How To Trim An Arched Window
Old 06-25-2010, 12:46 AM   #1
Hardly Working's Avatar
Rewards Points: 808
I got a side job doing trim on a unfinished house but the trouble is that I haven't had to do an arched opening. The trim is to be MDF 2 1/4 ogee Base/Case. What would be the best way to try to bend it. Thought about relief cutting the bottom which would become the top to create a fan. Suggestions please.
How to trim an arched window-100_5840.jpg   How to trim an arched window-100_5850.jpg
Hardly Working is offline
Old 06-25-2010, 02:40 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Re: How To Trim An Arched Window
Check trimster.com to see if they have a profile that will work for you. If you are trying to match an odd ball custom trim it can be time consuming and a royal PITA. Hopefully one of the pro trim guys may have more current info & will jump in here.
griz is offline
Old 06-25-2010, 05:20 AM   #3
DREAM1's Avatar
Trade: G/C
Rewards Points: 25
i wouldnt even do a trim id return the drywall right to the window and be done.
DREAM1 is offline
Old 06-25-2010, 05:34 AM   #4
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,028
use flex trim. lay it out on the floor over night and let it "rest" to its arch shape
festerized is offline
Old 06-25-2010, 05:58 AM   #5
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
We always get our arched casings made by a custom millwork shop. You may be able to make your own out of sheet goods and put your own profile on it.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
SK Remodeling (06-25-2010)
Old 06-25-2010, 07:21 AM   #6
BillD's Avatar
Trade: General contractor
Rewards Points: 342
In my opinion you have two choices in order to do it right. Both were already spoken to in previous posts. Have it made to match or get flex trim.
Bill
BillD is offline
Old 06-25-2010, 07:28 AM   #7
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 812
just make it yourself, don't try and bend it, just get a wider piece and draw the arch then cut and router it. I've made many arch pieces. one time I had to make a large one and used two pieces of the trim specified and ripped alternating pieces (to make up for the saw cut) and glued them all back together in the arch. It was getting painted so you never saw the pieces. Had to do that twice in the same house, one bigger than the other.
dave_dj1 is offline
Old 06-25-2010, 09:05 AM   #8
SK Remodeling's Avatar
Trade: residential remodeling contractor
Rewards Points: 244
Yea you can just give them the radius of the arch and they will make one for you.
SK Remodeling is offline
Old 06-25-2010, 10:20 AM   #9
keith mathewson's Avatar
Trade: carpenter
Rewards Points: 416
It is a single point radius trim. The jamb would be simple to make. What's the profile of the molding?
How to trim an arched window-dscf1847.jpg   How to trim an arched window-dscf1845.jpg
keith mathewson is offline
Old 06-25-2010, 11:34 AM   #10
dprimc's Avatar
Rewards Points: 590
I tried using a piece of pvc trim for a similar window a few years back. With some effort, I got it to make the curve. The first nail caused it to explode into a million pieces. Really scary.
Started over with flex trim after learning what didn't work.
dprimc is offline
Old 06-25-2010, 02:43 PM   #11
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 1,388
Go to Home Chepo all thier Trim has a bend just like the Window!
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty"
- Thomas Jefferson-
http://www.savingtherepublic.com/Main.html
Snobnd is online now
The Following User Says Thank You to Snobnd For This Useful Post:
Cole82 (06-25-2010)
Old 06-25-2010, 03:40 PM   #12
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
Send a message via MSN to KennMacMoragh
You just need one of these
Leo has a thread on curved moldings you might want to look at http://www.contractortalk.com/f13/cu...oldings-74133/
Personally, I would not attempt it myself. I would refer them to someone who does custom millwork, you want them to have it done the right way.
kenparsonscontracting.com
KennMacMoragh is offline
Old 06-25-2010, 04:09 PM   #13
Framer53's Avatar
Trade: Handyman
Rewards Points: 254
Get a hold of the window supplier, they will hook you up!
Framer53 is online now
Old 06-25-2010, 05:26 PM   #14
KemoSabe
loneframer's Avatar
If you're bending PVC trim, you should use a heat blanket to soften it enough to make the curve, or make it out of sheet goods, like I do.
How to trim an arched window-005-copy-8-.jpg   How to trim an arched window-005.jpg   How to trim an arched window-041-1.jpg
Old 06-25-2010, 05:34 PM   #15
KemoSabe
loneframer's Avatar
Here's how I do them. Just a router and a home made base for the router. I've done wall plates with 3/4 plywood the same way. 16' radius is the largest I've done so far. Just have to extend the base using 6" wide rips of plywood.
How to trim an arched window-006-copy-2-.jpg   How to trim an arched window-006-5-3.jpg   How to trim an arched window-003-7.jpg
Old 06-25-2010, 05:40 PM   #16
What about the interior Lone?
Old 06-25-2010, 05:49 PM   #17
KemoSabe
loneframer's Avatar
On curved trim, we usually get it made at a custom millwork shop. Just have to give them the radii and a trim sample.
I did make a few casings in my own house, very much like the window in the opening post, but I used sanitary trim throughout.
I apologize for the quality of the pics,. I had the wrong film in the camera. These were taken the day I sold the house.
How to trim an arched window-033-2-1.jpg   How to trim an arched window-035-2-1.jpg
Old 06-26-2010, 02:33 AM   #18
Rewards Points: 808
I wondered why they didn't order a trim kit with the window.
It's just a single ogee I might attempt to make it. Flex trim dose sound like it would work. I'll do that window last but will have to address it first with the HO to figure out which way he wants to go. Oh and he needs to rent the scaffolding for me to put it in too. Thats not going in off a ladder thats for damn sure.
Old 06-26-2010, 10:39 AM   #19
KemoSabe
loneframer's Avatar
Here's a video of cutting radii with a router. I only used one radius on this setup because the inside curve was the only one that mattered. You can use as many center lines as you want and change bit profiles to flute the trim, etc. These were being used to make bending forms for drywall, so I whipped them out pretty quickly.
+ YouTube Video
http://www.youtube.com/watch?v=f-uZRuz4P0I
Old 06-26-2010, 10:43 AM   #20
KemoSabe
loneframer's Avatar
Here's where the got used
I also made some ramps to bend an arch across the sheets, using a combination of the router for the radius and a Skilsaw to make the straight cut.
How to trim an arched window-002.jpg   How to trim an arched window-004.jpg   How to trim an arched window-001.jpg
Need some guidance with operable sunburst window shutters supermankd Finish Carpentry 3 07-05-2012 08:58 PM
New Vinyl window for sale - HALF PRICE - $91 (Glenview) Grumpy Contractor Swap 0 10-13-2009 12:49 PM
Windsor One exterior trim allenmar General Discussion 1 08-13-2009 12:05 PM
Reno Window Screw Up Bummie Windows, Siding and Doors 15 12-22-2008 10:33 PM
Screwing aluminum trim to window. Patrick Windows, Siding and Doors 27 07-08-2008 04:44 PM
