Trade: trim carpenter
Old Skool Adjustable Shelving
Ever run into old cabinets with adjustable shelving supports let-in like this. Good practice with a dovetail saw.
They sure had skill with hand tools back in the day. |
Trade: siding
Re: Old Skool Adjustable Shelving
wonder if back in the day you could buy that by the lf?
Trade: Finish Carpenter
Man that must have been a PITA!
Quite possibly. In clear pine, those guys could probably make short work of it.
For our generation of power tool users, seems insane, but have you seen this video: http://video.google.com/videosearch?...&hl=en&tab=wv# I'd like to try that. |
#5 | |
Re: Old Skool Adjustable ShelvingQuote:
Those are called sawtooth shelf brackets.
And there was a time you could buy them in 8' lengths, not sure if anyone manufactures them now. |
I just saw those for the first time a couple of weeks ago in an old piece of furniture. Pretty good idea. You could probably cut up a whole mess of them in a rack.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas |
Professional Remodeler
Seen them occasionally, not so much anymore. Around here (Michigan) I see mostly the radius ones. They have the half-circle cut out every 4" to 6" or so instead of the sawtooth pattern along each support, and the shelf support is just a 1-by with a radius at the ends, like a Popsicle stick. It slides into the matching radius of the support and the shelf sits on them.
-Mike- Falcon Contracting Residential - Commercial
Maker of fine kindling
Wow thats funny, I just did a kitchen that the owner insisted on having a version of those in the uppers that had glass doors.
I cut the saw tooth pattern with the cnc in maple ply with a mdf core. So the inside corners have a 1/2" radius unlike the old timer's original. But the HO loved them and the check cleared. All done in the power tool age We have to go back soon and rehang the doors after paint and put on the pulls. I'll snap some shots and post them then. |
#10 | |
#11 | |
That will be good to see, Bass |
I had to go by that kitchen this morning. The painter is still wworking there but here is a preview to the finished look.
Trade: Consultant
Maybe I'm seeing something wrong, but aren't those upside down? I'd think you'd want the flat side facing down (like in the original photo), so there was some bearing surface other than the sloped face.
Trade: Carpentry & Remodeling
I bet they were gang cut on a radial saw with a stack dado,
someone probably already said that though
Do what you would do, as if i won't Do anything after you Did It! |
#15 | |
![]() My feeling was that the angled side down would snug them up a little with the weight of the shelf. I might have blown it but like I said before, HO is happy and the money has changed hands. |
Trade: Remodeling contractor
Sooooooooo
Are they upside down? ![]() Just curious.......................
Back in Maine Dubbin' Around Doin' good stuff ...... |
Let's just say, they are the opposite
of every set I've ever seen, and that's more than a few. Not sure why they wouldn't work though.
#18 |
Just seems like if they didn't "pinch" at the exact same spot, they could lock in out of level.
#19 |
Gus will post back and let us know.
Right? We all know he just did it, "In the name of science."
#20 | |
![]() They seem to work fine though. There is not enough room to get them out of level. The sticks are fairly accurate. When I chose which way to put them I played with it a little and the "upside down" way seemed to keep the stick registered in there a little better so I went with it. I'll be sure to keep you boys away from this house. I wouldn't trust you with Mrs HO anyway. Loooker ![]() They have other ones in the house with the drill press method too. I happen to like my upside down version myself. Ha! |
| adjustable shelves for trailer? | platinumLLC | Vehicles | 1 | 02-15-2009 12:57 AM |
| Closet Maid Shelving | Eric S | General Discussion | 23 | 09-05-2007 10:28 PM |
| I'm new. HI. Shelving Question | Eric S | Introductions | 9 | 08-24-2006 10:23 AM |
| contractor van steel shelving | jane99 | Contractor Swap | 0 | 03-30-2006 03:29 PM |
| contractor van steel shelving | jane99 | Vehicles | 0 | 03-30-2006 03:25 PM |
