Plywood Cart
Old 03-08-2009, 09:43 AM   #1
KMac's Avatar
Trade: Finish Carpenter
Plywood Cart
Have any of you guys built a cart to move plywood around? I'm looking for some design tips and ideas. I need something to move sheet goods from my truck to my shop area - about 100 feet from where I back my truck in to my shop. I don't want it to take up too much space. I'm sick of carrying it. Any ideas?
KMac is offline
Old 03-08-2009, 10:01 AM   #2
JonM's Avatar
Re: Plywood Cart
Get yourself a drywall cart...
JonM is offline
Old 03-08-2009, 10:05 AM   #3
KemoSabe
loneframer's Avatar
Re: Plywood Cart
Harbor freight has a 2'x4' steel mesh wagon with 10" pnuematic tires and a 1000# capacity for under $100. It would probably do the job or at least give you some design ideas.
loneframer is offline
Old 03-08-2009, 10:18 AM   #4
TimelessQuality's Avatar
Trade: GC/Remodeling
Re: Plywood Cart
I hear HD or Lowes will give you a cart if you have an enclosed trailer (ramp door helps too)
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is offline
Old 03-08-2009, 10:43 AM   #5
LRG WoodCrafting
Leo G's Avatar
Re: Plywood Cart
I made an "A" frame cart, holds about 20 sheets. Yours would surely need better wheels than mine. Probably (4pcs) 1000lb rated pneumatic tires.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 03-08-2009, 10:45 AM   #6
KMac's Avatar
Re: Plywood Cart
Thats no fun - I want to make something! That is along the lines of what I want though.
That's a nice cheap cart - I want the sheets to sit on edge but I may grab one of those carts for loading high rise jobs.
I didn't realize those were free.
KMac is offline
Old 03-08-2009, 10:45 AM   #7
tcleve4911's Avatar
Trade: Remodeling contractor
Re: Plywood Cart
Show him a pic, Leo. Don't be shy.............
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 03-08-2009, 10:46 AM   #8
LRG WoodCrafting
Leo G's Avatar
Re: Plywood Cart
I wish I had one. And if I wanted to take one I would have to remove at least 10 sheets of 3/4", not happening soon.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-08-2009, 10:49 AM   #9
KMac's Avatar
Re: Plywood Cart
I would like half an "A" frame cart - may i should just buy a drywall cart like JonM suggested.
KMac is offline
Old 03-08-2009, 10:54 AM   #10
LRG WoodCrafting
Leo G's Avatar
Re: Plywood Cart
An "A" frame is a balanced cart. Mine is designed to fit through a 34" opening (36" door). It is nice, bring it over to the door, off load the truck and put it aside. When you need to use sheets, pull it through the door and put it behind the tablesaw. Pull off the sheets one by one and you never have to drag them more than about 10'. Makes it nice when you are building a kitchen with 15-20 sheets of 3/4" plywood. Like I said about my wheels. Get good ones, mine suck. HD specials. Need something from Graingers or WoodCraft. Something with ball bearings. Are you getting the hint that you shouldn't cheap out on the wheels?
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-08-2009, 11:06 AM   #11
Steve
OCRS's Avatar
Re: Plywood Cart
An "A" frame is a balanced cart. Mine is designed to fit through a 34" opening (36" door). It is nice, bring it over to the door, off load the truck and put it aside. When you need to e sheets, pull it through the door and put it behind the tablesaw. Pull off the sheets one by one and you never have to drag them more than about 10'. Makes it nice when you are building a kitchen with 15-10 sheets of 3/4" plywood. Like I said about my wheels. Get good ones, mine suck. HD specials. Need something from Graingers or WoodCraft. Something with ball bearings. Are you getting the hint that you shouldn't cheap out on the wheels?
I would second Leo on this. I once watched from afar a new guy transporting drywall across the site with a drywall cart, the wheels got caught up on a small ledge. He tried to stop the tipping, broke his leg.
OCRS is offline
Old 03-08-2009, 11:07 AM   #12
Re: Plywood Cart
Unless you want to spend the next
five years waiting to "get around to"
changing them for the ones you
should have bought
to begin with.
neolitic is offline
Old 03-08-2009, 11:07 AM   #13
tcleve4911's Avatar
Re: Plywood Cart
Check out this article about a plywood tilt cart that acted as storage & a table saw feed
http://books.google.com/books?id=OdZ...esult#PPA36,M1
Back in Maine
Dubbin' Around
The Following User Says Thank You to tcleve4911 For This Useful Post:
Snobnd (03-09-2009)
Old 03-08-2009, 11:12 AM   #14
LRG WoodCrafting
Leo G's Avatar
Re: Plywood Cart
should have bought
to begin with.
I had bought the same wheels (or so I thought) from HD a few years ago. They worked great. All these wheels did was look the same, nothing else.
I built the cart when I was starting up the shop, had a mortgage, shop payments new equipment. In other words cash strapped. I did the bet I could with the stuff I had. Now I can afford better.
Thanks for the encouragement.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-08-2009, 11:16 AM   #15
LRG WoodCrafting
Leo G's Avatar
Re: Plywood Cart
I looked at a bunch of those drywall carts. If all you are planning on using them for is going from point A to point B then they would be fine. A little pricey on some of the better ones. But if you are going to use it for storage as well ans transport then I find that they are to short. You would end up having your plywood turn into potato chips because of no support on the ends. A storage cart should be at least 6' long. I made mine 7'. Short enough so that when you are putting plywood on it you have a place for your had to go, but long enough for full support so the plywood stays nice and straight during its storage period.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-08-2009, 11:16 AM   #16
LRG WoodCrafting
Leo G's Avatar
Re: Plywood Cart
Looks like it can do one or the other.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-08-2009, 11:18 AM   #17
tcleve4911's Avatar
Re: Plywood Cart
Lookas like it can do one or the other.
not both?
Back in Maine
Dubbin' Around
Old 03-08-2009, 11:20 AM   #18
LRG WoodCrafting
Leo G's Avatar
Re: Plywood Cart
Not at the same time.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-08-2009, 11:24 AM   #19
LRG WoodCrafting
Leo G's Avatar
Re: Plywood Cart
I like the idea of the clamping cart. I don't think I'd go as far as making the top with all the notches for the clamps. But like the idea of the storage and clamping surface on wheels. Not sure if my shop has the room for it though.
http://books.google.com/books?id=OdZ...-1&output=html
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-08-2009, 11:26 AM   #20
tcleve4911's Avatar
Re: Plywood Cart
okay.....why not? Several stacked sheets....I do that all the time with a stack on sawhorses staged behind the saw. Push one off at a time.
no?
Back in Maine
Dubbin' Around
Working from a Tool Cart basswood Finish Carpentry 41 03-24-2010 04:38 AM
Plywood direction effect on floor bounce over I-Joist personalt Framing 25 12-31-2008 05:28 PM
putting tile on plywood. AARC Drywall Flooring 8 10-21-2008 04:05 PM
Plywood w/one hour fire rating fireguy Commercial Construction 8 09-18-2008 06:44 PM
Footing Forms for Residential use Clamps/brace for plywood forms plazaman Excavation & Site Work 5 08-21-2008 10:21 PM
