Panel And Picture Frame.
Old 10-17-2008, 02:17 PM   #1
One man show.
kevbo's Avatar
Trade: Finish Carpenter
Panel and picture frame.
kevbo is offline
Old 10-17-2008, 02:29 PM   #2
Meetre's Avatar
Re: Panel And Picture Frame.
what kind of paneling are you doing? maybe a picture or drawing to show us what the final product should look like. there are many different styles that have different approches to getting the look you want. more info please.
Meetre is offline
Old 10-17-2008, 02:40 PM   #3
One man show.
kevbo's Avatar
kevbo is offline
Old 10-17-2008, 02:51 PM   #4
Meetre's Avatar
if it's paint grade mdf, i'ld butt joint it and and bondo the seam, sand it flat. just don't get too agressive with the sanding and it'll look perfect. just watch for bumps in the wall that could make the seam not line up, might need to shim the seam to lay perfectly flat with the rest of the wall.
Meetre is offline
Old 10-17-2008, 03:09 PM   #5
One man show.
kevbo's Avatar
kevbo is offline
Old 10-17-2008, 05:18 PM   #6
Meetre's Avatar
no problem, man. Oh, one other thing....you will want to use a factory edge of the mdf unless it is chipped up, it'll be square and make the seam line up better. good luck
Meetre is offline
Old 10-17-2008, 07:49 PM   #7
VitoFromNJ's Avatar
Trade: carpenter
Imagine it like a cabinet door...
VitoFromNJ is offline
Old 10-17-2008, 09:18 PM   #8
Tailors sew seams.
Carpenters make joints.
It's called joinery.
neolitic is offline
Old 10-17-2008, 09:32 PM   #9
send_it_all's Avatar
I would integrate rails and stiles on 4' or 8' centers to hide joints if at all possible. Otherwise I would probably use biscuit joinery. I don't think I would attempt a scarf joint on a big panel. Not the right application IMO.
send_it_all is offline
Old 10-17-2008, 11:03 PM   #10
LRG WoodCrafting
Leo G's Avatar
Cut your full sheets to appropriate sizes so the styles fall on the joint. This will hide the joint and you won't have to deal with it. You will have to do a little thinking to get your sizes right instead of just laying out 49" or 97" lengths.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 10-17-2008, 11:27 PM   #11
One man show.
kevbo's Avatar
kevbo is offline
Old 10-18-2008, 12:15 PM   #12
Meetre's Avatar
I said seam, cause some days my brain won't spit out the right word for me. If you wouldn't use a scarf joint how would you do it? I agree with covering the joint with the picture frame, minimizes the chance of seeing it.
Meetre is offline
Old 10-18-2008, 12:47 PM   #13
Tom R's Avatar
I think he's talking about picture-frames only, - - no stiles. But yeah, - - I would still figure it so the joints fell under one side of the frame(s).
Tom R is offline
Old 10-18-2008, 01:31 PM   #14
KMac's Avatar
What about routing a half lap joint? - lots of surface area to glue that way. Never had to join two sheets of MDF without being able to cover it with a stile.
KMac is offline
Old 10-18-2008, 03:29 PM   #15
You might also try to accentuate the joint by routing a decorative detail into it such as a bead on each piece like beadboard would have.
If it's going to be painted, a but joint with biscuits will probably be smooth enough to disappear after painting.
Old 10-18-2008, 05:48 PM   #16
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
I like to use a spline cutter in a hand held router when we have to join sheet goods with a visible joint.
If you prepare the edges of the sheet to a nice straight and square edge, the joint is strong and "seemless". We join veneer ply this way alot.
In the field preparing those edges can be difficult. I would clamp or screw a straight rip of ply to the underside of the mdf and use a flush cutter in another router to nibble off an 1/8" or so.
Gus Dering is online now
Old 10-22-2008, 02:17 PM   #17
One man show.
kevbo's Avatar
kevbo is offline
Old 10-22-2008, 08:18 PM   #18
VitoFromNJ's Avatar
Trade: carpenter
Lay it out so that the flat panel lies in a corner. In other words, wrap, the flat around the corner
Old 10-22-2008, 08:36 PM   #19
Gus Dering's Avatar
Maybe you could make up outside corner "posts" that fit under the cap with a small reveal and run to the floor. You could rabbet them to lip over the paneling , So you don't have to be real accurate with all the panel ends.
Then but the base to the corner posts similar to a plinth block.
Dress them up however you feel fit with a router.
Of course you need ample room under the wainscot cap, seemslike a maybe.
Badda bing badda boom, production
Just thinkin out loud, so to speak
