How I Handle Stock Not Being Long Enough.
One of my personal pet peeves is having to splice wide crown molding. I'm milling 5" crown for my new house & have a 19x15' room & only have 14' stock. Here's my board stretcher.
Re: How I Handle Stock Not Being Long Enough.
Tried paying attention to grain orientation. Hopefully stain color will take as well from board as the grain did.
Getting ready to head to the shop & run the glued stock through the molder. I'll update this thread with finished crown. |
Trade: Cabinets and doors
Don't hit the screws
No board stretcher at your shop? That was the first tool I bought
Trade: contractor
wouldn't a miter with similar grain selection produce the same result? (except be 10 times faster)
#6 | |
Re: How I Handle Stock Not Being Long Enough.Quote:
A miter will eventually open up, a glued finger joint won't. I'm gonna be in this house for the rest of my life, I don't want to be looking at an open joint & having to add it to my to do list that I will never get around to. ![]() BTW, all screws will be removed prior to going through the moulder. |
Re: How I Handle Stock Not Being Long Enough. |
| The Following User Says Thank You to pinwheel For This Useful Post: | genecarp (03-18-2010) |
LRG WoodCrafting
Did you get the blue one or the orange one? I find the orange one works better on hardwoods
It would look the same initially, his system will be MUCH less likely to open up in the future, GMOD
Trade: Cabinetry and trim
There's a lumber yard around here that puts zipper joints in long runs of trim. They'll make up to 24' runs and even attempt to match the grain and color.
Lunch time. Just got in from milling 180' of the 5" crown. 110' of cherry & 70' of cypress. Now I gotta go back & start hand sanding after lunch.
![]() Didn't come out to shabby & I'm pleased to say, none of the pocket screw holes came through the face. I was honestly a little worried about having more holes to fill. Just wish the moulder done a better job of chip collection. Always have a big pile to sweep up when I'm done. Hopefully next weekend I can get start trimming out the house. Momma's gonna be so happy. |
LRG WoodCrafting
What do you have for dust collection. That machine needs about 500-800 cfm
Mickey
Trade: residential remodeling
When I was going to tech school in Building Construction, we did all the remodeling of the buildings for the other departments. It was an old government installation and all of the buildings needed work. One day a guy cut a board too short and the instructor got really ticked. You would have thought he was personally buying the materials, anyway he tells the guy to go to the maintenance guy to get a board stretcher. Off he went and when he found the guy and told him what he needed. The guy played along and told him that he had left that tool somewhere and sent him off again to find it. Finally, when it was time for class to be over for the day, he comes back and says that he couldn't find it anywhere. The instructor threw up his hands and walked off, and one of us told him there was no such thing as a board stretcher.
I always learn more by listening that I do by talking. |
#14 | |
That's not the problem. I'm running 2 hp, 1550 cfm dust collector with nothing else hooked up. It's dedicated to my moulder or planer, depending on which one is rolled into the alley. It's the big chips that tear out from the initial pass that don't get picked up well. Running this 180 of trim filled a 55 gallon barrel & the dust collector. Barrel is staged in front of the dust collector. |
Time Traveler
Trade: Home Reno's and Millwork
The other item which is useful in the shop is a sky hook.
BTW I like your set up, did you use the pocket screws till the glued dried or did you put them in the meat and hope you did not hit them? |
Trade: general contractor
#17 | |
Trade: Remodeling contractor
Question and/or critique......it looks like the pocket holes are too close to the butt which leaves very little meat on the male end. Any concerns with that? Nice post BTW.
Back in Maine Dubbin' Around Doin' good stuff ...... |
#18 | |
LRG WoodCrafting
#19 | |
It just looks like the pocket screws are close to the end, but what you don't see is the fingers. That's on the male side of the finger joint & there was plenty of meat for the screw head to hold. The screws sucked the joint together very nicely. |
#20 | |
| roofer problems - long but need advice, thanks | anon | Roofing | 2 | 12-12-2009 12:04 PM |
| New From Long island | HOCKA | Introductions | 2 | 11-11-2009 04:55 PM |
| finish work/ how long | propertyone | Finish Carpentry | 25 | 11-07-2009 07:40 AM |
| New member from long island NY | bellapaint | Introductions | 4 | 09-24-2009 09:59 AM |
| How long to build a house? | Bender | General Discussion | 94 | 02-10-2009 11:55 PM |
