Miter Saws
Old 01-17-2008, 09:43 PM   #61
Mike772's Avatar
Trade: Home Builder
Re: Miter Saws
Originally Posted by Tom F. View Post
Does anybody send blades out for resharpening anymore? I'm speaking of these expensive trim blades. I can remember my dad having them sharpened 30 years ago, but I don't see it done anymore.
Yes. Last year a local tool supplier started to offer blade sharpening. I am thrilled they did. Those 12" Freud industrial ultimate crosscut (96 teeth) blades are not cheap to replace. The odd thing is, I swear it comes back sharper than it was when the blade was new.
Mike772 is offline
Old 01-17-2008, 10:52 PM   #62
orson's Avatar
Trade: Kitchen & Bath
Re: Miter Saws
Originally Posted by Jason W View Post
I've found the 12" blades to cause a wider cut at the face of the material, making trim look like it has a gap at the joint (unless you spend a fortune on a blade).
Try Freud Diablo blades, they are hands down the best blade for the money. Their 12 inch blades rarely have any significant roundout(wobble) and if they do my supplier replaces them for free. They have different grades, the industrial is expensive but worth the extra money if you are getting resharpened.
www.rubycon.us
Ruby Construction LLC
Lancaster Kitchen Remodeling
Lancaster Bathroom Remodeling
orson is offline
Old 01-17-2008, 10:59 PM   #63
orson's Avatar
Re: Miter Saws
Originally Posted by carver348 View Post
After reading all the posts I'm still kinda confussed. Sounds like the bosch gets high marks and the older model dewalt. Some of the reviews on the bosch don't sound so good. Buy a bosch or find a old dewalt? Any ideas?
The older deWalt has really aggravating bevel guage that is ridiculous to try to set at a precise bevel angle. By mounting the markings on a horizontal surfact you can hardly read them. The circumfrence of the guage is too small so the tick marks are too close together. It is almost impossible to read the bevel guage near zero because the saw arm is blocking your view. The new Dewalt model that has the extra deep cut has corrected these problems, however, added it's own host of downers. Imagine having something as simple as the cord coming out the back of the slide arm(working flawlessly) on the old saw and moving it to a place where it gets caught on the new design. Prime example of why I put no stock in DeWalt engineering.
And to take the cake, no detent override on the mitre for those "just off" cuts. My next 12" sliding mitre saw will be a Bosch
www.rubycon.us
orson is offline
Old 01-18-2008, 11:14 PM   #64
Palisade Point Const.
TempestV's Avatar
Re: Miter Saws
My dad has the old dewalt saw, and I've worked with it quite a bit- the bevel is a little hard to read, but I've never really been bothered by it. It might not have detent overrides, but as far as I can tell, you don't need them, considering that I can lock it within 1/2 or even 1/4 of a degree of a detent without a problem. Personally, I find it easier than the saws with the override that you have to activate to do the same thing.
TempestV is offline
Old 01-21-2008, 07:35 AM   #65
orson's Avatar
Re: Miter Saws
What about when you have to lock it at 1/8th or less off the detent? ever try that? Doesn't work so good and wastes a lot of time trying to lock it over and over as it slips into the detent.
this statement sounds smart alecky, sorry didn't mean it that way
www.rubycon.us
orson is offline
Old 01-23-2008, 10:07 PM   #66
BTD's Avatar
Trade: Trim and Finish Carpentry, Remodeling
Re: Miter Saws
Originally Posted by 2ndGen View Post
One question:
Best saw blades for finish work?
General Carpentry?
Freud by miles and sharp teeth. Never will use anything but 80 tooth Freud
BTD is offline
Old 01-26-2008, 02:45 AM   #67
2ndGen's Avatar
Trade: Thoroughbred Roofer
Re: Miter Saws
Thanks BTD...Freud seems to be the consensus.
2ndGen is offline
Old 01-26-2008, 03:13 AM   #68
pknyryan's Avatar
Trade: remodeling - siding, roofing, windws, doors.
Re: Miter Saws
I have personally used all the big name 10 and 12 inch slidig miters and my list would go
1) hitachi 10"
2) Makita 10"
3)dewalt 12"
4) Bosch 12"
The Hitachi is number ne pick because it is light and simple, easy to read and adjust.
The Makita is great as well, except bevel isnt as easy to set as the Hitachi.
I wouln't buy the dewalt - way too heavy and the slide is crap. And it needs almost constant adjustments. I have a Makita for 5 years and I never had to adjust it.
I don't like the thumb adjustment setup on the Bosch at all. I won't use them. I see a lot of people like it. It is quite smooth toslide and very accurate.
pknyryan is offline
Old 02-07-2008, 03:07 PM   #69
TrimmanVa's Avatar
Trade: Interior Trim/Decks
Re: Miter Saws
Hitache 12' compound slide. Very versitile for every trim application.
TrimmanVa is offline
Old 02-07-2008, 03:29 PM   #70
The Deck Guy
Greg Di's Avatar
Re: Miter Saws
I think you mean "runout" which is blade wobble.
Greg Di is offline
Old 02-07-2008, 10:06 PM   #71
stp57's Avatar
Trade: carpenter/ handyman
Re: Miter Saws
A lithium ion battery might actually make the cordless Makita worth the price.
Steve
stp57 is offline
Old 02-08-2008, 09:20 AM   #72
TrimmanVa's Avatar
Re: Miter Saws
I made a mistake on my post, i meant the hitache 10 in compound slide, the 12 in way to bulky .... Good luck
Old 02-08-2008, 01:25 PM   #73
The ONLY way is DEAD_ON!
DEAD_ONConst's Avatar
Trade: Custom Finish/Carpenter
Re: Miter Saws
Without a DOUBT, Freud Diablo's! Damned things don't cut, They friggin' slice wood! Bolt that to a well tuned Ridgid DCSM and you are in business!
I do send my blades out to be sharpened as well. There is just no excuse not to. I have them reground until there is nothing left to sharpen and then it gets trashed. And you are basically getting 10 blades before it is worthless. Over the initial purchase of around 70.00 for a 80T blade and 10 additional sharpenings @ 15.00 I spend 230.00 over the life of the blade compared to 770.00 for 11 blades (1blade +10 sharpenings)
My choice for Saws are Ridgid! Right out of the box they work great and are accurate. I did make some adjustments to the slide to eliminate some wobble when pulled fully toward you. Then it was a matter of double checking the bed and fence square and the head plumb to the table. If you have to make adjustments, they are quick and easy with this saw.
It is accurate enough for trim work, but I have a single-bevel CMS, also a 12" Ridgid that I use for cabinetry/finish work when I want my miters and joints to be ABSOLUTELY precise.
DEAD_ONConst is offline
Old 02-08-2008, 09:02 PM   #74
Carpenter/Finisher
john5mt's Avatar
Re: Miter Saws
is there such thing as a well tuned rigid dcms? is there such thing?
john5mt is offline
Old 02-08-2008, 09:41 PM   #75
Sweeper of fine saw dust
chris klee's Avatar
Trade: Project Manager by day, Cabinet maker for fun
Re: Miter Saws
yep. use those blades on everything, circular saw has one framing blade and one finish blade, codrless saw has 2 blades, miter saw has one and table saw too.
i use a hitatchi 12" non slider. i didnt buy the saw and it wouldnt have been the one i chose, but it works great every time. my boss messed up my 10" delta that i had for a while and this was what he bought me to replace the one he broke. i dont use miter saws for framing, so it stays in better shape. this one is over 2 years old now and still in almost perfect shape.
having said that, i really like the new bosh saws out of all the ones i have
used reciently
chris klee is offline
Old 02-08-2008, 09:44 PM   #76
chris klee's Avatar
Re: Miter Saws
i thought wobble was side to side and runout was out of round?
Old 02-08-2008, 10:13 PM   #77
JLTrim's Avatar
Trade: Finish Carpentry
Re: Miter Saws
They make a damn good blade. I spent all day today cutting 2x mahogany with one on my DeWalt 12" and every cut was clean and straight, even when I just had to slice a hair off a previous cut.
JLTrim is offline
Old 02-08-2008, 11:00 PM   #78
stp57's Avatar
Re: Miter Saws
http://boschtools.com/Products/Tools....aspx?pid=3918
no up front controls, but still cool.
Steve
stp57 is offline
Old 02-09-2008, 01:04 PM   #79
Re: Miter Saws
YEP, I have TWO of them! Both are ACCURATE to within 1/256th" in any axis!
I take great pride in my work, and as I am also a Master Certified Auto mechanic and build hi-performance engines and transmissions, I have a natural inclination toward accuracy. It took me about an hour to set-up and align my Sliding miter and about 45 minutes for the Compound miter, but When I need to nudge a miter because something is a little out of square, it isn't a problem for me. The biggest draw-back with the Slider is in fact the rail system, as is the case with ANY sliding miter saw. I looked at a brand new Makita and DeWalt yesterday and the had deflections of about 1/8"-3/16", OUT OF the BOX! My Ridgid wasn't that bad, and is better now. Now that's DEAD_ON!
Old 02-09-2008, 01:22 PM   #80
Re: Miter Saws
Anyone use the Freud "Avanti"?
(10" 80t, 12" 96t)
They used to make another
chromed one that looks like it,.
Can't remember the numbers,
and mine are worn off now.
L/S I got a great deal on one,
tried it, liked it, went back and
they were discontinued
Anyhow they were the equal of the
Forrest for ½ the money.
"Avanti's" look just like them.
neolitic is offline
Blade Wobble New Miter Saw balanceact Finish Carpentry 7 06-03-2008 09:12 AM
Miter Saws Accuracy: Slider vs. Non-Slider bradbheld Tools & Equipment 17 11-26-2007 08:18 PM
Hitachi sliding compound miter saw A.W.Davis Tools & Equipment 14 02-01-2007 07:53 PM
Best Table saw and sliding miter saw. wackman Carpentry 42 08-19-2006 07:04 AM
what about miter saws? Rob A Finish Carpentry 41 08-10-2006 06:50 PM
