How Do I Cope For An Obtuse Angle?
Old 01-05-2006, 08:39 PM   #1
karma_carpentry's Avatar
Trade: carpenter
Okay, I searched these forums (and also did a Google search) and didn't get a quick answer... so...
Tomorrow I need to cope a basecap into a 121 degree obtuse angle. In a normal new construction, I would bisect the angle and butt the pieces to each other, but I'm running into existing basecap and don't want to pull it off, cut the angle, and replace it. I thought I'd cope into it.
Trouble is, I never coped into a wide angle, just into the near-90 inside corners. So is there a special way? I figured I'd cut the initial miter for the cope to 1/2 the angle and cope to that, angling the cut especially backward, rather than the 5 or 10 degrees I normally do for an inside 90. I figure you don't cut a 45 miter and expect that to fit.
Does this sound right?
I want to do it to learn the technique. If it doesn't look good, I'll just pull of the old molding and miter it.
Build on a good foundation.
karma_carpentry is offline
Old 01-05-2006, 09:25 PM   #2
Tom R's Avatar
Re: How Do I Cope For An Obtuse Angle?
Yes, - - you are correct, - - just cut your miter at 29 1/2 degrees and 'back-cut' much sharper when you cope. Also you can cheat a little (well, a lot) by nipping off some of the corner of your 'existing' piece.
http://www.tr-built.com
Tom R is offline
Old 01-06-2006, 07:07 AM   #3
Trade: carpenter
Thanks, Tom. That's what I suspected, but I have no experience behind it. I'll give it a shot and see how well the cope will mesh into the old piece.
Old 01-08-2006, 11:25 AM   #4
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
paint grade, or stain grade?
Real nice guys
King of Crown is offline
Old 01-09-2009, 07:10 PM   #5
rick grippo's Avatar
Trade: comm and res interiors
how can i find out what the obtuse angle is on stairwell picture frame moulding???
rick grippo is offline
Old 01-09-2009, 07:35 PM   #6
Jeremy E's Avatar
Trade: carpentry
Uh... protractor?
Jeremy E is offline
Old 01-09-2009, 08:41 PM   #7
Handle It!
MALCO.New.York's Avatar
This would be the perfect opportunity to start a NEW THREAD. First in "Introductions", then in "Finish Carpentry"!
Bevel and angle gauge for an existing.
Calculating for a new set is different!
Ultimate Wisdom---------
MALCO.New.York is online now
Old 01-10-2009, 01:01 AM   #8
President of the world
world llc's Avatar
Trade: general contractor
to continue off topic.... i always use a level and speed square
world llc is offline
Old 01-10-2009, 02:17 AM   #9
Handle It!
That only works is someone knows how to use a Swanson!!!
+ YouTube Video
http://www.youtube.com/watch?v=jh04yCYGPTA
But it is OBTUSE and a speed square only goes up to 90!!! Help!!!
Figure it out!!
Old 01-10-2009, 08:40 AM   #10
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
I did see that right, didn't I?
I have been using a speed square wrong for almost 30 yrs.
It seems I am supposed to make a tick mark at the needed angle and connect the dots.
Darn it! I hate it when I'm wrong like that
Do you ever think you should have your own tv show?
Gus Dering is offline
HELP - Transition at angle between floor and carpet rajrajput Flooring 1 07-19-2007 08:40 PM
Brick Veneer on steel angle iron sandyman720 Construction 9 07-15-2007 05:20 AM
Advice on mounting Steel angle irons. turbomason Masonry 12 03-04-2007 12:47 AM
miter angle settings please ..... Vermonster Finish Carpentry 10 02-05-2007 08:13 AM
bosch angle finder, chestnut clamps summertime Tools & Equipment 9 09-27-2006 05:59 PM
