Trade: General Contracting
Kreg Jig K2 Vs. Porter Cable 550
I was looking for some input on these tools.
I have used the Porter Cable model before , but can't remember what it's limitations are , opposed to the Kreg Jig2 or the K3 Master System. If any of you have used either or both , could you comment on pro's and con's of each. I have bid a trim job with head pieces , and I plan on using this method opposed to a bisquit for assembly. There is a slight 45 degree chamfer on the trim edges , so flush fits are not as critical. I am a trim carpenter working new residential housing mostly. TIA for any input Also here is a link for the Kreg tools w w w.kregtool.com/products/pht/product.php?PRODUCT_ID=10 |
Master Craftsman
Trade: Rustic interior woodwork
Re: Kreg Jig K2 Vs. Porter Cable 550
I've use the Porter Cable pocket cutter too and didn't like it. You have to swing the router then drill the pilot hole with a drill, move over and repeat. I have a Kreg Jig and love it. Quick and easy to set up and change and the bit drills the hole and pilot all in one step. I would definately get the Kreg.
Dave.
Do one thing at a time, do it well, then move on. http://www.bigdaveswoodworks.com |
Finish Carpenter
Trade: Finish Carpentry
I've never used the Porter Cable, but it would have to be very good to beat the Kreg. I have had the Kreg for a few years, and can't imagine anything working better.
Trade: carpenter/remodeler
i have a kreg and i simply love it. it is easy, fast, and handy. i can't comment on the pc.
Trade: Pressure Washing
My vote is also for the Kreg for all of the same reasons listed above.
Thanks Dave , as well as everyonelse that gave input .
Looks like I will give up on the Porter Cable and pick up the Kreg K3 Master System. |
miterclamp.com
Trade: interior trim/cabinets
Porter cable quit making the 550 a long time ago, so you'd have trouble finding one except used. The used ones have been selling for a hundred bucks or so more than they used to cost new on ebay.
I burnt the motor out on my old one, then the laminate trimmer motor I replaced it with, before getting another on ebay (for more than the original cost). I tried a kreig jig that my partner had once and didn't like it at all - but that was in 95 or so, so they may have improved the drill bits and the jig itself since. Neither of us could keep the step drills from breaking at the step. The only replacements we could get locally were from a woodworking tool store chain which has since gone banckrupt. They were probably made in china. The porter cable was way, way faster than the other one I tried. The hole you have to drill from the back side is only 1/2" deep or so and of a small diameter. I would have that hole drilled before the router motor stopped. And the pocket screw goes into the stock parallel to the face, so the screw doesn't tend to slide the two pieces out of alignment when you tighten the screw. I didn't need to clamp the stock to anything when assembling - a major time savings, especially if you're on a job site and already cramped for space. If you are planning on staying in the business for a while - I'd definitely consider getting a stationary pocket hole cutter. They are pretty light, have a small footprint, and would pay for themselves quickly on jobs where a lot, if not all, of the casings are jackmitered or butted like you are doing now. Back the cost of the manual one out of the price of a stationary one, and see what it'd cost you. I just did: the porter cable stationary is $699. The Kreig stationary is about 3 times more and probably much better constructed. Most of the guys I know have used the porter for years and like it fine. Regards, Jimc Last edited by clampman; 09-18-2006 at 01:15 PM. |
Trade: Landscape Carpentry and Construction
I haven't used the PC but have been using the Kreg for 2 years and like it very much. I haven't had any trouble with the bits breaking. One tip, I use a pocket comb (while the drill is coasting to a stop) to clean out the flutes, a real time saver.
miterclamp.com
Colonel,
Well, Joe probably broke the original and replaced it with china ones. That's a good tip on cleaning out a twist drill. For about two years (when drilling dowel holes), I used to wipe the bit across my jeans as it was winding down. Then one day the bit grabbed my jeans, and let me tell yah, leg skin doesn't wrap around a 5/16ths drill bit very well - even when sandwiched between denim. I highly do not recommend that method. Regards, Jimc |
| Porter Cable 7800 Drywall Sander | xtremekustomz | Drywall | 33 | 01-28-2010 12:00 AM |
| porter cable palm belt sander | Bone Saw | Tools & Equipment | 5 | 04-18-2007 06:47 PM |
| porter cable drywall sander | tgates | Contractor Swap | 5 | 01-24-2007 09:51 AM |
| Porter Cable Framing Nailers | Reno | Tools & Equipment | 10 | 05-04-2006 11:44 AM |
| GREAT Custome Service from Porter Cable | JPV123 | General Discussion | 3 | 04-06-2006 09:06 PM |
