Ending Chair Rail Molding.... - Finish Carpentry - Contractor Talk
Old 02-18-2018, 11:10 AM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,118
I'll be installing painted chair rail soon in a hallway that extends into a foyer. Lots of doors involved.
What is your preferred method of ending the chair rail at the door casings? All the casing is stained and the chair rail will be painted. The chair rail has one rounded section that will be proud of the casing.
I have made straight cuts to the casing and back-beveled the proud portion and I have cut returns at each piece of casing.
What is your preferred method?
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is online now
Old 02-18-2018, 11:45 AM   #2
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 122
Re: Ending Chair Rail Molding....
Back bevel. Painting the wall later with a return next to the casing sucks.
goneelkn is offline
The Following 3 Users Say Thank You to goneelkn For This Useful Post:
Bull Trout (02-26-2018), overanalyze (02-18-2018), Robie (02-18-2018)
Old 02-18-2018, 11:50 AM   #3
Robie's Avatar
I'll be painting all the walls and ceiling before the molding goes in.
Older couple...probably last re-paint job they will see.
But yes, I agree...pita.
Robie is online now
goneelkn (02-18-2018)
Old 02-18-2018, 12:31 PM   #4
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 1,104
I assume no chair rail backer since it's not mentioned? I've never done chair rail that didn't have backer. We would end the backer into the side of the casing and do a self return on the chair rail about 3/4" - 1" from the door casing.
If you don't have backer I guess I would do the back bevel but I don't like the look that I imagine either of those options to look like.
Xtrememtnbiker is offline
Old 02-18-2018, 12:35 PM   #5
Robie's Avatar
No backer.
This is what will be installed.
Robie is online now
Old 02-18-2018, 12:40 PM   #6
Then I would back cut/bevel on a 22.5 from the point that sticks proud of the casing.
The Following 7 Users Say Thank You to Xtrememtnbiker For This Useful Post:
Bull Trout (02-26-2018), Bummie (02-18-2018), overanalyze (02-18-2018), pinwheel (02-21-2018), Robie (02-18-2018), SmallTownGuy (02-18-2018), tsbrewers (03-02-2018)
Old 02-21-2018, 07:21 AM   #7
Pro something
M.F Custom's Avatar
Trade: Construction
Rewards Points: 392
Must be thin casing, you could add a back band to the casing. I hate clipping any trim and leaving exposed end grain...
M.F Custom is offline
The Following 2 Users Say Thank You to M.F Custom For This Useful Post:
asevereid (02-21-2018), Robie (02-21-2018)
Old 02-21-2018, 08:25 AM   #8
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 4,698
https://www.flickr.com/photos/crown_molding/5122106834
Big Johnson is online now
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
greg24k (03-03-2018), parkers5150 (02-21-2018)
Old 02-23-2018, 11:56 AM   #9
AustinDB's Avatar
Rewards Points: 840
I would make a straight cut and round over the part that sits proud to make it appear as a returned corner. Works for paint grade
AustinDB is offline
The Following 2 Users Say Thank You to AustinDB For This Useful Post:
B.Johnson (03-03-2018), Robie (02-26-2018)
Old 02-26-2018, 09:28 AM   #10
RichVT's Avatar
Rewards Points: 667
See this:
http://www.thisiscarpentry.com/2014/...-wall-returns/
RichVT is online now
The Following 4 Users Say Thank You to RichVT For This Useful Post:
M.F Custom (02-27-2018), Ohio painter (03-03-2018), Robie (02-26-2018), Xtrememtnbiker (02-26-2018)
Old 03-02-2018, 11:45 PM   #11
tsbrewers's Avatar
Trade: Finish Carpentry
Rewards Points: 120
Originally Posted by RichVT View Post
I'm sorry, but that is ugly as sin,
Too much going on with those two moldings. maybe a plinth block would have looked better, not sure, but that doesn't do it for me personally.
tsbrewers is offline
The Following User Says Thank You to tsbrewers For This Useful Post:
Big Johnson (03-03-2018)
Old 03-03-2018, 07:59 AM   #12
General Contractor
greg24k's Avatar
Rewards Points: 7,516
The typical way of doing this is simply "ease the edge" from the protrusion point or keep back and cap it if there is backing like Big J's example.
Eased edge is common on the shoe, chair or plate rail moldings...and not the base molding unless it was improperly sized.
greg24k is offline
The Following 7 Users Say Thank You to greg24k For This Useful Post:
asevereid (03-03-2018), AustinDB (03-04-2018), Big Johnson (03-03-2018), overanalyze (03-03-2018), Railman (03-03-2018), Robie (03-04-2018), sparehair (03-04-2018)
Old 03-03-2018, 10:42 AM   #13
Railman's Avatar
Trade: Railing
Rewards Points: 459
To me, this is an example of " less is more".
Sometimes the cleanest look is the best rout, regardless of what phobias a purist trim carpenter may have. The more you stack parts to the situation, the more it jumps out.
But the square portion, & clip it back at 30' or so. That is by far the cleanest, & best functionality way to do it, especially given that it is painted woodwork.
Railman is offline
The Following 2 Users Say Thank You to Railman For This Useful Post:
greg24k (03-03-2018), Robie (03-04-2018)
Old 03-04-2018, 09:00 AM   #14
MTRmatt's Avatar
Rewards Points: 4
[IMG]http://tic.wpengine.netdna-
cdn.com/wp-content/uploads/2013/06/Finished-1.jpg[/IMG]
Agreed to much going on there.
Some many variables and ill do different things dependung on orofile and projection. but with the molding your using ill usually just knock the cirner back on the saw and hit it with some sand paper. Like mentioned above less is more
MTRmatt is offline
The Following User Says Thank You to MTRmatt For This Useful Post:
Robie (03-04-2018)
Old 03-04-2018, 09:24 AM   #15
Pro something
M.F Custom's Avatar
Trade: Construction
Rewards Points: 392
I'm not sure what kind of casing that is in the picture but its awful thin for any base or chair rail to terminate into...
The Following User Says Thank You to M.F Custom For This Useful Post:
greg24k (03-05-2018)
Old 03-08-2018, 10:05 PM   #16
Big Shoe's Avatar
Rewards Points: 1,880
Believe it or not, Iíve used my belt sander on chair rail to bevel the high side off at casing after itís installed.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
base picture frames and chair rail on out of level floors mastersplinter Finish Carpentry 10 04-18-2014 10:33 AM
Makita tracksaw and rail 4 sale Californiadecks Contractor Swap 3 11-10-2012 07:48 AM
Koch's barber chair Kent Whitten Carpentry Picture Post 1 08-23-2012 07:22 PM
terminating chair rail woodworkbykirk Finish Carpentry 1 12-09-2010 09:26 PM
Pricing 5 1/2" Crown Molding, Baseboard (Colonial) and 3" Chair rail into metal studs baumbuilders Finish Carpentry 18 05-05-2009 10:28 PM
