Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Finish Carpentry
Old 11-01-2009, 09:01 PM   #1
Faking my Way
TBFGhost's Avatar
Trade: Architectural Trim and Punchlist Work
Mantel Codes
I need a little help, I am not sure what the clearance around the firebox is required by code and more importantly why you guys reccommend...it is a wood burning one if that matters...
TBFGhost is offline   Reply With Quote
Old 11-01-2009, 09:24 PM   #2
http://www.manteldepot.com/building_code.htm
http://www.woodweb.com/knowledge_bas..._clearance.JPG
neolitic is offline   Reply With Quote
Old 11-01-2009, 09:35 PM   #3
Faking my Way
TBFGhost's Avatar
Thank you, everything checked out with my plan except I need to move the mantel shelf up 4 inches.
The Sketch up.... bookcases on both sides, mantel shelf connecting them. PVC pipe running through mantel shelf, into and down left bookcase to assist in ease of wire fishing for the TV that will sit on the shelf with the components in the left base cab. Shaded area is exsiting brick, the hearth is also brick but I didn't shade it, otherwise it would get more confusing to look at.
Old 11-01-2009, 11:52 PM   #4
I think we use the same drawing "program."
Old 11-02-2009, 07:37 AM   #5
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Excellent link, Leo. Just added that to my library.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline   Reply With Quote
Old 11-07-2009, 03:51 PM   #6
Faking my Way
TBFGhost's Avatar
The start up cost is next to nothing, but I seem to loose alot of time everytime I use it...
Old 11-07-2009, 04:38 PM   #7
You got that right.
Old 11-07-2009, 06:07 PM   #8
Here's one I did a few years ago if it helps your (somewhat similar) design any.
This one housed an electric fireplace insert, notice the convenient openings for the electronics . . .
Tom R is online now   Reply With Quote
Old 11-07-2009, 06:14 PM   #9
Dream Maker
Mr. D's Avatar
Trade: residential construction
Here in northern Michigan the inspectors always require the specs given by the manufacturer. That is what they go by. Therefore, it changes with every fireplace mantle and hearth I build.
Mr. D is offline   Reply With Quote
Old 11-07-2009, 06:15 PM   #10
Faking my Way
TBFGhost's Avatar
thanks
Insurance classification codes rwhit Business 13 11-17-2009 05:04 AM
Mantel angus242 Carpentry 3 09-24-2009 02:04 PM
Where can I find NC codes? vinnievega Construction 55 09-14-2009 01:22 PM
MA Building Codes Jaketoo Decks & Fencing 2 06-09-2009 06:52 PM
Drywall codes c_tischler Drywall 2 10-17-2008 06:49 AM
