Trade: carpentry
I Need A Fix
I just finished hanging the boxes on a built-in entertainment center. When I went back this weekend to do the face frames and trim, I found that a small section of the plywood had delaminated. I tried to feed some glue into the gap, cauled it with a scrap of melamine, and clamped it up for a few hours. That took care of most of the problem, but now I can feel a couple of little wrinkles and a couple of splits in top ply.
I really don't want to pull and rebuild the box, and the face frame doesn't give enough clearance to pop a thin sheet over the entire damaged face, so I'm looking for a good fix. Unless someone has a better idea, I'm planning on hitting the whole area (around 6"x6") with wood filler, then sanding the whole thing smooth. A second layer of wood filler, more sanding, and done, no? I guess, in the absence of someone here having a better approach, I'm just looking for any tips, tricks, and/or product recommendations from the deep end of knowledge and experience pool here. The finish is paint, not stain. Thanks for any help you can offer. Jeremy |
Trade: Remodeling - Carpentry
Re: I Need A Fix
Your idea should work if you are painting it.
Trade: Finish Carpenter
Re: I Need A Fix
Personally, I would make new boxes. Why put something in that you are seeing problems with already?
Re: I Need A Fix |
Trade: carpentry
Re: I Need A Fix |
Trade: Trim & Finish
Re: I Need A Fix
You could try slicing the veneer where its detached with an exacto k nife. Wick in some thin glue through the slit, chair doctor or (cyanoacrylate sp) and then clamp it up. My solution to most problems like this always seems to be 2P-10 lately.
Scott |
LRG WoodCrafting
Re: I Need A Fix
My guess is it is a Chinese import plywood. It is notorious for delamination and changing shape when cut. It is effectively junk. You get what you pay for.
If this was in your own home, you could let it fly. But in a clients house, you need to get it out. This is your reputation, your business, your livelihood. If after the job is done and months down the line this think implodes and starts to fall apart nothing good will be said about you/your company. Take care of it now. It will only be in your best interest.
Re: I Need A Fix |
#9 | |
Re: I Need A FixQuote:
I agreeo with Leo. |
Code Nerd
Trade: Historic Preservationist / Furniture Maker
Re: I Need A Fix
^agreed....sorry dude
Trade: Finished /Remod/Decks/ done it all /whatever pays
Re: I Need A Fix
Paid for domestic but the retards loaded import.(my buddies "great" idea to try a new supplier
![]() Chinese plywood.
