Finish Nailing Problem
Old 03-28-2007, 12:59 PM   #1
mms's Avatar
Trade: Structural Steel
I am fabricating an oak bulkhead out of 1X8 solid oak
(2 sides and 1 horizontal bottom surface).
First I constructed a rough frame from pine and secured this to the ceiling.
Now I am "finish nailing" the 1X8 oak pieces to this frame,
and am having great difficulty with the nailing,
as everything "bounces" so badly as I am nailing.
Is there a "trick" to stop this bouncing?
mms is offline
Old 03-28-2007, 03:21 PM   #2
Jeremy E's Avatar
Trade: carpentry
Re: Finish Nailing Problem
Pre-drill
Jeremy E is offline
Old 03-28-2007, 05:07 PM   #3
Teetorbilt's Avatar
Secure the framing better, it shouldn't be 'bouncing'.
Albert Einstein
Teetorbilt is offline
Old 03-28-2007, 05:54 PM   #4
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
Either use a finish nailer or a brad nailer.
In_Mexifornia is offline
Old 03-28-2007, 07:05 PM   #5
mms's Avatar
OK, thanks for your replies.
I did pre-drill; but perhaps not a large enough diameter??
The framing cannot be secured any better; I used three 2-1/2" screws
into each ceiling joist the bulkhead spans across.
I don't own a nail gun, so that option isn't available to me.
Thanks again.
mms is offline
Old 03-28-2007, 09:13 PM   #6
Professional
You can probably rent one for $15 a day. Know anyone you can borrow one from?
Old 03-28-2007, 11:16 PM   #7
mms's Avatar
Can't think of anyone that has one to borrow, but I most certainly can rent one.
Thanks for the idea!
mms is offline
Old 03-29-2007, 12:33 AM   #8
Scott Young's Avatar
Trade: carpenter/remodeler
having faced the same thing you are describing i would suggest a faster hammer head to drive the nail before the bounce, or rent a nail gun. you can always pick one up for a pawn shop for little to nothing.
Scott Young is offline
Old 03-29-2007, 10:40 AM   #9
IBUILD's Avatar
Trade: GENERAL CONTRACTOR
I agree with pre-drilling, keeps it from splitting as well!!
IBUILD is offline
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 04:41 PM
GAF nailing strip Jaketoo Roofing 12 08-10-2007 07:58 PM
Stripping old deck finish joedonuts Painting & Finish Work 26 06-09-2007 11:34 PM
metal railing finish failed problem? a68cudas Painting & Finish Work 9 06-06-2006 03:37 AM
Finish nailer problem Nick H Tools & Equipment 2 01-24-2006 06:17 PM
