Not My Crowning Screw Up?
Old 11-10-2017, 10:41 AM   #21
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 9,499
Re: Not My Crowning Screw Up?
..or maybe one of them wasn't cut upside down (like that left side)
MarkJames is offline
Old 11-10-2017, 10:59 AM   #22
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 186
One of two things happened. The cut was not made at 45 or the crown slipped and when he cut it it wasn't nested properly at the spring angle.
It could be both. I usually make the crown I'm installing and it has wide flats to balance the crown on the chopsaw. Lumber yard crown is usually pretty thin and scant on the flats. It's best to have a stop on the chopsaw to align the spring angle properly and consistently.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Tom Struble (11-12-2017)
Old 11-10-2017, 11:06 AM   #23
MarkJames's Avatar
Yeah, but that looks familiar. Like when I forget to cut something upside down.
Old 11-10-2017, 11:33 AM   #24
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 186
The bevels wouldn't match like that if one pc was cut right side up.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 11-10-2017, 02:52 PM   #25
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 3,692
Little off topic, but the house I just worked on the builder has a coping machine, kind of like a key making machine, thought it was kind of neat.
Randy Bush is offline
Old 11-10-2017, 03:01 PM   #26
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 186
Copemaster.
I've always wanted one but for the amount of crown work I do it's probably not worth it. But if I ever come into so disposable cash, it's on the list.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 11-10-2017, 03:28 PM   #27
KAP's Avatar
Trade: Custom
Rewards Points: 22,278
Originally Posted by Leo G View Post
Copemaster.
If you don't have or want to expend the coin, a table saw and a steady hand does the same thing and doesn't require loading and unloading... starts doing it on MDF a while ago because coping MDF sucks...
MDF profiles take about 10-15 seconds, wood takes 30-60 seconds depending on the profile if you don't want to cope... some also use a grinder, but the table saw is more stable for more pronounced profiles... but there are pro's and con's to everything...
KAP is offline
Old 11-10-2017, 09:25 PM   #28
gbruzze1's Avatar
Rewards Points: 2,606
A table saw copes using same technique as a Copemaster, but they absolutely donít do the same thing.
gbruzze1 is offline
The Following User Says Thank You to gbruzze1 For This Useful Post:
slowsol (11-10-2017)
Old 11-10-2017, 09:49 PM   #29
Punching above his weight
Easy Gibson's Avatar
Trade: What do you need?
Rewards Points: 3,582
This second page has a lot of CSI work for one crappy joint.
My favorite job like this I did was I showed up to bat cleanup for a HO who had installed everything except the last foot going into the corner, on every corner. "Corners are the hard part." I waited for him to leave, then went out and bought full runs. I can't remember what I did with what I took down. Hopefully brought it to a slightly smaller house and used it there.
Easy Gibson is offline
The Following User Says Thank You to Easy Gibson For This Useful Post:
SmallTownGuy (11-11-2017)
Old 11-10-2017, 09:57 PM   #30
KAP's Avatar
Trade: Custom
Originally Posted by gbruzze1 View Post
A table saw copes using same technique as a Copemaster, but they absolutely don’t do the same thing.
Maybe I should have been more clearer and said accomplishes the same thing sans the coin and loading/unloading... obviously templating using a blade versus free-hand using a blade are not the same thing... didn't think I needed to make the distinction...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
Wile E Coyote (11-20-2017)
Old 11-10-2017, 09:59 PM   #31
MarkJames's Avatar
That reminds me of a glass tile backsplash mosaic job where the homeowner had installed "most of it, but wanted help with just all the edges."
Old 11-11-2017, 12:47 AM   #32
Mordekyle's Avatar
Rewards Points: 2,458
Here comes Tipi in 3...,2...,1.....
Mordekyle is offline
The Following 2 Users Say Thank You to Mordekyle For This Useful Post:
SmallTownGuy (11-11-2017), Unger.const (11-13-2017)
Old 11-11-2017, 01:37 AM   #33
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,348
Could also cut another 1/8th of the piece without the nails in it, then shim out the back of it to make the corner better...
or redo with cope saw and a new board.
cedarboarder is offline
Old 11-11-2017, 01:42 AM   #34
Trade: Workaholic
that is amazing. whats it cost
Old 11-11-2017, 04:22 AM   #35
MarkJames's Avatar
Originally Posted by cedarboarder View Post
That is amazing. Whats it cost
$2495
Old 11-11-2017, 06:30 AM   #36
B.Johnson's Avatar
Trade: Builder
Rewards Points: 58
I don't think that they make them any more. I picked up a used one for $600.
Home Designer Series Software
B.Johnson is offline
Old 11-11-2017, 09:03 AM   #37
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 186
They still make them. Someone started it up again.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 11-11-2017, 11:36 AM   #38
Stilla's Avatar
Trade: Finish carpentry
Rewards Points: 422
Originally Posted by VinylHanger View Post
I'm trying to put the final piece of crown on after someone else couldn't finish. I think he just went with 45, but ended up at like a 55 degree angle somehow. Anyway, am I correct in saying his cut is too short on the long point?
His is on the left, my scrap on the right. Great part is the other side is exactly opposite.
I don't do much is any crown, but I don't think this is my screw up?
The spring angle of the crown is installed wrong on both parts. Make the tops touch and fix the cut, so the bottom closes.
Stilla is offline
Old 11-11-2017, 11:40 AM   #39
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 186
And then twist the crow as you go along the wall until you reach another corner where by then you should be back to the proper spring angle on the wall.
If it is a very short run you'll have to keep playing the improper spring angle game until you can twist it into the correct angle.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 11-11-2017, 11:47 AM   #40
KAP's Avatar
Trade: Custom
How cheap can people be? It's painted pine...
I'd tell the customer this is already the result of trying to save a $1... do you want it done correctly or gerry-rigged to accommodate the screw-up?
Which one do you want to live with...
KAP is offline
The Following 2 Users Say Thank You to KAP For This Useful Post:
avenge (11-11-2017), B.Johnson (11-11-2017)
Need help w/ leroi screw compressor jackpot Sandblasting 4 03-04-2013 07:19 AM
Screw gun keeps tearing paper on tapered side??? Spencer Drywall 13 02-20-2013 10:11 AM
LeRoi rotary screw compressor problem/problems Need Help Please. jackpot Tools & Equipment 2 01-16-2013 04:28 PM
Metal Roof leaking at every screw...ideas? labgal Roofing 36 08-14-2010 01:04 PM
drywall screw length vs vapor barrier blacksheep Drywall 7 02-08-2009 09:01 PM
