Jack Miter Jig
Old 07-31-2009, 04:56 PM   #1
basswood's Avatar
Trade: trim carpenter
Jack Miter Jig
I made a jig to make cutting jack miters easy. Jack miter cuts can be done with power tools... but the head casing miter cut made with a power miter saw leaves a fair bit of hand saw work to get into the inside corner (like finishing stair stringer cuts by hand).
The jig I made holds the casing on edge with just the profiled portion to be mitered showing. This is similar to the jigs the old timers used to cut jack miters... I just added the hand miter box. This lets you cut the miter with a hand saw very precisely and quicker than cutting with a power miter saw and switching to a hand saw to finish. This only makes sense it you regularly cut jack miters (of course if you have one you might regularly cut jack miters ) )... but here it is anywho:
Jack Miter Jig-hand-saw-compound-miter-box.jpg   Jack Miter Jig-casing-jack-miter.jpg
basswood is offline
Old 07-31-2009, 05:07 PM   #2
Grand Rapids Remodeling
Paulie's Avatar
Re: Jack Miter Jig
I've watched your posts and expertise in the trim work. They are always informative. I've done a few jobs but basic compared to your experience. But I'm interested in the jig. Can you by chance take a pic of a piece in the jig? I get what your doing but can't wrap my mind around the actual workings.
Paulie is offline
Old 07-31-2009, 05:15 PM   #3
basswood's Avatar
Re: Jack Miter Jig
Here you go... an end view pic of the jig with a piece of casing at the end... just a long slot miter box. Also a pic of the jig in use:
Jack Miter Jig-jack-miter-jig-end-view.jpg   Jack Miter Jig-jack-miter-jig-use.jpg
basswood is offline
Old 07-31-2009, 05:20 PM   #4
Paulie's Avatar
Re: Jack Miter Jig
Most excellent! Thanks all clear now. Nice work.
Hope I didn't make you cut a piece short on my behalf.
I see a small cut on the front board that holds the work vertical, is it hard to no when to stop your cut?
Paulie is offline
Old 07-31-2009, 05:21 PM   #5
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Re: Jack Miter Jig
Pocket screws in the joint?
Gus Dering is offline
Old 07-31-2009, 05:30 PM   #6
basswood's Avatar
Re: Jack Miter Jig
Thanks Paulie,
The short piece was already in the waste bin... so no worries. I make the table saw rip cut first... so when the cut is finished the piece just drops out.
basswood is offline
Old 07-31-2009, 05:34 PM   #7
basswood's Avatar
Re: Jack Miter Jig
Ya sure, you betcha!
Jack Miter Jig-jack-miter-pocket-screwing.jpg   Jack Miter Jig-back-jack-miter.jpg
basswood is offline
Old 07-31-2009, 08:23 PM   #8
Gus Dering's Avatar
Re: Jack Miter Jig
Are we relying on the painter to caulk the little spot where the relief cut runs out the end?
You know how those painters are.
Looks good Bass
Old 07-31-2009, 08:35 PM   #9
basswood's Avatar
Re: Jack Miter Jig
Looks good Bass
Gus, this will be backbanded so the relief cut will be covered.
You didn't think I would expect that much from the painter did you?
basswood is offline
Old 07-31-2009, 08:52 PM   #10
BobsLandscaping's Avatar
Trade: Landscaping
Re: Jack Miter Jig
What is a jack miter and what is it used for?
BobsLandscaping is offline
Old 07-31-2009, 09:08 PM   #11
rayh78's Avatar
Trade: GC - Home repair
Re: Jack Miter Jig
Its when Jack the carpenter makes a miter cut.
Jack drinks a little, thats why the tilted miter saw.
rayh78 is offline
The Following User Says Thank You to rayh78 For This Useful Post:
JRSeifert (07-06-2010)
Old 07-31-2009, 09:15 PM   #12
basswood's Avatar
Re: Jack Miter Jig
A jack miter is a combination of a butt joint (of the flat portion of a molding) and a miter (of the profiled portion of a molding). It is used to avoid very large miters which tend to open up with seasonal changes. In this day of conditioned spaces it is less important, however it is still a good idea in my area (Minnesota) due to radical differences between summer and winter.
In the age of hand saws jack miters were rather easy to do... with power tools, not so much. Now they are considered difficult to do well, and time consuming. My jig is a way to make them easy to do.
basswood is offline
The Following 2 Users Say Thank You to basswood For This Useful Post:
BobsLandscaping (07-31-2009), Tom Struble (08-01-2009)
Old 08-01-2009, 02:02 PM   #13
Re: Jack Miter Jig
Only had to do that for one house.
Had to build an old fashioned wood
miter box.
Is that a Jorgensen miter box?
That rig would be a tad awkward
with my old #358 Stanley.
neolitic is offline
Old 08-01-2009, 04:17 PM   #14
basswood's Avatar
Re: Jack Miter Jig
Neo,
That is a Jorgensen. The saw is decent, but small. Pretty short stroke... not a real pro miter box. It is good for cutting base shoe though.
The small size makes it good for this jig... small 45* ramp, and attaching it to the big slot miter box jig makes it nice and stable. I like doing hand saw work, makes me feel connected to craftsmen of the past.
basswood is offline
Old 08-01-2009, 04:31 PM   #15
Re: Jack Miter Jig
Neo,
Sometimes it's better.
Sometimes it's faster
to set up.
Sometimes it's just more fun!
It's always more quiet.
neolitic is offline
Old 08-02-2009, 12:52 AM   #16
S Winklepleck's Avatar
Re: Jack Miter Jig
Very nice bit of info
I would have cut the mitre with my chop saw set to a 45 bevel, then the straight cut on the table saw. I wouldn't have even thought to have a jig like this. I'm sure this produces much better results. I may need to talk my boss into letting me put one together at the shop
-Steve
"I need the skilsaw." ... "Why did you bring me the drill box?" "It says S.A.W. on it." "Those are my initials."
S Winklepleck is offline
Old 08-10-2009, 11:01 PM   #17
basswood's Avatar
Re: Jack Miter Jig
Got rained out last week (jobsite shop in the yard) so I took the measurements to the shop and precut as much as I could. Each doorway has 15 pieces of trim and 24 cuts (compared to 3 pieces of trim and 4 cuts for a basic door casing set):
Jack Miter Jig-jack-mitered-head-casings.jpg   Jack Miter Jig-vic-casing-sets-precut.jpg
basswood is offline
Old 08-10-2009, 11:07 PM   #18
basswood's Avatar
Re: Jack Miter Jig
Two of the doorways met at an inside corner and the casings had to be ripped down. One of the doorways was not plumb so the rip was tapered... and the heights were 3/4" different. I cheated the head reveal up on the low door (to the garage) and made up the rest on the flat of the casing.
Even with the trim mostly precut, I only managed to trim 4 doorways in a day.
basswood is offline
Old 08-10-2009, 11:31 PM   #19
BillD's Avatar
Trade: General contractor
Re: Jack Miter Jig
Nice set up Basswood, thanks. Do you change the jig to accept different moldings or do you just make a different jig?
Bill
BillD is offline
Old 08-10-2009, 11:48 PM   #20
basswood's Avatar
Re: Jack Miter Jig
Bill
Bill the slot of the jig could have fillers added for smaller moldings... or the miter box platform could be moved up or down (it is easily attached with pocket hole screws):
basswood is offline
Miter folding with a cnc machine Gus Dering Finish Carpentry 35 11-30-2009 07:10 PM
Miter saw for framing Stubits Framing 5 04-25-2009 02:41 PM
Jack stud question billderboots Framing 45 12-31-2008 07:13 PM
What jack hammer should i get? :-) Houston's Tools & Equipment 8 10-24-2008 03:09 PM
Blade Wobble New Miter Saw balanceact Finish Carpentry 7 06-03-2008 09:12 AM
