Hidden Wainscot Door Solutions
Old 04-08-2012, 01:52 AM   #1
StrongTower's Avatar
Trade: Finish Carpenter
Rewards Points: 1,234
Hey guys, I have a hidden door to do in a home office. New constuction, I'm paneling it as we speak. 13.5 ceiling height, superior alder, rabbeted panel moulding to flat panels. The door is basically a 2/8 - 8/0 that needs to mimic an upper/lower panel, carry the rails, base, & chair rail, while closing seamless. Problem is, it's an outswing door. We were thinking of 3/4 ply (reinforced on back with some type of strong back), with the panel moulding covering the reveal. Scarfing the chair, base, & rails at 5 degree for clearance. Any opinions on hardware that would take the door out & away from face frame and not bind on hinge side? Euros for a rabbetted door don't look like they will work.
StrongTower is offline
Old 04-08-2012, 05:09 AM   #2
CSinMa's Avatar
Trade: more Pro than Con
Rewards Points: 75
Re: Hidden Wainscot Door Solutions
We use concealed Soss hinges and we incorporate the base with the door and put rolling casters hidden behind the base for this type of application. This allows little weight on the hinges themselves and the door opens and closes flawlessly.
I've seen it done once from a distance !
CSinMa is offline
Old 04-08-2012, 07:24 AM   #3
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Ditto that. The ones I've done I used sos hinges.
katoman is offline
Old 04-08-2012, 07:35 AM   #4
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Never seen those soss hinges before. Cool stuff!
ohiohomedoctor is offline
Old 04-08-2012, 08:28 AM   #5
Dan_Watson's Avatar
Rewards Points: 2,466
Agreed on the hinges.
And I thought I was a workaholic...after midnight on Easter morning.
Dan_Watson is offline
Old 04-08-2012, 09:16 AM   #6
After looking at Soss's website, doesn't look like it would clear the added moulding or even the rabbeted panel moulding. Essentially this door is like a rabbeted kitchen cabinet door. The hinge need to push the door out and away from frame. Was originally thinking a piano hinge, since the barrel would be hidden behind the rabbet. I'll draw it up on sketchup for a visual.
Old 04-08-2012, 10:00 AM   #7
Friend's Avatar
Trade: cabinets and green building
Rewards Points: 160
try this http://www.youtube.com/watch?v=4jw6V...Q2STefpypwP1WY
Friend is offline
Old 04-08-2012, 10:00 AM   #8
CSinMa's Avatar
Rewards Points: 75
You may find a rabbeted door "leaf hinge" for the application you are looking for.
CSinMa is offline
The Following User Says Thank You to CSinMa For This Useful Post:
StrongTower (04-08-2012)
Old 04-08-2012, 10:06 AM   #9
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
inset euro hinge
world llc is offline
The Following User Says Thank You to world llc For This Useful Post:
Old 04-08-2012, 01:25 PM   #10
Tried the inset euro hinge, even the zero clearance 270. Will keep looking. Thanks for replies.
Old 04-08-2012, 01:37 PM   #11
world llc's Avatar
how about that sketch up drawing...
Old 04-08-2012, 01:37 PM   #12
katoman's Avatar
Trade: carpenter
Go with the Soss hinges. Re-design/configure so they will work.
katoman is offline
Old 04-08-2012, 02:52 PM   #13
Dan_Watson's Avatar
http://reversica.com/products.html
The Following User Says Thank You to Dan_Watson For This Useful Post:
Old 04-08-2012, 03:57 PM   #14
Dan- that's looking more like it. Definetly would work, that range of motion is awesome. Almost done with sketchup drawing.
Old 04-08-2012, 06:37 PM   #15
Really looking like the hinges for a lazy Susan base cabinet will work.
Old 04-09-2012, 01:24 PM   #16
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,344
Soss hinges are fantastic, used them once for a hidden door and they worked great.
SuperiorHIP is offline
Old 05-09-2012, 09:47 AM   #17
jlord's Avatar
Trade: Remodeling, Finish, Cabinets
How about Blum 155 Zero Protrusion hinges. They push the door out as it opens.
jlord is offline
Old 05-09-2012, 10:01 AM   #18
J F's Avatar
So, op....whaddya end up doin'? Got pics?
J F is offline
Old 05-11-2012, 12:17 PM   #19
Giving it my best
RS Sam's Avatar
Trade: Cabinet Maker and Residential Remodeler
Rewards Points: 512
Rixson pivots are another option. You need to design the trim overlay so that on the pivot side the trim that covers the reveal is fixed to the wall and the other side overlays the wall. Both the Rixson and the Reversica will reduce the walk through space by, at the very least, the thickness of the door as the door stays in the opening. The head casing is always a trick and so different solutions to different configurations. Here is one link for one type of Rixson pivot http://www.epivots.com/rixson-370.as...FUJo4Aod-m4KDg
I can give you more info if you need, but go to the Rixson site for the specs.
... and it just happens that today Gary Katz has reposted an article about installing a hidden bookcase at http://www.thisiscarpentry.com/2012/...bookcase-katz/ Not exactly what you are doing but a good explanation of using a Rixson Pivot for a hidden door.
Grace is bestowed upon the soul - not upon the ego.
RS Sam is offline
Old 05-14-2012, 10:16 PM   #20
We ended up using 170 hinges. To make the chair rail, base, & shoe work, had to cope a 45 and drill out the rail behind the molding to clear. It was a necessity, couldnt get it any better. Haven't been back out there since one of the guys finished the base. Hopefully get out there for some pics.
Hidden hinges for traditional cabinet doors Panzer5 Finish Carpentry 6 06-13-2012 06:30 PM
Hidden Shelf Brackets HitchC&L Finish Carpentry 4 12-22-2011 06:40 AM
Another Hidden Deck Fastner greg24k Decks & Fencing 7 04-22-2011 08:02 AM
blum hidden hinges Smittyswoodshop General Discussion 2 11-01-2010 07:40 AM
Hidden under cabinet switches dkillianjr Electrical 13 01-29-2010 09:45 AM
