Trade: green building
Fudge Factor For Biscuited Door/window Casings
Here's a question for you trim carpenters who preassemble door or window casings on the floor using biscuits and glue.... How much can the jamb be out of square or be wracked and still give good results with this technique?
miterclamp.com
Trade: interior trim/cabinets
Re: Fudge Factor For Biscuited Door/window Casings
It depends on how wide your casing is compared to the window size, and whether it is a stool and apron job or picture framed. If it is picture framed, then you will have to cut the miters to match the jamb.
If it is too far racked on stool and apron windows, you may have to make your miters to match the jamb too. I would let any racked window casing joints set up overnight before trying to force them into place. Doors can be out a bunch.
Experience is what you get only just right after you needed it. http://www.miterclamp.com |
Thanks Jim... great article in FHB # 164; I'm finally gonna give it a go; maybe old dogs can learn new tricks
miterclamp.com
Thanks, and absolutely old dogs can learn. Though trial and error has become my operational mode the older I get.
I switched from full time wood butcher to metal muncher with 50,000 lbs worth of metal munching equipment at age 56, and didn't know what a single one of the 16 levers even did on the first universal milling machine I bought. I still don't know much, but I did learn where not to stand when those purple, smoking chips start flying. Cheers, Jim
| tight miters on door casings help! | ROGER RAMJET | Finish Carpentry | 44 | 11-14-2008 02:31 AM |
| Painting over alluminum window casings | MRstark44 | Painting & Finish Work | 7 | 07-26-2008 05:55 PM |
| Exterior casings with integrated j channel? | sandyman720 | Windows, Siding and Doors | 5 | 11-22-2007 08:38 PM |
