Hardwood Floor And Door Jambs
Old 02-28-2009, 03:41 PM   #21
basswood's Avatar
Trade: trim carpenter
Re: Hardwood Floor And Door Jambs
Originally Posted by WarnerConstInc. View Post
A little extra work but, that sure beats cutting jambs.
Beats jamb cutting and if you have to cut jambs... you will likely have to pull and cut down some doors too.
For the house in these pics the floor was a 5/8" engineered walnut floor. So I made up a bunch of shim block stacks (1/2" mdo blocks with an extra ply shim to total 5/8"). For door openings with a high side, I used the "Peel-a-shim" stack instead of the ply block and just dial the height back down to get level.
Anyway, I run by all the openings and set out the shim blocks for the jamb legs to rest on when installing the doors. Doesn't take very long.
Pay me now or pay me later
basswood is offline
Old 02-28-2009, 04:57 PM   #22
I like Green things
WarnerConstInc.'s Avatar
More than likley on the door cutting, some people just dont think very far ahead now do they.
WarnerConstInc. is online now
Old 02-28-2009, 10:04 PM   #23
topsail's trimcat
woodworkbykirk's Avatar
with the issue of call backs, this is part of the thing, im usually the guy getting sent to deal with the callbacks and fix things, the problems are with things which weve done things his way... when ive done things my way its done with walk away from it. come back when they want additional work done. im now ignoring his way for this reason , whats that old saying "do it right the first time" or something, not do it wrong the first time so we can bill the homeowner for comnin back time after time
also wanted to just trim the windows then come back after all the flooring was down and the painters were done all the walls before the doors were hung and cased, closets built, and baseboard, all this was doing was holding up everyone else .
woodworkbykirk is offline
Old 02-28-2009, 10:12 PM   #24
basswood's Avatar
Now what could possibly make you say something like that?
basswood is offline
Old 02-28-2009, 10:33 PM   #25
Morning Wood's Avatar
Trade: Pretty much anything with wood
Undercut for all the reasons already mentioned. I have used a biscuit jointer to undercut doors. Set the base on a shim so the top of the blade allows you to slide the flooring under the jamb. I always make it pretty snug.
Morning Wood is offline
Old 02-28-2009, 10:46 PM   #26
And a lot of HO's won't finalize
choices til 5 minutes after the
last minute.
neolitic is offline
Old 02-28-2009, 10:48 PM   #27
topsail's trimcat
ive used the bosch undercut saw in the past with a different contractor, he was awesome had like 3 of evertying on site for a house we completely remoddled. and there was only 2 of us
i just use a marples/Irwin japanese pull saw that has rip tooth configure on one side and a crosscut tooth on the other. it has a very thin kerf, good enough for me
Old 03-01-2009, 11:32 AM   #28
Deicide1's Avatar
You can if the HO is willing to pay for a top notch job. Most existing homes that I have re-done flooring in wether wood, tile and such, most doors have seen there better days. If I cant get them to pull the doors and jambs, I will under cut not notch. I always pull all the base, I really hate the look of short base and shoe moulding.
Look, I bid and do jobs that I feel I can do properly and will do properly. If a homeowner doesn't want to pay for a good job, then I am not willing to do it. I would never half-ass work because someone doesn't want to pay for good work.
Deicide1 is offline
Old 03-01-2009, 06:54 PM   #29
topsail's trimcat
well off the job now as of 5pm today..... homeowner is out of money or something soo i pulled all my gear outta there a couple hours ago
Old 12-03-2009, 12:17 AM   #30
Casemill's Avatar
Trade: Flooring
Your contractor need to sign something stating the he is responsible for all damage caused by flooring expansion. I'm sure he will let you do the job right after you present him with that document. He sounds like a moron.
Casemill is offline
Old 12-04-2009, 06:53 PM   #31
canadianwood's Avatar
Originally Posted by basswood View Post
When floors are to go in after doors are hung (some builders insist on this), I find out the floor thickness and hang the doors up at finished floor height. The floor guy loves it--just slips his floor in... very little jamb cutting... and I don't have to recut doors so they will clear a rug.
Here are a few pics of how I do this (note if the floor is not level the floor guy gets to cut in the floor on the high side, as I hang the jamb legs level):
A few large builders around here also insist on doors & trim before flooring. In fact, the flooring is the very last thing that goes into the home before they hand over the keys.
I guess Jayman homes got sick of fixing & replacing damaged hardwood
canadianwood is offline
Old 12-04-2009, 07:26 PM   #32
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Sounds like they are to cheap to supply ram board.
Doors installed before hardwood shouldn't matter regardless. All on has to do is know how to set the head of the jamb to elevation. Sure there could be some small trimming with a jamb saw. I wouldn't trim jambs any other way. Quick easy and painless. Even cutting doors down is painless with a track saw. Dewalt makes one that is descent.
JustaFramer is offline
Old 12-05-2009, 01:30 AM   #33
bconley's Avatar
Trade: Kitchen and bath design+remodel
Originally Posted by catawba View Post
To me it depends on wether it's prefished or unfinished (HO's) decision.With prefinished all I want to do is come back and put shoe ,lock sets and door bumpers on when they get through, less traffic. Unfinished floors,I totally agree with Warner.
The prefinished flooring is so soft and scratches so easy that this the only way you can turn over an acceptable product.
And the painters don't need to mask flooring when shooting base.
bconley is offline
Old 12-05-2009, 09:26 AM   #34
cabinet runner's Avatar
Trade: cabinet installer
Yeah thats how its done in my area 99% of the time . I installed cabinets in 2 kitchens this week on new homes that didn't have the flooring in the kitchen . Both are getting prefinished hardwood . I held the base cabinets up 3/4 of an inch .
One had an island so I left that loose and will go back ater the flooring is down .
I havent seen flooring down before the trim and paint were done in a long , long time .
cabinet runner is offline
