Hang Plazma
Old 03-06-2008, 04:52 PM   #1
dainova's Avatar
Trade: remodelling
Hang Plazma
Hi,
I'll need to redo old work and hang new plazma on the wall, do you think I can go to old holes and with old bolts, it's in wood studs.
Or probably and more reliable to go to new spot and new bolts.
Also what it the rule for pilot holes to achieve max strength ?
Does it go with normal rules like in Pilot Hole Size Table, probably for soft wood...
Tx
Dai
dainova is offline
Old 03-06-2008, 04:56 PM   #2
Dan_Watson's Avatar
Re: Hang Plazma
im assuming you have to reuse the old bracket?
Dan_Watson is online now
Old 03-06-2008, 06:21 PM   #3
You did what??
J F's Avatar
Re: Hang Plazma
I would just move the bracket up or down and inch or two and re-mount. Whenever I drill pilot holes I drill a hole just slightly smaller than the shank (minus the threads).
Now keep in mind my advice is worth about what you paid for it.
Someone else may know for certain that drilling new holes so close to the old ones is a recipe for disaster...so with that disclaimer...you can't sue me.
I did this exact same thing to a 50" plasma (mine) about 3 years ago....still hanging tough...I think.
J
J F is online now
Old 03-06-2008, 06:55 PM   #4
mmike032's Avatar
Trade: trim carpentry
Re: Hang Plazma
i was wondering WTH a plazma was.
mmike032 is offline
Old 03-06-2008, 06:56 PM   #5
You did what??
J F's Avatar
Re: Hang Plazma
It was a plazma rifle...40 watt range....just what you see pal.
J
J F is online now
Old 03-06-2008, 06:57 PM   #6
You did what??
J F's Avatar
Re: Hang Plazma
...and you have to say it in your best arnie impersonation...
J
J F is online now
Old 03-06-2008, 08:15 PM   #7
Dan_Watson's Avatar
Re: Hang Plazma
I usually drill the hole 1/8" smaller. Ive moved them down about 2 inches with no problem.
Old 03-06-2008, 08:30 PM   #8
Teetorbilt's Avatar
Re: Hang Plazma
What's the weight? You have wood studs, this is good. I'd go with a few Tapcons (they publish tension and shear on every box). I know that they are for concrete but also have a very aggressive thread that also works well in wood.
Albert Einstein
Teetorbilt is offline
Old 03-07-2008, 02:42 AM   #9
dainova's Avatar
Trade: remodelling
Re: Hang Plazma
Thanks all guys for warm welcome with that much replies.
dainova is offline
Price for Hang or Tape in Massachusetts Garythetaper Drywall 1 06-18-2007 07:48 PM
Hang and Finish or Just Hang Hardibuilt Drywall 21 06-10-2007 02:27 PM
Unfinished oak cabinets: hang and then finish or vice versa ? bahed Finish Carpentry 4 06-07-2007 11:10 PM
Best way to hang drywall on concrete wall?? gche37 Drywall 10 11-30-2006 10:29 PM
Stripped, Prep to Hang Q slickshift Wallpaper 3 09-10-2006 09:20 PM
