Good Trim Adhesive?
Old 08-15-2008, 10:39 AM   #1
banctecbobn's Avatar
Trade: home builder
Good Trim Adhesive?
Need to know the best adhesive for attaching wood trim around wood cabinets.
Trim will vary in size but mainly 1/2" to 3/4" corner trim. Will be attaching to painted drywall and wood cabinets finished with poly. There isn't anything to nail to so I'm looking into adhesive or any other suggestions.
Would like something that wouldn't need any clamping. I've used the Loctite Quick-grab on foam before and it didn't work for me. Would this stuff work great on wood and drywall?????? I'm looking for somehing that will work great.
Bob
banctecbobn is offline
Old 08-15-2008, 11:17 AM   #2
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Re: Good Trim Adhesive?
This is what comes to mind. It will work great but once applied it will never come off. Don't use the activator spray and you'll get a minute or two to hold and adjust.
Keep the product / kit out of the heat or your truck. Store it in the refrig. The humidity collects in the bottle and renders the chems useless.
I have the kit which has three viscountcies of the product.
http://www.amazon.com/2-P10KIT-2-P10...8812836&sr=8-2
http://www.garymkatz.com/TrimTechniq..._act_glue.html
We Fix Houses is offline
Old 08-15-2008, 11:49 AM   #3
denverboz's Avatar
I've used the Loc-tite Quick Grab before in just such situations, and it worked fine. You know they make different kinds,one kind is made for foam, but they also sell a heavy duty quick grab construction adhesive.
denverboz is offline
Old 08-15-2008, 12:01 PM   #4
Look at Rockler, Woodcraft, woodworkers supplies.
There are several cyanoacrylate (read super glue)
products for just this type of application.
neolitic is offline
Old 08-15-2008, 04:01 PM   #5
Being an A-hole
Candlewood's Avatar
Why glue it?
Never used any glue to hold trim up other than wood glue to hold returns together and what not.
John
Sorry, missed the whole part you have nothing to nail to.
Can you put any blocking in to catch the trim?
Candlewood is offline
Old 08-15-2008, 05:37 PM   #6
seabolt's Avatar
Trade: Cabinets/Remodeling
I picked up a Titebond HiPurformer kit a few years ago from my local Rockler and it works great for these situations. Here's a link:
http://www.rockler.com/product.cfm?O...Select=Details
It is a little pricey, and the glue is pretty high too (about $10 a tube), but it sets up fast and strong.
I originally bought it 'cause I was in a time crunch to finish a job - I glued up 56 five piece doors with it the day I bought it and there haven't been any troubles with the joints in over 4 years.
seabolt is offline
Old 08-15-2008, 11:48 PM   #7
Uber-Member
jeffaah's Avatar
Trade: Carpenter...Deck Guy
In this situation, I also suggest Loctite power grab. Fast tack and more then strong enough for moulding.
jeffaah is offline
Old 08-21-2008, 11:37 PM   #8
Hardly Working's Avatar
I like Tite Bond trim and moulding glue.http://www.titebond.com/ProductLineT...t=5&prodline=4 It's extra thick and doesn't run like TB 2.
Hardly Working is offline
Old 09-02-2008, 06:45 PM   #9
The Man
Cashking63's Avatar
I agree with hardly Working. i use the TB trim and molding glue and it always works very well. it also has a bit more "tack" to it which helps hold things in place
Watch your thoughts; they become words. Watch your words; they become actions. Watch your actions; they become habits. Watch your habits; they become character. Watch your character; it becomes your destiny. --Frank Outlaw
Cashking63 is offline
Old 09-04-2008, 07:45 PM   #10
nailman's Avatar
Trade: General
I swear by 2P-10, but from reading this thread I think I will try some of the recomendations.
nailman is offline
Old 09-12-2008, 01:35 PM   #11
ckarpa3's Avatar
Trade: General Contractor, Carpenter, Cabinetmaker
I use powergrab for panels, 2P10 for small trim work and returns. Why not use a micropinner? Mine shoots 1/2" pins. I can anchor tiny millwork to 1/4" panel.
ckarpa3 is offline
Old 09-12-2008, 02:57 PM   #12
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Dabs of carpenters glue and micropinner
silvertree is offline
Old 09-12-2008, 08:18 PM   #13
orson's Avatar
Trade: Kitchen & Bath
I'd say Loc-Tite Powergrab and micropin it for good measure.
Nice thing about the Loc-Tite other than the high initial tack is that it is water cleanup if any gooshes out on the edges.
PS- Loctite makes a Powergrab formulated for foam panels. Most construction adhesives are a no-no on foam.
orson is offline
Old 09-13-2008, 10:09 PM   #14
Certified Remodeler
silvertree's Avatar
I really like that lock tite myself. But I never leave home without glue, any brand. Water clean up for all the carpenters glues too. Micro pinner is great, I have 2 of them so I can switch nail lenght without opening the gun.
Old 09-15-2008, 07:21 AM   #15
Carpenter
RizzoMaryland's Avatar
Locktite or Carpenters glue would be fine for long term. Use a hot glue gun for immediate adhesion.
"An idea is salvation by imagination"
Frank LLoyd Wright
RizzoMaryland is offline
Old 09-18-2008, 01:02 AM   #16
dansbiz's Avatar
Trade: Finish Carpenter
I have had to glue small moulding pieces together and as you know using yellow glue and tape is tedious and messy I have found a spray glue called permagrip. Excellent for this reason...The down side is you can get overspray, but by covering the areas you can apply it no problem. It dries in minutes, spray both parts and stick it on. It bonds immedialety so you have to apply it precisely! some mini pin brads would not hurt after.
dansbiz is offline
Old 09-18-2008, 07:24 AM   #17
stp57's Avatar
Trade: carpenter/ handyman
Ditto for Powergrab. But, if you vent it first it will do a much better job. By vent I mean, press the piece in place, pull it back off for a minute & press it back in place. Works every time.
Steve
stp57 is offline
ACS....any good? orson Marketing & Sales 4 08-20-2008 09:01 AM
Is that marketing tool a good idea or a cheap one? WaltG Marketing & Sales 5 03-20-2007 10:15 PM
preprimed trim? what the? JohnDucan Painting & Finish Work 8 10-17-2006 08:32 PM
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 13 08-25-2006 08:49 AM
Good Workers denick Excavation & Site Work 12 03-05-2006 10:40 PM
