Help With A Built In
Old 02-26-2009, 11:58 PM   #1
Carpenter/Finisher
john5mt's Avatar
So i backed myself into a corner
i have this built in for a flat screen. All the boxes are built and attached to the wall and now it is time to attach some face frames. My plan is to use biscuits in the edges of the plywood and i dado-ed an appropriate groove in the back of the face frames to fit onto the biscuits. i am positve the glue and biscuits will hold it once it is attached but my dilemma is in how to clamp it properly while the glue sets. Typically with cabinets you would clamps to the back but being that it is all built and attached i cant do that. Any ideas? I dont want to use any nails in the face or have to put plugs in pocket screw holes.
I suppose this is one of those "he who fails to plan, plans to fail" moments
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Old 02-27-2009, 12:07 AM   #2
Carpenter/Finisher
john5mt's Avatar
Re: Help With A Built In
1st Gen tradesman
john5mt is offline
Old 02-27-2009, 12:24 AM   #3
MRstark44's Avatar
ever used miller dowels? i've had great luck with them.
also, i love the look of using a walnut plug on the face of a cabinet like that. gives it some character when done right. (cant use to many, must be spaced out appropriately)
MRstark44 is offline
Old 02-27-2009, 12:50 AM   #4
m1911's Avatar
Trade: trim carp
Pin some temporary 1x blocks to the plywood sides just behind the face frame and use clamps to clamp the face frame to the blocks until the glue sets.
m1911 is offline
Old 02-27-2009, 01:12 AM   #5
dkillianjr's Avatar
I like that idea. I don't have a pinner, but I would assume you could remove them rather easily.
Heres another idea John. How about something like this 3 way clamp? They are a little pricey at 10 bucks a pop. Maybe you could just pick up a couple and do parts of it at a time, im not sure what kind of time frame your working with. http://www.amazon.com/Adjustable-Cla.../dp/B00080QF56
dkillianjr is offline
Old 02-27-2009, 01:17 AM   #6
m1911's Avatar
Trade: trim carp
I was going to suggest the face clamps, but I assumed he did not want to invest in a bunch of clamps. Just nail some blocks with 18ga 1-1/4" brads, you wont see the holes once the face frame hides them. If you have enough c clamps you can clamp the blocks to the cabinet, and clamp the FF to the blocks with a second clamp.
m1911 is offline
Old 02-27-2009, 06:09 AM   #7
General Contractor
greg24k's Avatar
If you have a 23 gage pin nailer, it works best in such cases.
greg24k is online now
Old 02-27-2009, 08:40 AM   #8
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
I have never tried this but....
If you want no nail holes to fill at all, on the frame or boxes.
What if you popped together another box about 8 -12 inches deep with about 2 or 3 partitions in it that was just tall enough to tip up in the room and the same with as your et center.
Shim and secure it in front of the frame and use it to drive shims that clamp down your frame.
Sounds like a lot of work but who knows? It might work
Gus Dering is offline
Old 02-27-2009, 10:48 AM   #9
wood is good
Sooner Pesek's Avatar
Trade: trim carpenter
John,
Is it possible that you could use pipe clamps across the width of the entire unit in 3 or 4 places , then shim between the clamps and your faceframe to hold in place?
This will only work if the FF is pre assembled as one unit.
This is similar to Gus's idea and you can re-use pipe clamps.
Roger
"SKILLED Carpenters aren't CHEAP , CHEAP Carpenters aren't SKILLED " --- saw this on a t-shirt a while back ---
Sooner Pesek is offline
Old 02-27-2009, 02:56 PM   #10
Carpenter/Finisher
john5mt's Avatar
Sooner that is a really good thought. I may add that to my plan of attack.
1st Gen tradesman
john5mt is offline
Old 02-27-2009, 03:32 PM   #11
Gus Dering's Avatar
I like the pipe clamp idea too.
You may have problems in the areas that don't have a continuous horizontal box part though.
Seems like the box will flex in too much.
But it wouldn't hurt to give it a dry run and see what happens
Old 02-27-2009, 03:46 PM   #12
I have a pair of the face frame clamps
with no-mar jaws, that I bought locally.
The ones like killian posted work easier
if you can hot glue some shelf liner or
something to the jaws.
Even when the cabinets are laying down
it seems like I never have enough hands
to juggle the clamps and blocks to keep from
leaving "smilies."
neolitic is offline
Old 02-27-2009, 03:57 PM   #13
I like Green things
WarnerConstInc.'s Avatar
Get yourself a pin nailer just for these situations.
WarnerConstInc. is online now
Old 02-27-2009, 03:59 PM   #14
RED HORSE 554's Avatar
Trade: Project Manager and Builder
chamfer strips glued on the blind side of the face frame and then blind screwed and or nailed to hold inplace until the waffers and thier glue dries It would be nice if the face frame could be togeather and installed as a unit then the total of the face frame would allow the chamfer strips to be pressed in tightly wile fastening
RED HORSE 554 is offline
Old 02-27-2009, 06:27 PM   #15
Platinum8's Avatar
Trade: Finish carpentry and Painting
I know someone mentioned the face frame clamps. They have edge clamps out there that have some pads on them so they don't damage the suface or edge. Again, i don't know if you wanna drop any money on them but its a good investment. hope it helps
good luck.
Platinum8 is offline
Old 02-27-2009, 07:42 PM   #16
billy d's Avatar
Trade: carpenter
John I bought some attachments that go on a clamp to turn it in to a three way clamp I used them once.the pressure that I put on them pulled the clamps right out.Something I have used it may sound crazy but it worked for me was the one hand clamps.I cut up a bike inner tube slide one end over one end of the clamp,clamped it on the the face and pulled the inner tube on the top and then clamped it again.
Went along the face with a block and a hammer and banged them ,the inner tube is under pressure all the time so pulls it in.Once every thing is going you can go back to the start and pull the inner tube even more to get more pressure on the clamps.I know it sounds crazy but it has worked for me.Good luck, billy.
billy d is offline
Old 02-27-2009, 10:20 PM   #17
Gus Dering's Avatar
That is worth a shot. Good idea
Old 02-27-2009, 11:30 PM   #18
catawba's Avatar
Trade: res. construction
John5mt here is a way to clamp with as many c-clamp's as you need or can get your hands on , when attaching the clamp just make sure you use a block thick enough to get the radius corner of the clamp far enough from the face frame that it doesnt make clamping pressure uneven.
catawba is offline
Old 02-28-2009, 09:53 AM   #19
Gus Dering's Avatar
Another great idea
I wish I thought of that
I will use that one at some point, great tip. Drawing is a bonus
Old 02-28-2009, 12:16 PM   #20
Deicide1's Avatar
I came in too late because that's what I was going to say.
Either do what this guy says, or use a bar clamp in the same manner.
Deicide1 is offline
Want to build own home, or have shell built and finish myself, some questions... Little Carpentry 18 03-11-2009 10:30 PM
Built In RizzoMaryland Carpentry Picture Post 30 12-30-2008 05:01 PM
Deck Built Despite The Snow! DecksEtc Decks & Fencing 20 12-05-2008 07:53 AM
Glass Doors For Built In KMac Finish Carpentry 6 11-20-2008 07:09 PM
Sizing built up deck beams Unforgiven Decks & Fencing 17 09-08-2008 10:03 PM
