DN Construction
Trade: Construction
Ironing Board
Hey guys, I am doing a remodel in a condo for some very high end people. Everything in this house is high end from their towel bars made in Germany to the super high gloss on their floors. My question is they want a ironing board that mounts to the wall and flips down when in use. Has anyone installed one of these, and was it up to par for a high end house? Also where did you get it from?
Thanks in advance Dave |
Sure, I can do that...
Re: Ironing Board
I built my own and installed it. Used a regular portable one as a pattern.
Re: Ironing Board
Yes, i have installed a few, in general they are ok quality, the padded cover that goes over the board is a bit cheap, and slides around, but it has an outlet, place to hold the iron, and a wood RP door, my electrician supplies it when needed, GMOD
Re: Ironing Board
Google Nutone ironing center and look at the deluxe model. I think you will like this one. Wish I could post a link for you but I don't know how.
Still have all my fingers
Re: Ironing Board
You can chuck the factory door and frame and build something that goes better with the decor. The hardware and mechanism on these is decent.
http://www.hideawayironingboards.com/home_frm.html
Killing the Earth, one raised panel at a time....... http://bergstromcabinets.com http://minneapoliscabinets.biz http://maplegrovecabinets.com |
#6 | |
Re: Ironing BoardQuote:
http://www.nutone.com/product-detail...roductID=10590
| The war of plywood VS particle board | Jimmy Cabinet | Kitchens & Baths | 46 | 04-26-2010 10:31 AM |
| Drywall overtop foam board | im4snow | Drywall | 2 | 11-08-2009 09:04 AM |
| determining skirt board height | romoranger | Finish Carpentry | 2 | 07-07-2009 02:46 PM |
| Rigid Foam Board under sheathing | milfordtom | General Discussion | 12 | 05-13-2009 12:12 AM |
| Plywood over particle board | PA woodbutcher | Flooring | 5 | 03-11-2009 07:09 AM |
