Nail Spacing
Old 04-26-2006, 09:30 AM   #1
mms's Avatar
Trade: Structural Steel
Nail Spacing
I am attaching 2-1/2" wide X 3/4" thick oak architectural moulding to 3/4" oak plywood in a panel arrangement.
What should be the minimum nail spacing I should use?
mms is offline
Old 04-26-2006, 09:33 AM   #2
Custom Builder
Glasshousebltr's Avatar
Re: Nail Spacing
8 to 10 inches.
Bob
Bob
Glasshousebltr is offline
Old 04-26-2006, 09:51 AM   #3
mms's Avatar
Re: Nail Spacing
OK thanks!
I forgot to ask if it is necessary to have two rows of nails at
this spacing (one along outside edge and one along inside edge of trim)?
If yes, then side by side or staggered?
I should maybe also mention that the plywood is exposed on the backside, therefore I will be using 1-1/4" nails (so as not to protrude
out the backside).
mms is offline
Old 04-26-2006, 10:34 AM   #4
Custom Builder
Re: Nail Spacing
Staggered.
Bob
Bob
Old 04-26-2006, 02:50 PM   #5
mms's Avatar
Re: Nail Spacing
OK thanks.
I've now cut all my trim pieces, and am about to pre-drill my nail holes.
Just want to be sure what you mean.
8" oc staggered or 8" oc in-line
in other words for a 48" pc - 7 nails or 13 nails?
mms is offline
Old 04-27-2006, 04:27 PM   #6
RowdyRed94's Avatar
Trade: Residential custom home builder
Re: Nail Spacing
They eye tends to notice patterns more so than randomness. Never nail in pairs if you can help it. Stagger them at least slightly. On a 48" board I'd offset a pair near each end and put about 5 more in between for 9. If you don't double up on the ends your board could warp out at the corner that's not nailed.
Clint - carpenter, coordinator, webmaster
RowdyRed94 is offline
Old 04-28-2006, 09:14 AM   #7
mms's Avatar
Re: Nail Spacing
Thanks for the reply (and for suggestion to "double up" @ ends)
mms is offline
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 24 04-20-2011 09:14 PM
too many nail pops!! D-ball Drywall 7 05-26-2007 07:12 AM
In what situation can this nail be used? nailStapleBrads Construction 8 05-17-2006 08:47 AM
Landmarks nail lines MJW Roofing 12 04-04-2006 05:03 PM
