Trade: Finish Carpentry
Entry Door Frustration
Why is it that the more expensive and nice looking a door is, the harder it is to install properly? When a door costs thousands of dollars, shouldn't it be PERFECT?!
The one I'm working on now is a 7'x10' double arched door, mahogany, shipped from Honduras I guess. Not sure of the name of the company. Reveals are nice, but with a perfectly plumb jamb, alignment of the two doors is 3/4" off. Had the same problem with my last big entry door. So I fixed that, and the 4-point lock won't operate. The doors came pre-mortised and they're almost 1/4" off from where they should be. Just wondering if anybody else has experienced the same problems, and maybe some of you can recommend a better supplier of custom entry doors that I can pass along to the builder. |
I'm a Mac
Trade: ICF Construction
Re: Entry Door Frustration
Chris |
Where would you propose that one get Honduran Mahogany?
Insert title
Trade: Doors-Windows-Decks
China or Wal-Mart
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
I'm a Mac
Re: Entry Door FrustrationI was refering to the frame hanging and hardware application, not the species of wood
Chris |
They send the trees to China, or the Hondurans?
#7 | |
Re: Entry Door FrustrationQuote:
I really don't like fancy doors that come premortised.... They seem to ALWAYS be jacked up. I used to have a boss who'd get all his custon made doors mortised by the local door company. Every door had the hinge mortises cracked or at different depths and the latch holes were always out of alignment... and really... if you're a door company, shouldn't you know that the deadbolt and latch don't use the same strikeplates?
I've dealt with this since the '70's. The 'fine tuning' is up to you. I've never had one that was 3/4" off - 3/8" maybe.
Insert title
They are smart, they only import raw materials.
Al Smith
The larger the door is the more it weighs and the more critical it is to get solid backing behind the jamb hinges. also its not hard to be 3/8 of an inch out in seven feet. 3/16 in from the wall surface and 3/16 out from the wall surface in a twin door with both hinge jambs will result in the doors not aligning by 3/4 inch at the astrigal. It is also expected that a custom raised panel door slab could potentially be tweaked out of flat. It is not difficult to spot potential issues as you check and recheck during the entire process of hanging a very large and very heavy twin door. I use a level to find my starting point. After that I pretty much put the level aside and make the rest of the door assembly match lock mortises and open and close correctly with even reveals. A properly hung solid door should sound like a car door closing.
yea the cheap doors do seem to go in easy, with perfect reveals.
#13 | |
It's true though! A run-of-the-mill 8'x6' double from anywhere usually lines right up, shim it, fasten it and voila! Now add a few thousand dollars to the price tag and it's a day-long project...
Anyway today I showed the builder, didn't want to touch it till I get the OK... He's gonna call the supplier, but I'm willing to bet customer service from Honduras will be nonexistent. So can anybody recommend a GOOD supplier of high-end entry doors? I'm tired of fighting these things. |
Trade: glass and window company
IWP Doors. They are a division of Jeld-Wen. You can find a supplier local on the website. www.jeld-wen.com.......very high end. I did a double entry door with sidelites and transom for 18K material only. They are produced in Mexico.
#16 | |
They own% of the door market world wide. They fabricate veneered and the real deal. The Aurora doors through IWP are the composite doors, but they also carry real wood.
#18 | |
It's all about the Avatar
Trade: I have no face!
#19 |
Thanks for the suggestion, I will pass it along...
#20 | |
... I don't believe I've installed any of their doors before, but I could be wrong.Anyway, I found the company that supplied the ones I'm griping about, they're called Borano. Here's a picture of it, it's the first one, "Provence" http://www.borano.com/mahogany_exterior_doors.htm |
| Steel exterior entry door ?'s | HoneyDo | Painting & Finish Work | 1 | 10-26-2007 01:28 PM |
| glass block entry to shower | Mr. D | Masonry | 10 | 12-04-2006 02:14 PM |
| Timberframe front entry | tcleve4911 | Carpentry Picture Post | 8 | 11-18-2006 05:18 PM |
| Need Entry Door Help...PLEASE! | thepawnshop | General Discussion | 6 | 06-04-2006 11:46 PM |
| Service Entry | Glasshousebltr | Electrical | 4 | 11-26-2005 11:46 AM |
