Trade: Construction
Rewards Points: 384
Re: Removing Crook
A sharp block plane may be what you need if I understand correctly...
M.F Custom is offline
Old 01-11-2018, 07:47 PM   #5
Rewards Points: 22
Re: Removing Crook
Sorry, maybe I'm not explaining this properly. Let's say the sill has a crown in it, the window is straight, the wall is straight. I don't want to remove any material off of the back edge of the sill as that will change the overhang on the front of it. It would also not remove the crook (crown) from the front of the sill. Maybe this isn't a question worth asking.
Old 01-11-2018, 07:55 PM   #6
Pro something
M.F Custom's Avatar
Trade: Construction
Rewards Points: 384
Re: Removing Crook
Shims, some construction adhesive and wedge sticks from the top.
Old 01-11-2018, 08:21 PM   #7
Rewards Points: 22
Re: Removing Crook
Thanks MF
Old 01-11-2018, 09:50 PM   #8
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Re: Removing Crook
crook versus bow, 2 different animals.
kirkdc is offline
Old 01-11-2018, 10:07 PM   #9
Rewards Points: 22
Re: Removing Crook
Exactly, and it's a crook that is what I'm asking about. So far nobody seems to understand the (correct) terminology I'm using.
Old 01-11-2018, 10:11 PM   #10
Rewards Points: 22
Re: Removing Crook
I realize that to have avoided this situation, jointing the material first is the best option. Now that I'm presented with trying to straighten a crook on a finished board without using mechanical fasteners, I thought maybe in the wealth of knowledge on this site existed a technique to help facilitate that. I'm a bit surprised by avenge's response as I think this is a valid question. Although MF didn't necessarily understand my question I appreciate the civil answer.
Old 01-11-2018, 10:25 PM   #11
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 190
Re: Removing Crook
For clarification
jlhaslip is offline
The Following 3 Users Say Thank You to jlhaslip For This Useful Post:
AustinDB (01-13-2018), B.D.R. (01-13-2018), Rio (01-13-2018)
Old 01-11-2018, 10:29 PM   #12
Rewards Points: 22
Re: Removing Crook
Thanks, should have thought to post something like that myself.
Originally Posted by jlhaslip View Post
For clarification
Old 01-11-2018, 10:35 PM   #13
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,061
Re: Removing Crook
Terminology aside, if it doesn't fit right, the only way to make it fit is by removing material in the appropriate area. Or bend it into place by applying brute force with fasteners.
Seems to me the answer is self-evident.
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
M.F Custom (01-12-2018), Rio (01-13-2018), sparehair (01-13-2018)
Old 01-11-2018, 10:41 PM   #14
Rewards Points: 22
Re: Removing Crook
It absolutely is. Thanks for solving that for me. Thought maybe someone would suggest routering out some of the bottom or some kerfs. Who knows maybe someone has run into this before or we could have fun trying to problem solve or bounce ideas around.
Old 01-11-2018, 10:47 PM   #15
Rewards Points: 22
Re: Removing Crook
I've been reading this site for years, reluctant to join because of threads like this devolving into this redundant stupidity.
I honestly was hoping to be a participating member of the site to get better at what I do and am passionate about.
I will obviously figure this out when I go to install, it really is a no brainer, I'm not here in a panic looking for someone to hold my hand, I was trying to have an interesting conversation about one of the many little obstacles we encounter on a daily basis. I have some time to think about this while the painter finishes so I thought I'd post. For those I've upset, I'm sorry, for those who learned a new word today, you're welcome.
Old 01-11-2018, 11:04 PM   #16
Capra aegagrus
Tinstaafl's Avatar
Re: Removing Crook
Sorry, what stupidity? You ask how to make a misshaped piece of wood fit, and don't want to hear the answer that it needs to be shaped right?
The only alternative I can think of is modifying the window/opening to match your piece of wood. Yep, that would be practical.
Rio (01-13-2018)
Old 01-11-2018, 11:13 PM   #17
Rewards Points: 22
Re: Removing Crook
I asked if anyone had any ideas on how to reduce the amount of force required to straighten it. I obviously understand I need to physically push it straight... I thought maybe someone with a better understanding of wood grain and/or woodworking than myself might suggest something interesting like maybe some relief cuts 2/3 depth in the bottom. Simply trying to reduce the amount of spring in it so I can use fewer or smaller fasteners. I didn't realize asking a question about manipulating wood on this site was such a bone head move.
Old 01-11-2018, 11:24 PM   #18
avenge's Avatar
Re: Removing Crook
Why? I was assuming the"crook" was somewhere other than the sills you made. Which begs the question why? Don't blame us for being confused you said you didn't want to take any off the underside but then you said you didn't want to take off any on the backside which by the way would involve scribing. But that wouldn't solve your problem of the effed up sill you made, It's not rocket science either force it and fasten it or make another sill without a "crook".
The Following 2 Users Say Thank You to avenge For This Useful Post:
Rio (01-13-2018), Stilla (01-13-2018)
Old 01-11-2018, 11:31 PM   #19
Mordekyle's Avatar
Rewards Points: 3,300
Re: Removing Crook
Wedge sticks to the opposite wall?
Mordekyle is offline
The Following 2 Users Say Thank You to Mordekyle For This Useful Post:
Philament (01-13-2018), Rio (01-13-2018)
Old 01-11-2018, 11:31 PM   #20
avenge's Avatar
Re: Removing Crook
[QUOTE=TheConstruct;6676186]redundant stupidity.[QUOTE]
That's what gets my post count up on this site.
Removing retaining wall? rotarex Landscaping 10 05-30-2013 08:50 PM
Removing wet insulation Tom Richards Insulation 8 12-16-2012 07:44 PM
Ornamental Plaster (Removing Paint) Jason Whipple Painting & Finish Work 4 09-23-2012 07:55 PM
