Minimum Door Width
Old 02-20-2009, 08:43 AM   #1
President of the world
world llc's Avatar
Trade: general contractor
Minimum Door Width
is there a minimum width for cabinet rails and stiles?
I'm thinking about making some doors 1 1/2" wide in poplar, but worried it will twist up easiely...
any words of experience are appreciated!!
edit: more info... 2 doors flush mount recessed panels... each door 40" tall by 12 1/2" wide
world llc is offline
Old 02-20-2009, 12:41 PM   #2
cleveman's Avatar
Trade: custom home building
Re: Minimum Door Width
Haven't worked with poplar. I use 2" rails & stiles. I think 1 1/2" should be no problem. I think a lot of people use 1 1/2" stock for the facing.
The type of panel will also determine what happens to the door as well. I'm assuming you're using some plywood panel which will be more stable than a solid, glued up panel.
cleveman is offline
Old 02-20-2009, 01:22 PM   #3
Trim40's Avatar
Trade: Guy who plays with wood
2" stiles and rails give you a little more room for egde routing. 35mm cup hinges might be tight with 1 1/2" stock. You could also add a mid rail to help keep things straight
Trim40 is offline
Old 02-20-2009, 04:50 PM   #4
world llc's Avatar
maybe i'll go with 1 3/4 to keep it safe. the panel will be ply. no profile on either edge, square is what they want.
thanks for the help so far
Old 02-20-2009, 06:12 PM   #5
OW! My thumb's Avatar
Trade: Finished /Remod/Decks/ done it all /whatever pays
I try to use a minimum of 2", sometimes 2 1/4.
Is there a reason for 1 1/2, like trying to match whats there?
I use poplar all the time on my paint grade stuff. Just be picky when you look through the pile.
OW! My thumb is offline
minimum stair requirement, broken back te12c02w Carpentry 12 04-28-2008 07:32 PM
Learning at minimum wage Mark Twenhafel General Discussion 6 01-08-2007 08:13 AM
Sevice call minimum charge? Chris G General Discussion 19 10-20-2006 07:11 AM
Minimum labor charge for tile Rich Flooring 23 03-19-2006 10:53 AM
minimum ceiling height mvpulsts Remodeling 1 01-11-2006 09:48 PM
