Kitchen Cabinet Crown
Old 05-16-2012, 06:45 AM   #1
Milhaus's Avatar
Trade: Residential Remodeling
Rewards Points: 254
We have been fortunate to have a number of kitchen and bathrooms lately, but continually run into problems with crown moulding on older houses, where uneven ceilings pose an issue.
Do you guys have any tips on how to control this better? I've talked with my kitchen designer and am at the point that I think ordering a two piece crown right from the start is the best option. We have one area that the ceiling dives upward a fair amount, and it is absolutely necessary for two piece crown, but then another area that the standard 4" crown works fine. You guys have any suggestions on how to better control this variable?
Do we need to be more meticulous with leveling the ceiling in as we're putting sheetrock up? We pulled the plaster on the house we're working on, shimmed the joists down, but still ended up with one spot that we couldn't remedy. Any ideas are welcome-thanks in advance.
mark
Milhaus is offline
Old 05-16-2012, 07:00 AM   #2
Dan_Watson's Avatar
Rewards Points: 2,470
Re: Kitchen Cabinet Crown
mark
Please explain.
I would strap the ceiling when possible. Make sure it planes through and is level. Then, as long as the cabinets are installed level, your problem is solved.
Dan_Watson is offline
Old 05-16-2012, 01:35 PM   #3
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
It was either Lone or Kent ......think it was Kent.....anyway, he purposely made the cabinets a couple inches short for that specific reason.
CrpntrFrk is offline
Old 05-16-2012, 04:42 PM   #4
OKMrazor's Avatar
Trade: Cabinet/Millwork Designer
Rewards Points: 256
If you pulled the sheetrock on the ceiling then yeah... that was the time to level things out.
It's a relatively quick, easy and invisible fix at that point. It's a noticeable, pain in the a** fix at any other.
The most visible/referenceable gap will be between the door and the bottom of the crown. That should be darn near consistent.
OKMrazor is offline
Old 05-16-2012, 04:52 PM   #5
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
I agree with above. If your pulling down the ceiling, I would take more time to level/flatten the ceiling, not try and hide it with crown. Fastest way I know is two just get a nice level line going around the room at the lowest point of the ceiling and sister all the joists up so they are level and flat at what ever height was the lowest point.....if you REALLY want to go crazy, I have used my Plunge/Rail saw to rip dead flat, dead straight edges on Kiln dried...
Last time I did that was a bathroom, tile guy LOVED the dead flat, dead plumb, dead square walls in the shower.
TBFGhost is offline
The Following User Says Thank You to TBFGhost For This Useful Post:
hdavis (05-19-2012)
Old 05-16-2012, 05:20 PM   #6
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 512
I've matched some really bad ceilings by just rolling the crown a bit. As said before, just be sure to keep the cab door top to crown bottom measurement the same.
KnottyWoodwork is offline
Old 05-19-2012, 05:06 AM   #7
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
i would have leveled ceiling. couple of simple fixes depending how bad ceiling is. anything 3/8 and under you could probably get away with either rolling, scoring sheetrock, cheating reveals, block plane top of crown.
blackbear is offline
The Following User Says Thank You to blackbear For This Useful Post:
jessrj (05-19-2012)
Old 05-19-2012, 07:38 AM   #8
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
In cases where the dw ceiling is existing, I use a 4' and 6' plastering trowel to level out the ceiling. I typically do this for stain grade crown installs.
I'll use sandable 90, then finish mud. Doesn't really take all that long and it's better than trying to caulk it in, which always looks lousy.
katoman is offline
Old 05-19-2012, 08:00 AM   #9
hdavis's Avatar
Rewards Points: 9,051
mark
Absolutely. Get the edges done right, then fill in the rest.
hdavis is offline
Old 05-19-2012, 02:13 PM   #10
jessrj's Avatar
Trade: Cabinet Installer.
Rewards Points: 75
I agree. Sometimes you just have to cheat the reveals a little. If your building the house, then make sure its level where the cabinets go. If your not a two piece crown works but its time consuming. Most small problems can be cheated but I have also run into some ceilings that aren't small problems and you just have to do the best you can.
Stay sharp
www.mmbladesaver.com
jessrj is offline
Old 05-19-2012, 08:20 PM   #11
smeagol's Avatar
Trade: new construction and remodeling
Rewards Points: 638
You measure your differences in height of reveal and transfer the adjustments to the vertical part of your crown fence. (Given you are upside down and backwards)
smeagol is offline
Old 05-19-2012, 08:52 PM   #12
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
That's the way I was taught, works out nice and you can just roll it between the cuts or joints, unless your talking a 1/2" or bigger
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Old 05-21-2012, 08:32 PM   #13
roofguy1000s's Avatar
Trade: general contractor
Rewards Points: 25
I agree with fixing the ceiling before sheetrock. Also if the ceiling is being scrolled you can add a little more plaster.
roofguy1000s is offline
Old 05-21-2012, 09:07 PM   #14
Perfectionist
MF Custom's Avatar
Trade: Custom Carpentry
Rewards Points: 764
Flat ceiling = best solution.
A 2 peice crown will help but you will still have a reveal change on the riser.
Scribing combined shiming and followed by building down with spackle can also help if it's not to far out. When I know I'm going to the ceiling I always check it before I rock.
MF Custom is offline
Old 05-23-2012, 02:03 PM   #15
Five Star's Avatar
Rewards Points: 1,010
If your not fully gutting the kitchen in a 2 part crown you have some lee way , I also find it acceptable to level the crown and let the rest shadow above without trying to fill it !
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
refacing cabinets-is it 'worth' it? AustinDB Kitchens & Baths 18 10-29-2016 03:36 AM
Kitchen remodel electrical question Dore Electrical 9 05-15-2011 09:03 AM
Fugly kitchen crown Kent Whitten Carpentry Picture Post 11 06-30-2010 07:08 PM
Please help -Kitchen cabinet question BusyOne Remodeling 20 01-13-2010 01:08 AM
Kitchen Cabinet Software??? fathersonfab Marketing & Sales 27 10-08-2007 07:36 PM
