Ideas For Transitions From One Type Of Crown To Another
Old 03-16-2009, 12:53 PM   #1
Carpenter/Finisher
john5mt's Avatar
So my customer's kitchen cabinets have crown and go to the ceiling and he wants to add crown throughout the rest of the kitchen, living room, dining room, and hallway. It's a nice sized crown job but he doesnt want to use the pickled oak crown on his cabinets and throughout those rooms and and he doesnt want to rip it off and put white crown on top of the cabinets (understandable).
I have seen some transition boxes before and hated the look of them so i drew up this idea:
Does any one have any other ideas or ways to maybe improve this one.
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Old 03-16-2009, 01:54 PM   #2
RED HORSE 554's Avatar
Trade: Project Manager and Builder
Re: Ideas For Transitions From One Type Of Crown To Another
Bring the crown mold in under the top cap on the corner box add a trim alike the top cap to act as a closer Between boxes set revels the same Doing this will icon or bold the corner box and it will be viewed as a hightlight and not a part of the crown molding if possable place a band at the bottom just under the crown this will give added detail.
RED HORSE 554 is offline
Old 03-16-2009, 02:53 PM   #3
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
If you can get the same profile, the transition from one finish to another is not a bad look at all.
I don't think it is I should say.
Gus Dering is online now
Old 03-16-2009, 03:12 PM   #4
Palisade Point Const.
TempestV's Avatar
I don't know what kind of profiles you are using, but what would it look like if you coped one piece into the other?
TempestV is offline
Old 03-16-2009, 05:48 PM   #5
Carpenter/Finisher
john5mt's Avatar
were putting a bigger crown on the ceiling than is on the cabinets....
he doesnt like the look of the two colors switching in the middle.
1st Gen tradesman
john5mt is offline
Old 03-17-2009, 11:31 AM   #6
dubz's Avatar
Trade: General Contracting
We would always run the same profile like Gus showed. It's the best solution IMO. If it's not possible, I'd probably return the crown back to the wall a bit before the cab crown before I did a plinth type block. I think the block would draw your eye and be more noticeable.
dubz is offline
Old 03-20-2009, 03:35 PM   #7
I think we used the same on this project. but have used the stacked moldings and boxes. This project is my home
Old 03-20-2009, 06:02 PM   #8
Pimpovic's Avatar
I wouls say that you are doing it the hard way, having a larger crown on the ceiling than on the cabinetry. My first thought was to cope the ceiling molding into the other but this will be pretty unsightly having a large crown run into your cabinetry. You will have to compromise the look of the transition unless you rethink the size of the crown moldings.
Pimpovic is offline
Old 03-20-2009, 11:16 PM   #9
Carpenter/Finisher
john5mt's Avatar
Umm red horse
that looks great
But i dont see how it has to do with my question
1st Gen tradesman
john5mt is offline
Old 03-20-2009, 11:22 PM   #10
Carpenter/Finisher
john5mt's Avatar
The problem i am running into is my supplier is telling me that the crown on the cabinets is 3" and they cant get crown that is smaller than 3 1/4".
1st Gen tradesman
john5mt is offline
Old 03-21-2009, 12:31 AM   #11
miterclamp.com
clampman's Avatar
Trade: interior trim/cabinets
Well, as the saying goes, you can polish a turd for a real long time but when you're all done you still just have a real shiny turd.
Since you can't get what you need, I'd do as Dubz suggested and just return the large crown to the wall before you reach the kitchen crown, which simply dies into that same wall. Cut a return on a stick of crown and hold it up there for the owner to decide where to end it.
I would select a crown with the same spring angle if I were you though.
Good luck.
Jim
clampman is offline
Old 03-21-2009, 08:37 AM   #12
basswood's Avatar
Trade: trim carpenter
Here is a pic of a mockup Tom posted here of a minimal corner block, and another pic of the return option someone else posted (there is also the scribe option--but I don't have a good pic of that).
Ideas for transitions from one type of crown to another-opposingcrowns005.jpg   Ideas for transitions from one type of crown to another-photo_091908_001.jpg
basswood is online now
Old 03-21-2009, 08:39 AM   #13
TempestV's Avatar
How would it look if you had some sort of decorative column or post running full length from floor or counter to ceiling? I've seen that done where it looks good.
TempestV is offline
Old 03-23-2009, 11:20 AM   #14
Originally Posted by john5mt View Post
Umm red horse
that looks great
I looked and chatted with others on this question all say get a bigger corner box with no top cap or drop the crown below the top cap of the corner box and add a flat closer strip to the ceiling to close the gap. Route the leading edge of closer strip to match with a ogy of some kind for detail to match crown. I found this video.
http://video.aol.com/video-detail/ho...own/2458673972
Old 03-23-2009, 03:06 PM   #15
Carpenter/Finisher
john5mt's Avatar
Thanks for the mock up on the minimal bass.
1st Gen tradesman
john5mt is offline
Old 03-23-2009, 11:58 PM   #16
basswood's Avatar
Tom made that mock up, but I thought it was a good idea for some situations.
It would be interesting to see it in painted crown into stained crown, with the two sides of the block in different colors.
Practical GREEN ideas that don't cost much, part 1. wackman General Discussion 24 03-15-2010 07:52 PM
Need some "Pergola" type ideas RCPainting Carpentry 1 03-08-2008 12:36 AM
Crown and Popcorn silvertree Carpentry Picture Post 12 02-04-2008 09:39 PM
Large crown on a built-in cabinet Bummie Finish Carpentry 5 09-01-2007 08:53 PM
space above crown ch0mpie Finish Carpentry 6 03-06-2007 01:41 AM
