Having A Hard Time Finding A Piece Of Casing.
Old 02-21-2008, 11:06 PM   #1
al10fred1081's Avatar
Trade: Carpentry/ Home Improvements
Its either a 3.25 or 3.5" x 3/4" ranch style casing. I opened a door up and replaced it. the trim was put on in 1968. stain grade yellow pine. I know it was 1968 cause thats what was the date on the newspaper shoved in the electrical switch box behind it where they slapped two pieces of this casing together back to back to cover a lolley column next to a door. evidently there was a draft.
The samples I have are both ripped and they look like they were probably 3.5" to start with then ripped and planed to fit the opening.
Anybody know a place I could order online or even a trimshop in south central PA that could cut it for me? Just moved up from DC area and Smoot lumber's website leaves something to be desired.....the trim will be painted and at this point I really could care less if it was MDF. I need 4 pieces of trim to wrap this job and I can't find RANCH!!!!!
Thanks,
Alex
al10fred1081 is offline
Old 02-21-2008, 11:29 PM   #2
Re: Having A Hard Time Finding A Piece Of Casing.
You sure they weren't using
base for casing?
neolitic is offline
Old 02-21-2008, 11:36 PM   #3
The ONLY way is DEAD_ON!
DEAD_ONConst's Avatar
Trade: Custom Finish/Carpenter
Anybody know a place I could order online or even a trimshop in south central PA that could cut it for me? .....the trim will be painted and at this point I really could care less if it was MDF. I need 4 pieces of trim to wrap this job and I can't find RANCH!!!!!
Thanks,
Alex[/quote]
Alex, if you can send me a small sample of the old stuff, I can mill up as much as you need! All I would need is about a 2"-4" piece of the old stuff. Doesn't matter if it is painted or not, I can strip it and match the profile in-house.
DEAD_ONConst is offline
Old 02-22-2008, 01:47 AM   #4
base for casing?
I really wish they were. ranch style base is only 9/16 thick whereas the casing is 11/16 or in 1968 evidently 3/4. but definitely casing not base and impossible to find locally.
Old 02-22-2008, 01:55 AM   #5
DEAD_ONConst unfortunately the only pieces I have have already been ripped down the backside. I replaced the exterior door after years of settling and now I need four full pieces for me to rip to get the reveal on the jambs straight. None of the stuff I have is the stuff I need. and believe it or not this is the only opening that has this trim on it. the rest is 2 1/4" unfortunatley the header piece is also a different size to match the height of the trim capping the windows next to the doors. Miters looked like s%#^ when I got there and I'm just trying to make this woman happy...been a nightmare job from the get go...
if you can copy the majority of the profile and fudge together the rest I'll go rip it off her door tonight lol.
Thanks,
Alex
Old 02-22-2008, 01:49 PM   #6
Al Smith
A W Smith's Avatar
scroll down to page nine
http://www.jjwohlferts.com/client_im...WCasing610.pdf
Al Smith
http://www.awsmith.com
A W Smith is offline
Contract Q- start time, finish time clause orson Business 37 02-04-2008 10:15 PM
Architects and time frames ultimatetouch Business 10 01-05-2008 06:57 PM
Time management, Multi-tasking for owners/principals pm_sup Business 10 12-24-2007 09:02 PM
Another lesson in the school of hard knocks A.W.Davis General Discussion 30 12-20-2007 01:43 AM
Milking time.... robins_aussie General Discussion 7 10-21-2007 01:28 PM
