Need Some Ideas...
Old 01-28-2009, 01:32 PM   #1
KMac's Avatar
Trade: Finish Carpenter
Need Some Ideas...
I got a request from an interior decorator client of mine for a 12' high bookshelf that will be going into a loft condo. It would be frameless and paint grade and I will also be installing a library ladder they are going to supply. Usually i do FF built-ins and shelves and for anything over 8' I just build two separate units - usually cabinet below and open shelves above. This will be all open shelves. My question is what should I do to gain the height needed? If I join two pieces of ply how do i deal with the seam? Any ideas or thoughts would be much appreciated!
KMac is offline
Old 01-28-2009, 01:41 PM   #2
Re: Need Some Ideas...
1X1's to cover the raw ply edges?
Does she think that you can do
4' ¾" shelves with no apron, and
have them carry 300lbs of books
without sags?
neolitic is offline
Old 01-28-2009, 01:42 PM   #3
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
There is not quite enough info to give specifics
How wide are we talking? How many bays?
Is there access trouble if you build full height in shop?
Are there finished ends? or wall to wall? Or wall to finished?
Gus Dering is offline
Old 01-28-2009, 02:04 PM   #4
KMac's Avatar
without sags?
She does not want 1X she wants it "clean & modern". And it's funny you mention 4' wide shelves cause that is what she did want until I said no.
KMac is offline
Old 01-28-2009, 02:07 PM   #5
Gus Dering's Avatar
Fixed shelves or adjustable?
Old 01-28-2009, 02:07 PM   #6
KMac's Avatar
The depth will be 12".
Will not be able to build this in shop - need to do on site - loft is on the 6th floor no need to go up in an elevator. I am doing a bunch of other things there anyway.
The unit will be approx. 4' wide and it will be wall to finished.
KMac is offline
Old 01-28-2009, 02:08 PM   #7
KMac's Avatar
Adjustable 32mm system with of course as many fixed shelves as i need.
KMac is offline
Old 01-28-2009, 02:09 PM   #8
Gus Dering's Avatar
Is she ok with 1 1/2" solid parts?
Old 01-28-2009, 02:11 PM   #9
KMac's Avatar
Probably - I doing some 2" thick "floating" shelves in another room.
KMac is offline
Old 01-28-2009, 02:13 PM   #10
Gus Dering's Avatar
Do you have room to push 11' through a saw in the room?
Old 01-28-2009, 02:13 PM   #11
I'm talking about rips of the same
width as the ply thickness, to cover
the ripped edges of plywood.
At some point one must usually
attempt and introduction.
"Ms. Designer, Reality.
Reality, Ms. Designer.
Would the two of you like to
shake hands now?"
neolitic is offline
Old 01-28-2009, 02:18 PM   #12
KMac's Avatar
No - I do have a TS55 but not a long enough guide rail.
KMac is offline
Old 01-28-2009, 02:19 PM   #13
KMac's Avatar
shake hands now?"
Yeah - it's always a battle with them but this particular one has been keeping me afloat - i like to make her happy if at all possible.
KMac is offline
Old 01-28-2009, 02:22 PM   #14
Sorry, bad taste in my mouth.
maybe a little whiskey later......
neolitic is offline
Old 01-28-2009, 02:23 PM   #15
KMac's Avatar
KMac is offline
Old 01-28-2009, 02:35 PM   #16
Gus Dering's Avatar
Sorry that took a while,
This is what I would probably do;
Check out the quick drawing I attatched.
I would do a face frame job but flush trim the finished end , the top , and the shelves to a double layer of 3/4" ply. The wall side would be 3/4" ply with the same 1 1/2" frame part but flush to the inside.
That gives the case a 1 1/2" solid look and the wall end has 3/4" for scribing.
You may want to put a fixed shelf in the center for support on the finished end side.
This is drawn with one bay. A little bigger than I would do.
Ok I'll draw one with 2. Be right back
11' bookcase.pdf
Old 01-28-2009, 02:45 PM   #17
Gus Dering's Avatar
Here you go, something like this anyway.
11' case 2 bay.pdf
The reason I was asking about the 11' through a saw is that the box parts would be easiest to laminate together with overlapping joints, With one side a little wider than the other and one nice straight edge.
Use that edge to trim the other side cutting both layers at once. Turn the whole thing around and trim to final width.
The quality of joint at the face frame will depend on how nice that double layer flushes up. Plus an ass load of clamps of course.
The Following User Says Thank You to Gus Dering For This Useful Post:
KMac (01-28-2009)
Old 01-28-2009, 02:47 PM   #18
Gus Dering's Avatar
Geez, I can't leave you kids alone for a minute.
Old 01-28-2009, 02:52 PM   #19
KMac's Avatar
Attachment 14594
Really great ideas gus - thank you very much.
KMac is offline
Old 01-28-2009, 02:56 PM   #20
Gus Dering's Avatar
I hope it works for you.
One thing is for sure, it will be heavy as all hell. Get some help.
I hope you find the room to trim as I layed out too
What are they doing using my pictures and linking to my site? Mark Daniels Technology 19 08-04-2011 07:39 PM
Practical GREEN ideas that don't cost much, part 1. wackman General Discussion 24 03-15-2010 07:52 PM
Ideas? TBFGhost Finish Carpentry 25 02-14-2009 01:38 PM
Any ideas what could have happened? will575 Technology 1 12-13-2008 11:18 PM
trailer workbench ideas? Mike B Vehicles 3 08-11-2008 01:36 AM
