Not My Crowning Screw Up?
Old 11-09-2017, 05:48 PM   #1
VinylHanger's Avatar
Rewards Points: 7,048
I'm trying to put the final piece of crown on after someone else couldn't finish. I think he just went with 45, but ended up at like a 55 degree angle somehow. Anyway, am I correct in saying his cut is too short on the long point?
His is on the left, my scrap on the right. Great part is the other side is exactly opposite.
I don't do much is any crown, but I don't think this is my screw up?
VinylHanger is offline
Old 11-09-2017, 05:59 PM   #2
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 8,172
Re: Not My Crowning Screw Up?
So, what are you looking for, affirmation - or a fix?
"Your talent is God's gift to you. What you do with it is your gift back to God." - Leo Buscaglia
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Mordekyle (11-10-2017)
Old 11-09-2017, 06:04 PM   #3
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 1,609
Rip it down and start over.
Big Johnson is offline
The Following 3 Users Say Thank You to Big Johnson For This Useful Post:
greg24k (11-10-2017), Jaws (11-09-2017), SmallTownGuy (11-09-2017)
Old 11-09-2017, 06:14 PM   #4
Just making sure it twernt me.
I'm making a plumb cut a couple feet out and redoing the angle. HOs call.
Old 11-09-2017, 06:22 PM   #5
Unger.const's Avatar
Rewards Points: 2,502
Are those both from the same millwork? If you're is mitered at 45. And his was a different angle then there would be a gap in some of that. So since the miter touches all the way through. And only half of the profile matches. I wonder if it is from two different killings? Like trying to match up a Ford engine to a Chevy transmission?
Unger.const is offline
Old 11-09-2017, 07:02 PM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,291
They weren't cut at the same spring angle, so one of them is wrong. Coping is your friend.
MarkJames is offline
The Following 4 Users Say Thank You to MarkJames For This Useful Post:
gbruzze1 (11-10-2017), Jaws (11-11-2017), SmallTownGuy (11-09-2017), Tom M (11-10-2017)
Old 11-09-2017, 07:22 PM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
looks good to me...
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
B.Johnson (11-09-2017), Unger.const (11-10-2017)
Old 11-09-2017, 07:24 PM   #8
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,860
That's what I was gonna say. I think the spring angle is different.
Most of the time, it's 38 degrees.
Unless you (they) cut it flat with a compound miter saw, they had to cut it at its' proper spring angle. Unless they built a fence and paid attention to detail, it could conceivably be at just about any angle.
Delta
I have an Edifice Complex.
Old 11-09-2017, 08:19 PM   #9
Trade: Builder/GC
No, but not your crowning achievement, either.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
B.Johnson (11-10-2017), VinylHanger (11-09-2017)
Old 11-09-2017, 09:39 PM   #10
It was the same milling. I don't think he worried about spring angle at all.
One side was 55 degrees and the other was like 35 degrees if I had to guess at a standard angle and spring angle was off. He quit because the corners weren't 90 degrees.
I ended up having to work my way into it on both sides, then we were short material by 18 inches.
It was close enough to caulk, which I can live with in this case.
Old 11-09-2017, 10:07 PM   #11
Trade: Builder/GC
Really???
Delta
J L (11-10-2017)
Old 11-09-2017, 10:14 PM   #12
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 4,652
If the left side is what you are installing then you can cope it to fit. It will have to be a scribe cope, not just a 45 cope.
If you are putting the right side in, then brotha, you got some issues.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 11-09-2017, 11:26 PM   #13
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,600
Democrats are doing more to undermine our country than Russians could ever hope to do.
Robie is online now
Old 11-10-2017, 12:07 AM   #14
LRG WoodCrafting
Leo G's Avatar
Screwed.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 11-10-2017, 05:15 AM   #15
John the Builder
Damn, even I wouldn't try to caulk 18"
And I'm a caulk gun commando...
The Following 3 Users Say Thank You to SmallTownGuy For This Useful Post:
B.Johnson (11-10-2017), Seven-Delta-FortyOne (11-10-2017), Xtrememtnbiker (11-10-2017)
Old 11-10-2017, 05:57 AM   #16
builditguy's Avatar
Rewards Points: 198
I suspect the previous "carpenter" didn't use a compound miter saw. He held the crown in the miter saw, the way it would go on the wall, and cut it.
What he didn't do, was hold it at the correct spring angle.
It can be done. I've done it, alot. The most important thing is to keep it held at the right height. Cutting a piece of scrap, to use as a height guide, works well.
And of course cope it.
Since you are done, it doesn't matter now. I probably would have torn off the existing, and started over.
Who knows, if I were there, maybe I would have done what you did.
We really won't know the best route, until we hear from Tipi.
builditguy is offline
The Following 3 Users Say Thank You to builditguy For This Useful Post:
Unger.const (11-10-2017), VinylHanger (11-10-2017), Xtrememtnbiker (11-10-2017)
Old 11-10-2017, 06:20 AM   #17
B.Johnson's Avatar
Trade: Builder
Rewards Points: 658
If he cut it on the miter box using the upside down method I would think that there would be a better chance to get the spring angle correct than if he cut it flat on the miter saw.
Cutting it upside down you wouldn't need to know that there was such a thing as a spring angle, never mind what the spring angle might be.
Home Designer Series Software
B.Johnson is offline
The Following User Says Thank You to B.Johnson For This Useful Post:
SmallTownGuy (11-10-2017)
Old 11-10-2017, 06:22 AM   #18
builditguy's Avatar
Rewards Points: 198
You are correct. I have seen it done that way also. I had forgotten about that.
I've also seen guys stand at the saw, staring at the crown, trying to figure out if they are making the cut, the right direction. After they had it upside down.
Old 11-10-2017, 06:58 AM   #19
Tom M's Avatar
Rewards Points: 4,720
Thats why I also cope
Tom M is online now
Old 11-10-2017, 10:33 AM   #20
I never caulk more than 16 inches. I'm not a hack.
It was a quick fixit job for a previous customer that turned into a small mess. She didn't want to pull it down, so we did what we could. It'll look fine with a bit of fill and sanding.
I still need to go back and put up the last small piece when she gets it. It will take longer to set up than to do it. That's one reason I usually avoid these types of jobs.
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
MarkJames (11-10-2017), Unger.const (11-10-2017)
Need help w/ leroi screw compressor jackpot Sandblasting 4 03-04-2013 07:19 AM
Screw gun keeps tearing paper on tapered side??? Spencer Drywall 13 02-20-2013 10:11 AM
LeRoi rotary screw compressor problem/problems Need Help Please. jackpot Tools & Equipment 2 01-16-2013 04:28 PM
Metal Roof leaking at every screw...ideas? labgal Roofing 36 08-14-2010 01:04 PM
drywall screw length vs vapor barrier blacksheep Drywall 7 02-08-2009 09:01 PM
