Here Are Some Interesting Crown Moulding Intersections
Old 01-16-2010, 03:31 PM   #1
MarcP's Avatar
Trade: Carpenter/Cabinetmaker
Rewards Points: 117
Pretty tricky!
Here are some interesting crown moulding intersections-img_0827-desktop-resolution-.jpg   Here are some interesting crown moulding intersections-img_0826-desktop-resolution-.jpg   Here are some interesting crown moulding intersections-img_0831-desktop-resolution-.jpg
MarcP is offline
Old 01-16-2010, 03:40 PM   #2
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Re: Here Are Some Interesting Crown Moulding Intersections
Looks like an afterthought or build as you go.
skyhook is offline
The Following User Says Thank You to skyhook For This Useful Post:
rselectric1 (01-16-2010)
Old 01-16-2010, 03:53 PM   #3
bodean614's Avatar
Trade: Carpentry/cabinetry/ estimating
Rewards Points: 91
I would have filled in at the bottom of crown with a block the same thickness as the head pc
bodean614 is offline
Old 01-16-2010, 03:53 PM   #4
Mellison's Avatar
Trade: Home Improvement General Contractor
"Interesting" is one way to describe it.
I think it would have been easier and look better if the recessed areas were built out to meet the rest of the wall.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Old 01-16-2010, 04:12 PM   #5
MarcP's Avatar
Rewards Points: 117
You guys are wrong. You need to see in person then. It doesn't look right when blocking is nailed to the wall to bring the crown onto the same plane.
MarcP is offline
Old 01-16-2010, 04:15 PM   #6
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,016
Send a message via Skype™ to ChrWright
It took some skill to put them in that way... but it does look a little strange.
Christopher Wright, CR: President @ WrightWorks, LLC
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
The Following User Says Thank You to ChrWright For This Useful Post:
skyhook (01-27-2010)
Old 01-16-2010, 04:21 PM   #7
Mellison's Avatar
Perhaps when it's painted.
I have been wrong before.
Mellison is offline
Old 01-16-2010, 04:31 PM   #8
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
I agree that it took some skill to install it that way.
Still looks distracting to me. The second pic is symmetrical and looks better than the first.
I would have played with extending the head pieces into the corner.
The truth is that the detail looks great so long as the doors have the room from the corners for the large crown to return clean. I just don't think there is a great way to pull it off otherwise.
All that said the pictures are interesting.
Gus Dering is offline
Old 01-16-2010, 04:35 PM   #9
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,460
It looks like a mess, a tricky mess none the less.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 01-16-2010, 04:41 PM   #10
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
I understand the concept behind the detail, but it looks very awkward to me. It definitely looks like something was missed in the planning stage. In order for the crown to flow properly, the windows need to be pulled from the corner far enough for the molding to clear itself throughout all the transitions. Either that, or they needed to be closer to the corner, so that it could appear to be "built into" the corner, without the crowded transition. However, very nice workmanship.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
WNYcarpenter (01-16-2010)
Old 01-16-2010, 04:53 PM   #11
bconley's Avatar
Trade: Kitchen and bath design+remodel
The way I have addressed that problem is to run a band the same size of the head piece all the way around the room.
bconley is offline
Old 01-16-2010, 05:06 PM   #12
Mellison's Avatar
More work, more money and a finished look.
A win win.
Mellison is offline
The Following User Says Thank You to Mellison For This Useful Post:
bconley (01-16-2010)
Old 01-16-2010, 05:06 PM   #13
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
These are "no win" situations... since the window locations and trim sizes were not planned, you end up doing the best you can.
Some of the most challenging work I've ever done was really just due to a lack of planning.
I think the best compromise is to run the crown straight into the corner, but not the head casing, instead you slip a filler block in to fill the void behind the crown in the corner.
Doors and windows in corners work best if you use casing large enough to meet in the corner. A related problem is not enough room for a full casing. Here is pic of a corner where half a casing meets on each side of the corner, so it looks like a full casing folded into the corner. The other issue in this photo is different height doors.
Cheers,
Bass
Here are some interesting crown moulding intersections-different-ht-doors.jpg
basswood is offline
Old 01-16-2010, 05:09 PM   #14
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
someone should have caught that detail problem long enough beforehand to figure a more pleasing transition.
That could have been the most complicated piece in the house to assemble, and it's nicely done, but it looks an "Oh, Sh!t!"....
We run into that when the HOer or designer changes trim details mid-stream. Don't take offense.....
we don't always know the circumstances involved, just what we can see from the pics!
WNYcarpenter is offline
Old 01-16-2010, 06:55 PM   #15
MarcP's Avatar
Rewards Points: 117
There is no doubt that it would look cleaner if there was the proper amount of room for both sides of the returns in the corners. But I'm telling you, we tried a mock up of running the crown into the corners with "filler blocks" to bring the crown on the same plane as the heads, it just looks "unbalanced" with a proper return on one side and no return on the other side. To each his own I guess.
The funny thing about the lack of thought about window placement though is this. This is over a 4 million dollar house in Westport, CT and the builder is too cheap to get any kind of interior trim detailing from the architect. All the trim is an "after thought". It does come down to, here it is, make it work!
MarcP is offline
Old 01-16-2010, 07:17 PM   #16
Artisan Carpentry
basswood's Avatar
Hi Marc,
That was a difficult position to be in and you did some challenging work and did it well. There are other ways to do it too. Your mock up may have looked odd, but so do the pics you posted... no easy way out.
I've done it both ways. Here is the other approach (look at the last two photos):
http://forums.finehomebuilding.com/b...-capital-crown
Cheers,
Bass
basswood is offline
Old 01-16-2010, 07:23 PM   #17
Lack Of All Trades
Darwin's Avatar
Trade: Construction & Home Improvement Services
Pretty tricky!
I see you removed that vertical piece in the first picture and corrected that cluster****. Looks to be about a 1X4 undera th' paint. Good job.
Darwin is offline
Painters and crown moulding... The Invetor Painting & Finish Work 7 01-02-2010 08:41 AM
crown moulding mnjconstruction Finish Carpentry 42 03-25-2009 04:05 PM
Crown moulding question davinci Carpentry 14 02-21-2009 09:54 PM
Fypon Crown moulding brailediver Finish Carpentry 17 01-30-2009 08:21 PM
pricing crown moulding boydbuild Finish Carpentry 15 12-19-2008 09:12 PM
