Trade: carpenter
Piano Hinges
I am wondering what you guys think. I can install piano type hinges two ways. On the 'flat' so you see the whole hinge, or into the 3/4 material, so you just see the spine. The first way is typical, the second way involves screwing into the raw edge of a piece of 3/4 birch ply. Is that asking for trouble, even if glued?
Trade: carpenter/ handyman
Re: Piano Hinges
I recently built a 7ft armoire with 2 full length doors (I can't send the photos because this site has a 200 KB limit & my photos are 1.18 MB. I used 6 ft piano hinges in 3/4 birch with no problem. I pre-drilled all of my holes & used glue in some of the screw holes that were suspect. The doors are quite heavy but piano hinges take so many screws that I don't worry about them holding up at all.
Steve |
Trade: carpenter
Re: Piano Hinges
Into the plywood cut? Did it hold?
Re: Piano Hinges
I fasten them into the edge of 3/4" birch all the time, and never have any problems. If it is something that I think might take more "abuse" than "use", I put a longer screw in every third or fourth hole. There are also piano hinges that wrap, so if seeing a flange on the back side of the open door is not offensive, they add plenty strength.
Trade: carpenter
Re: Piano Hinges
Thanks Trouble.
#6 | |
Handle It!
Re: Piano HingesQuote:
Upload your photos here. We want to see! http://photobucket.com/?link=topmenu
Re: Piano Hinges
I uploaded my photos on PhotoBucket. What next?
Steve |
Re: Piano Hinges
insert them into a new thread or into this one. copy the link from under the picture in photobuckets album, then in this box for a new reply there is an image of a picture at the top of the box, if you click on it it will display a window asking for the link, that you just previously copied from photobucket, just past it in.
Handle It!
Re: Piano Hinges
Go to the Photobucket page and copy the link address in the address window and post it here or you can copy the "direct link" next to each picture and paste it in your next post. Or just simply copy and paste the "img link".
Examples: (my album is "private so it will ask you for a password. Make yours public) http://s212.photobucket.com/albums/cc97/MalcoNewYork/ (entire album) http://i212.photobucket.com/albums/c...IMG_0365-1.jpg (direct link) ![]() The picture you see was generated by copying "img code" and pasting it here. This is the simplest way to do it!
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 03-12-2008 at 12:05 AM. |
Re: Piano Hinges
hahaha
Re: Piano HingesSteve ![]() ![]()
Re: Piano Hinges
Thanks all for the tips on posting photos.
Steve |
Re: Piano Hinges
Examples of Piano-Hinge use:
1.) (unpainted door, missing one knob): ![]() 2.) (unfinished, unpainted area, we later installed the baseboard sections, over the lower area of the door too):
- Build Well - |
Handle It!
Re: Piano Hinges
It took me awhile to figure it out some time ago. It is my duty to help others with what I DO know!!
Any time Steve! Ask away.
| Mess o' hinges... | reveivl | Carpentry Picture Post | 7 | 03-02-2007 06:58 PM |
| commercial door hinges | rservices | Windows, Siding and Doors | 4 | 12-02-2006 12:46 PM |
| Weird question about euro hinges | karma_carpentry | Finish Carpentry | 12 | 08-12-2006 05:13 PM |
| cabinet hinges | neolitic | Finish Carpentry | 4 | 04-21-2006 03:04 PM |
| Cheaper source for good brass knife hinges ? | karma_carpentry | Finish Carpentry | 3 | 12-17-2005 10:15 AM |
