Trade: home improvements
Finishing Some Build-in
I have a customer that I got to do some build-ins for. I'm building them out of birch and pop. I need so advise on finishing them. I have to paint them. I was thinking that if I paint with a oil base and sand between coats. will I get a nice finish. Is not set up with a spray gun so I was thinking of using a good brush. Will this work?
Trade: Epoxy Flooring & Concrete Overlays
Re: Finishing Some Build-in
#3 | |
Carpenter/fencing
Re: Finishing Some Build-inQuote:
Learning without thought is labor lost; thought without learning is perilous. |
Head Peon
Trade: Licensed G.C. Commercial & Residential Remodeling,Maintenace
Hello JCB,
If you have not painted alot with oil base it helps using Penetrol to condition paint.I am more of a carpenter than a painter but have done some. If you have other things you can work on in between coats I would try applying with a foam roller if possible.It goes on lighter than it would if you brushed but it dries alot quicker.Make sure you apply a primer also on the bare wood.A light sand in between like you said.If you decide to brush just keep a foam roller handy with a little thinner to fix any area of concern an then rebrush. You can do it.
Thanks, Wayne Brassell http://www.Bbldg.com "We Build Relationships Not Buildings" |
Trade: custom carpentry
i use the sherwin williams pro classic gloss on all my custom "built-Ins" with a good primer undercoat, that is sanded after dry.
sherwin williams also has a great primer that goes with the pro classic ask them which one it is. together you will spend about 70 bucks plus 15 for a good brush and 8 bucks for the mini roller. SPEND THE MONEY ON THE GOOD PAINT, IT MAKES A DIFFERENCE, been their done that.
Kreg It's the details that make the difference.... pay attention to them. |
yes, the paint coats will go on nice with a mini foam roller.
Yessss, ProClassic!
![]() Best thing since shirt pockets. ![]() Hard as oil enamel, and dries like latex. I use oil primer, sand, and foam mini roller for finish coats. The ProClassic is really forgiving and comes out looking like a sprayed job. (Don't let the bubbles scare you they pop and it self levels nicely. Build thin coats, don't try to do it all at once)
| Why Build ICF | monsterconstruc | Green Building | 32 | 09-28-2008 11:48 PM |
| Sheetrock Finishing Tools!!! | Mud Master | Drywall | 19 | 02-29-2008 06:58 AM |
| drywall finishing crew | damudman | Help Wanted or Looking For Work | 0 | 09-13-2007 04:34 PM |
| sprayer won't build pressure/ | Traditions | Painting & Finish Work | 10 | 05-27-2007 09:12 PM |
