Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Finish Carpentry
Old 11-19-2008, 03:28 PM   #1
Trade: Finish Carpenter
Glass Doors For Built In
I need to order two sets of glass doors for a built in and was wondering what the rule of thumb is for sizing glass doors. How much should I deduct from the opening for two glass doors? I never installed glass without it being inside a frame.
KMac is offline   Reply With Quote
Old 11-19-2008, 09:49 PM   #2
(Just 'til someone else comes along) . . .
You're not giving much information on your application, - - and it's not something I generally do, - - but it sounds to me like I'd subtract 3/16" from the height (leaving 3/32" gaps), - - and 1/4" from the width (which then gets divided in two, leaving 3/32" gaps on the outside edges, and 1/16" in the middle). That would be the tightest I'd want to go.
But of course, - - there are several other factors involved.
Mainly, - - how accurate will your glass be cut (you may have to leave slightly larger allowances, according to your supplier's tolerance range).
Also, - - is your opening perfectly square, and will the glass(es) be cut perfectly square??
Do the hinges you're going to use require a certain minimum clearance??
How dimensionally stable is the material you're using for the rest of the unit, and how constant is the humidity level in the room/building??
Sounds like you already have the unit built??
Generally, if I was going to custom build a unit that was going to need frameless glass doors, - - I would figure and order the glass before the build, - - then their 'tolerances' wouldn't have to enter the equation.
But, - - if I did need to get the glass last, - - I would get them made locally, - - so I could double check their accuracy upon purchase.
(Where the hell's Leo when you need him??)
Tom R is online now   Reply With Quote
Old 11-19-2008, 09:54 PM   #3
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
Kmac; make your doors, take em to your glass shop, pick em up when they have em ready :}:}
Another important factor is the size, there is code issues, after a specific size that glass has to be tempered glass. Tempered has to be ORDERED to a specific size and cannot be cut therefore back to my suggestion; let the glass shop worry about sizes etc.
skymaster is offline   Reply With Quote
Old 11-19-2008, 10:34 PM   #4
Maybe I'm not understanding him right.
I'm thinking he's talking about (from his wording) 'frameless' glass doors . . .
Old 11-19-2008, 11:57 PM   #5
Thanks for the reply.
I guess i should have ordered the doors first but now I need to get them made. They're going to be 1/4" tempered and I have the hardware and all already but no info with the hinges.
I was thinking right along the same lines - 3/32" gaps or so - maybe an 1/8". Seems like when i have seen them done before the gap was larger all the way around though.
Wood movement shouldn't be an issue moisture content is good now and will be in a controlled environment.
Old 11-20-2008, 07:12 AM   #6
Yeah, - - they use the bigger gaps for their own convenience, not the customers. Less chance for error or rubbing, and more room for deviation in straightness or squareness.
1/8" gaps would be OK, - - but that should probably be an absolute maximum.
Let us know how it works out.
Pics, pics, pics . . .
Old 11-20-2008, 07:09 PM   #7
I definitely will be taking pics and will certainly post some. Install is first week of December. Thanks again!
Glass tile prices Teetorbilt Remodeling 6 10-29-2008 09:57 PM
A Million Bux in Wasted Glass! Henry Grover Jr General Discussion 7 04-07-2008 08:31 AM
What to use on sandblasted security doors? Dorman Painting Painting & Finish Work 3 08-07-2007 05:24 AM
Glass Block Transition Paul_NJ Ceramic & Stone Tile 0 03-15-2007 07:14 AM
