1 man show.
Trade: Finish Carpentry
Ext French Door Jamb Width
How can you tell if you are going to need a 4 9/16" jamb or a 4 1/8" on a exterior wall, or are all exterior jambs never no less than 4 9/16"? Exterior is stucco in my case.
Trade: Carpentry & Remodeling
Re: Ext French Door Jamb Width
Well here in the NE we frame our ext. walls with 2x6. but if you are unsure and have noway of measuring the existing jamb for some reason, it is easier to add e-jambs than to rip the jamb to a smaller width. So go with the smaller 41/8 jamb. Can you measure the wall thickness?
3 1/2 " wall 1/2 '' ply& 1/2'' drywall?? I'm not sure i have seen 4 1/8 though.
Do what you would do, as if i won't Do anything after you Did It! Last edited by D.Foster; 02-01-2009 at 02:41 PM. |
Trade: Remodeling contractor
I would tend to go with the wider jamb widths. The inside of the jamb needs to be at least flush with the interior wall plane or you can't open the "French doors" all the way back to the walls. Just my experience...........
Back in Maine Dubbin' Around Doin' good stuff ...... |
Inswing, or outswing?
Outswing and stucco, make sure the hinge leaf width is wide enough to allow for the hinge knuckle to be at or slightly beyond the stucco, or the door will hit and won't open 180 degrees. If you do that and can't get back flush to the drywall on the interior, extend the jamb, or order it oversized if possible. Or if there is to be no case molding on the door, return the drywall back into the jamb and bead that edge. If it's stucco and inswing, return the stucco into the jamb on the outside, if that detail is acceptable, and bring the jamb flush to the drywall on the inside. I've always had trouble with jambs being exactly the right size. An out of plumb wall can screw you. They make those long jamb extension screws (McFeeley's.com) and if it's paint grade jambs, you're in business. I've even scribed and ripped the jambs to accommodate anomalies. Good luck. |
If the jamb ext. isnt too long and you have enough room i've used pocket screws too to attach them. I would like to try those screws from mcfeelys though, saw them a while back
Do what you would do, as if i won't Do anything after you Did It! |
Error Corrector
Trade: Maintenance Manager
I don't believe I've heard of 4 1/8" either. One of the properties I worked at had 5 1/4" (2X4 wall; 5/8" drywall inside; 5/8" drywall firestop outside and 1/2" plywood outside) jambs and the lumberyard we had a contract with only stocked 4 9/16" or 6 9/16". Most of the time I'd get the 6 9/16" pull the brickmolding off and rip them down.
| french door pricing | bcrdiy | Finish Carpentry | 36 | 05-02-2009 09:57 PM |
| I Have A New Appreciation For French TV Game Shows | Ed the Roofer | Off Topic (Non Trade) | 8 | 01-30-2009 06:12 PM |
| Height x width, or width x height? | webopolis | General Discussion | 31 | 10-23-2008 07:53 AM |
| Grout Width and sealing. | jritkes | Flooring | 6 | 09-28-2008 08:23 PM |
| French drain question | 72chevy4x4 | Construction | 4 | 11-01-2006 10:46 PM |
