Trade: carpenter/remodeling
Hardwood Over Concrete Stairs
I have concrete filled steel stringers and the owner wants to make them look like wood also have to take out steel railing and replace it with wooden rail and ballusters. someone told me they make a piece that fits over but never heard of it. Any other options would be very helpful. Thanks
chief pencil holder
Trade: Custom Cabinet Maker, Handrail
Re: Hardwood Over Concrete Stairs
Vapor barrier, next plywood, another vapor barer, then hardwood. Have fun
http://sacramentomillworks.com |
Re: Hardwood Over Concrete Stairs |
Acid stain one of the treads in Caramel, GMOD
I think I could build something that would fit the bill if that's what my client for sure wanted, but it sure wouldn't be cheap.
Bostiks best glue would hold the treads & risers in place easy enough. Would probably drill the concrete & put in wooden plugs in 4 corner points in order to temp nail the treads while the adhesive setup. |
chief pencil holder
Yes the first step is a doosie, you can slim it down a bit, but still an inch out at least. To be done properly it needs to be figured in when the stairs are built. Wood over concrete is never a good choice IMHO.
Trade: Remodel
Check out some tile that's fake/faux wood. Should be an easy remedy.
Concrete Mike
Trade: concrete
| The Following User Says Thank You to CONCRETE MIKE For This Useful Post: | genecarp (03-18-2010) |
Concrete Mike
Trade: concrete
I also like the overlay stamp system ,you can make it look like wood! The bad thing is the steel will still show.
| Polished concrete.. is it better than Hardwood ? | AcademyHardwood | Flooring | 33 | 04-27-2011 01:29 PM |
| Hardwood over concrete | RLKMarble | Flooring | 11 | 12-05-2009 06:22 AM |
| subfloor over concrete for hardwood | ssh | Flooring | 21 | 05-02-2009 01:47 PM |
| converting carpeted stairs to hardwood "framed" center runners | Scottsquared | Carpentry | 2 | 11-26-2008 11:22 PM |
| Hardwood to concrete floor, with nothing in between?? | SBI | Flooring | 7 | 08-01-2008 02:21 PM |
