Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Finish Carpentry
Old 03-09-2009, 05:34 AM   #1
Trade: Union Carpenter
Entries for "secret" rooms
A family Friend has asked me to take on a very interesting project of turning the office accessed from the master bedroom into a saferoom of sorts. Its more for keeping valuables out of plain sight than for hiding from burglers. We are looking for clever ways to conceal the enterence, but the real hard part is finding hardware for such a door... both the hinges and the closer and latch.
Could someone give me an idea or point me in the right direction.
lilFORESTer is offline   Reply With Quote
Old 03-09-2009, 07:51 AM   #2
Sean
SLSTech's Avatar
Start here http://www.contractortalk.com/f11/di...ng-them-54176/ - the one thread by me has a company that custom designs entrances for anyone & ships them, but there is allot more good info in there also
Next please put your location in your profile to help us all out.
SLSTech is online now   Reply With Quote
Old 03-09-2009, 07:59 AM   #3
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
Specifically, it is www.hiddenpassageway.com They have the best quality products and already come with hardware and options.
You can also try:
www.hiddendoors.com or www.nichedoors.com
BTW, as SLSTech already mentioned, you are doing a pretty good job of hiding already since you didn't put your location in your profile.
__________________________________________________ ___________
You are not making progress unless someone is trying to get in your way. I will never give up!
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline   Reply With Quote
Old 03-09-2009, 09:06 AM   #4
little fish
world llc's Avatar
Trade: general contractor
seen a large shotgun safe with the back cut or burned off as the entrance... looks like a safe but was an enterance to a small closet
world llc is offline   Reply With Quote
Old 03-09-2009, 10:24 AM   #5
Trade: Finish Carpenter
Check out this article:
http://www.garymkatz.com/TrimTechniq...se_install.htm
Should give you some ideas.
KMac is offline   Reply With Quote
Old 03-09-2009, 10:47 AM   #6
did one a few years back, cheap and easy. i took the existing in swing door to the closet, then added another door to that one hinged on the opposite side(bi-fold style). finally i added a picture framed wardrobe mirror to that door. i dont recall the name of the hardware, but to open and close the unit you would just have to push then pull on the mirror and it would accordian out and to the left. the hardware was a pin and socket type
parkers5150 is offline   Reply With Quote
Old 03-09-2009, 10:59 AM   #7
Palisade Point Const.
TempestV's Avatar
I saw some "childproof" locks a while back, I believe in rockler, that used a magnetic key to open. The hardware was mounted on the inside of the door, and no key hole was needed, instead, a magnetic key was provided, which you placed over the lock assembly from the other side of the door, and you could then open the door. I'm not sure if that will help you, but when I saw it, I thought it might be useful for locking a hidden door. I'd ask them what they might want on that wall in their bedroom that could be used as a door- Tv cabinet, mirror, shelves, ect. If there is something to cover up the opening, it's a lot easier than making the door blend into the wall.
Edit- Here is the lock I was talking about:
http://www.kidsafeinc.com/product/71...&utm_campaign=
TempestV is offline   Reply With Quote
QuickBooks - Payroll entries repeatable? sharpsaw Accounting Software & Discussion 2 03-01-2008 11:05 PM
Who uses "hot mud" for entire rooms? steve-in-kville Drywall 37 10-10-2007 07:48 PM
paint est. for house inside rooms by the sq ft pool adams Painting & Finish Work 17 09-27-2007 09:13 PM
jiggly rooms............ painterofeveryt Painting & Finish Work 5 01-06-2007 06:13 PM
Somebody sell some Gass Rooms Glasshousebltr Construction 2 03-04-2004 10:46 AM
