Plate Jointer
Old 03-19-2009, 04:34 PM   #1
General Contractor
greg24k's Avatar
Plate Jointer
Did anyone worked with Porter Cable plate jointer model #557? If yes, what you think about this model?
Thanks.
greg24k is online now
Old 03-19-2009, 06:38 PM   #2
wood is good
Sooner Pesek's Avatar
Trade: trim carpenter
Re: Plate Jointer
Greg,
I have used the #557 for about 5 yrs. now. The fence adjusts from 0-135 degrees, very solid when locked in and runs very smoothly. It also has the option of installing the smaller diameter blade to use face frame bisquits (although I haven't used those since I got the Krieg jig system).
All in all , a well designed machine IMO.
Roger
"SKILLED Carpenters aren't CHEAP , CHEAP Carpenters aren't SKILLED " --- saw this on a t-shirt a while back ---
Sooner Pesek is offline
Old 03-19-2009, 07:09 PM   #3
Sean
SLSTech's Avatar
Re: Plate Jointer
I agree with Roger - of course he threw me for a loop on the 135 degree part. Made me go look at mine & sure enough there it is & I have had it for over 5 years. Thanks Roger
90 degrees is the first lock - if you slide it up you can lock on at 135
Now I don't use mine everyday, more like once a month but I have yet to have an issue. I can see this one getting handed down to one of my kids.
One trick I saw Norm use on New Yankee Workshop which I thought was cool - was routing out a groove on the cabinets, putting the biscuits where needed on the face frames & attaching which helps with any mismarks / lining up problems us mere mortals run into
SLSTech is offline
Old 03-19-2009, 07:17 PM   #4
Carpenter/Finisher
john5mt's Avatar
Re: Plate Jointer
i have it and have no complaints...though ive never used a different one so i have nothing to compare it to
Just could bring myself to buy a lamello 800 bucks is a bit much for a plate joiner
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Old 03-19-2009, 07:39 PM   #5
General Contractor
greg24k's Avatar
Re: Plate Jointer
Thanks for the feedback I have the Dewalt one and the last few smaller jobs I did, I could have used the FF size biscuits. I will go tomorrow and get the Porter Cable one.
Old 03-19-2009, 07:40 PM   #6
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Re: Plate Jointer
There are several different versions of the 557. The initial model (type1) had issues with enlarged slots, and PC tweaked it and offered the 557 Type 2. All was good until people started complaining about minor alignment issues.... So now PC came out with the type 3. I have this one, it works fine. I don't use biscuits that often anymore, but when I do, I grab my older than dirt Dewalt joiner. It's lighter, smaller, and cuts a perfect slot every time.
If you're looking to buy a new PC 557, make sure it says type 3 on the label.
- Alex
Long Island Remodeling Contractor
Splinter is offline
The Following User Says Thank You to Splinter For This Useful Post:
greg24k (03-19-2009)
Old 03-19-2009, 07:56 PM   #7
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Re: Plate Jointer
I have one, and love it. Although I will have to admit that the offset double track on the guide kind of threw me for a few minutes. (I'm sometimes a little slow on the uptake... )
It's a very solid and smooth machine.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
The Following User Says Thank You to Willie T For This Useful Post:
Old 03-19-2009, 07:56 PM   #8
wood is good
Re: Plate Jointer
Thanks a lot Splinter,
I had to get off my a$$ and look on the label--Mine is a type I.
GREAT!!! Now the next time I use it, subcontiously, I will find something wrong with it, throw it across the room, through the drywall, break a gas line, house blows up.
OK, just kidding-I don't throw my tools.
I haven't had any problems with mine, but that is interesting info.
Thanks,
Roger
Old 03-19-2009, 08:31 PM   #9
JLTrim's Avatar
Trade: Finish Carpentry
Re: Plate Jointer
I have one, bought it recently to replace my sh!tty old Ryobi that got stolen. Only used it on one job so far, but it's dead accurate, has no slop, plenty of power, worth every penny. I'm kind of glad the old one got taken, been looking for an excuse to replace that POS.
JLTrim is offline
Old 03-19-2009, 08:35 PM   #10
Sean
SLSTech's Avatar
Re: Plate Jointer
Type 1 No wonder why everything lines up so well & I just thought I was that good.
Still a good joiner
SLSTech is offline
Old 03-19-2009, 09:35 PM   #11
The Remodeler
Splinter's Avatar
Re: Plate Jointer
For anyone with a type 2- I believe PC was offering some kind of "fix" for it... Contact them or a tool repair shop.
- Alex
Splinter is offline
Old 03-19-2009, 09:48 PM   #12
General Contractor
Willie T's Avatar
Re: Plate Jointer
Still a good joiner
Not all of them have the wide slot problem. I have an eight or ten year old one (Type I, I assume), and sometimes I have to tap the biscuits into the slot a little. It's always been pretty tight.
Willie T is offline
Hey Gus, Would You Buy this Jointer? basswood Finish Carpentry 13 02-18-2009 11:24 AM
Help on finding a wall plate KentWhitten Electrical 25 12-23-2008 06:30 PM
Flat plate heat exchanger genecarp Plumbing 2 11-24-2008 10:09 PM
Door Catch/Strike plate issue icfbunt Finish Carpentry 15 04-15-2008 12:34 AM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 06:52 AM
