I Replace Most Of Trim On My House Today Because Of Rot!
Old 03-06-2010, 08:57 PM   #1
CJ21's Avatar
Trade: Carpenter & Woodworker
I help my dad today replace most of the outside trim today! I think I did a fair job, this is my first carpentry project since I finish college.
CJ21 is offline
Old 03-06-2010, 08:59 PM   #2
CJ21's Avatar
Re: I Replace Most Of Trim On My House Today Because Of Rot!
CJ21 is offline
Old 03-06-2010, 09:03 PM   #3
Wood Craftsman
PrestigeR&D's Avatar
Thumbs up
CJ,
I think you did a very nice job- Keep it up ,nice and straight- looks clean- good job! Your dad is probably very happy with you!
Brian
PrestigeR&D is online now
Old 03-06-2010, 09:14 PM   #4
Curious about the 1X2.
Is that a common detail down there?
Seems like it would lower the gutter
and close it up a bit.
neolitic is offline
Old 03-06-2010, 09:15 PM   #5
CJ21's Avatar
Yes the 1x2 is a common detail in the south, the house do not currenly have gutters.
CJ21 is offline
The Following User Says Thank You to CJ21 For This Useful Post:
neolitic (03-06-2010)
Old 03-06-2010, 09:24 PM   #6
One Life so Live It
Tonyeo's Avatar
Trade: Handyman
Nice work, but No soffit vents ?
Tonyeo
I only ask because I want to know
http://www.whitebearhm.com
Tonyeo is offline
Old 03-06-2010, 09:35 PM   #7
CJ21's Avatar
The house never had any soffit vents. This is and old house.
CJ21 is offline
Old 03-06-2010, 09:48 PM   #8
seifconst's Avatar
Trade: Frame to Finish and Concrete
Well done CJ. Hope your future is bright. Nuttin like practicing on dad's house, huh? Ever consider installing gutter apron (called EE edge round here) to help shed the water past the newly installed fascia? It would greatly extend the life of what you've just done.
Seif
A smart guy won't say anything and a dumb guy don't know the difference!
seifconst is offline
Old 03-06-2010, 09:49 PM   #9
topsail's trimcat
woodworkbykirk's Avatar
is the fascia back primed or shellac'd?
woodworkbykirk is offline
Old 03-06-2010, 09:59 PM   #10
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
I bet pops is happy.
If you pre-prime the material it will look better and last longer.
Gus Dering is online now
Old 03-06-2010, 09:59 PM   #11
CJ21's Avatar
You is talking about eave tin that goes around the edges? I usally dont back prime my fascia.
CJ21 is offline
Old 03-07-2010, 06:49 PM   #12
seifconst's Avatar
Yes. It transitions water from the shingles' edge either into the gutter or past the fascia board.
Old 03-11-2010, 06:36 AM   #13
Dpscott's Avatar
Trade: Builder
Thats a reason for early failure. Go ahead and take shortcuts, I make a living it seems like fixing others shortcuts. Its best practice to seal all 6 sides espically on pine.
Dpscott is offline
The Following User Says Thank You to Dpscott For This Useful Post:
pinwheel (03-11-2010)
Old 03-11-2010, 11:53 PM   #14
CJ21's Avatar
I will back prime the next time.
CJ21 is offline
Old 03-12-2010, 11:17 AM   #15
mmike032's Avatar
Trade: trim carpentry
did you square but the facsia and 1x2?
mmike032 is offline
Old 03-12-2010, 01:47 PM   #16
CJ21's Avatar
I cut em on an angle.
CJ21 is offline
Old 03-15-2010, 01:07 PM   #17
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Looks good. Few things to keep in mind next time. Prime the back of fascia and soffit. Use eaves flashing. Just because it didn't have soffit vents before doesn't mean you couldn't add them in and vent the roof while you're at it. You could always do that later if you had spare time. Make sure you caulk every last joint. Not bad at all. Got the carpentry part looking good.
William James is offline
Old 03-16-2010, 08:38 PM   #18
D.Foster's Avatar
Trade: Carpentry & Remodeling
Prime before you caulk, and you may want to slip in some drip edge...
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 03-17-2010, 05:51 PM   #19
CJ21's Avatar
Who ever did the roofing never install drip edge, I will back prime the next time.
CJ21 is offline
Old 03-18-2010, 12:43 AM   #20
stp57's Avatar
Trade: carpenter/ handyman
Nice job CJ.
Steve
stp57 is offline
Went to work for a"framer" today rick0913 Framing 49 07-28-2009 12:18 AM
Haunted house Michaeljp86 General Discussion 7 06-20-2009 01:49 AM
Custom Trim jfrench General Discussion 11 04-12-2009 09:44 PM
House in Disarray need help Chris22298 General Discussion 21 03-29-2009 04:06 PM
house alarm in trailer cooks Low Voltage 7 10-24-2008 09:59 AM
