Frozen Glue
Old 02-06-2010, 01:20 PM   #1
tcleve4911's Avatar
Trade: Remodeling contractor
Frozen Glue
I left a bottle of Titebond 111 overnight and it froze. The top 1/2" is brown. I opened it and stirred it around. It looks okay. It's smooth - no clumps.
Does it alter it's quality when it freezes?
Is it okay to use?
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 02-06-2010, 01:22 PM   #2
Re: Frozen Glue
You are now obligated to
test it for us....
in the name of science!
Report back tomorrow.
neolitic is offline
Old 02-06-2010, 01:22 PM   #3
genecarp's Avatar
Re: Frozen Glue
I have warmed up a bottle or 2 in the micro over the years---only for 4 seconds, uncovered, my guess would be that it probably diminishes the strength somewhat, but not enough to fail, GMOD
genecarp is offline
Old 02-06-2010, 01:24 PM   #4
Its all ball bearings
angus242's Avatar
Trade: Tile
Re: Frozen Glue
From their website:
Limitations Not for continuous submersion or for use below the waterline. Not for structural or load bearing applications. Use when temperature, glue and materials are above 45°F. Store product below 75°F. Storage above this temperature may cause product to thicken and reduce the usable shelf life. If thickened, shake vigorously by firmly tapping bottle on a hard surface until product is restored to original form. Because of variances in the surfaces of treated lumber, it is a good idea to test for adhesion. Read MSDS before use. KEEP FROM FREEZING. KEEP OUT OF THE REACH OF CHILDREN.
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is online now
Old 02-06-2010, 01:28 PM   #5
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Re: Frozen Glue
Why risk it?
The test may be interesting. But is a professional job worth the risk of embarrassment over a less than $20 suspect item?
Gus Dering is offline
Old 02-06-2010, 01:33 PM   #6
LRG WoodCrafting
Leo G's Avatar
Re: Frozen Glue
Most of the glues have 3 freeze thaw cycles. But from the looks of the spec sheet you should junk it. Why risk a project from failing when you can get another bottle for under $25.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 02-06-2010, 01:35 PM   #7
Re: Frozen Glue
Originally Posted by Gus Dering View Post
Why risk it?
Some of us are snowed in.
Why turn one's back on an opportunity
to advance science and knowledge?
Besides Cleve can use the time,
developing proper testing procedures,
that might otherwise be squandered
shoveling snow!
neolitic is offline
Old 02-06-2010, 01:35 PM   #8
genecarp's Avatar
Re: Frozen Glue
Save it for your own house, only your wife will complain if a joint or 2 opens up, GMOD
genecarp is offline
Old 02-06-2010, 02:54 PM   #9
Gus Dering's Avatar
Re: Frozen Glue
shoveling snow!
Why risk it?
I'm a lot of things, but a dream squasher is a stretch.
Old 02-06-2010, 02:55 PM   #10
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
Re: Frozen Glue
...i know Elmers ProBond had a freeze thaw cycle of five times. Said so on the bottle!
TBFGhost is offline
Old 02-06-2010, 05:08 PM   #11
BCConstruction's Avatar
Trade: Construction
Re: Frozen Glue
Titebond 3 has the same amount. I think 2 also has but im not sure.
Type Advanced Proprietary PolymerCalculated VOC (less water) 5.6 g/LState LiquidWeight/gallon 9.22 lbs.Color TanChalk Temperature* Approx. 47°F.Dried Film Light BrownFlashpoint >200°F.Solids 52%Freeze/thaw stability Stable (5 cycles)Viscosity 4,200 cpspH 2.5-3.0Storage life 12 months (in tightly closed containers at 75°F.)
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is offline
Old 02-06-2010, 05:36 PM   #12
Tom R's Avatar
Re: Frozen Glue
Personally, I wouldn't take a chance on it.
Supposedly it can withstand a freeze cycle or two, you can tell by if it mixes back to it's original form (rather than staying separated or clumpy).
Tom R is offline
Old 02-06-2010, 09:03 PM   #13
NjNick's Avatar
Trade: Mechanical Contractor, G.C
Re: Frozen Glue
ahh try it , just use a couple extra nails
NjNick is offline
Old 02-06-2010, 09:18 PM   #14
topsail's trimcat
woodworkbykirk's Avatar
Re: Frozen Glue
not sure, not about to find out i just bought some today.
ive had lepage's glue freeze and thaw many times with no problems. but gorilla wood glue is pretty much done first freeze, even once its completely thaws out it has the consistancy of cottage cheese
woodworkbykirk is offline
Removing glue residue from concrete? blastoffinc Sandblasting 7 08-26-2009 01:38 PM
Removing glue after pulling paper is easy! MZ-HANDYMAN Wallpaper 20 08-06-2009 04:32 PM
glue gun user30697 Tools & Equipment 6 07-24-2009 07:10 PM
Glue applicator? Jason Whipple Finish Carpentry 19 05-21-2009 11:24 PM
Help glue removal isaac Finish Carpentry 2 12-12-2008 12:49 AM
