Edge Treatment For Exterior MDO
Old 05-04-2012, 03:26 PM   #1
The Deck Guy
Greg Di's Avatar
Rewards Points: 2,000
We are building an enclosure for an outdoor TV (TV IS WATERPROOF SO DON'T GET SIDETRACKED INTO MAKING THIS WEATHERTIGHT).
I'm going to use 3/4" MDO for every part of this, including two doors. Is there a way to treat the edges to hide the grain of the plywood? I can't imagine traditional edge banding holding up.
I know some sign guys use spackle on the edges.
Is there an "accepted" way of doing this?
Thanks
Greg Di is offline
Old 05-04-2012, 03:27 PM   #2
bodean614's Avatar
Trade: Carpentry/cabinetry/ estimating
Rewards Points: 91
Re: Edge Treatment For Exterior MDO
Miter. And glue.
bodean614 is offline
Old 05-04-2012, 04:05 PM   #3
The Deck Guy
Greg Di's Avatar
Originally Posted by bodean614 View Post
Miter. And glue.
Not possible on a door.
Greg Di is offline
Old 05-04-2012, 04:07 PM   #4
bodean614's Avatar
Rewards Points: 91
Then I would sand smooth seal with a exterior sealer and use a good primer.
Old 05-04-2012, 04:34 PM   #5
Logician
dontgetinmyway's Avatar
Rewards Points: 75
http://images.meredith.com/wood/imag...er_bits_bg.jpg
Hope this post works - I found this picture online but have used this technique many times - these router bits used in conjunction with some mahogany or spanish cedar stock will make perfect painted exterior door edges with MDO.
dontgetinmyway is offline
Old 05-04-2012, 04:36 PM   #6
Kent Whitten's Avatar
Rewards Points: 2,040
Exterior MDF out of the question? I have had a test piece painted for almost 2 years now under the drip edge of my shop, and in direct sunlight with zero issues so far. Edge treatment is not an issue. Stays flat. I had a scrap piece in water for 2 weeks and it absorbed about 1/32" untreated.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 05-04-2012, 07:40 PM   #7
KAP's Avatar
Trade: Custom
Rewards Points: 25,952
Thanks
You mention spackle, so I am assuming painted finish? If so, exterior MDO. If not, as dontgetinmyway suggests... or Burgess bits, but either one, the veneer will be fragile at the outside because of variances in the ply when running the bit, so remember to leave it a hair proud for 1/6" rounding of the corner to blend the veneer and wood... Lots of glue...
Best of luck... 8^)
KAP is offline
Old 05-04-2012, 11:08 PM   #8
OKMrazor's Avatar
Trade: Cabinet/Millwork Designer
Rewards Points: 256
Don't know what the budget is, but we did an outdoor kitchen out of King Starboard. That's used on boats all the time. Pricey stuff, but if it's just one tv-sized cabinet... Stuff's bullet-proof in terms of harsh elements.
They also have some color cores - with both outside 1/8" one color and a contrasting core.
Kent's exterior MDF idea is likely far cheaper/sheet. I've never used the stuff, but the PM on a neighboring job site "tested" it by throwing a sheet in a big muddy puddle at the front of a job site. Was there for a couple of weeks and served as a makeshift walkway through the muck.
Was toast at the end - but more from the back and forth of work boots/occasional tires than the elements. I think everyone was pretty amazed at it's resilience. Would use it in the future.
For MDO, on a small cabinet, I suppose I'd hardwood edge it. A bit of a time-sucker, but certainly better than edgebanding.
OKMrazor is offline
drip edge ? wellbuilthome Roofing 72 07-12-2015 04:18 PM
Beveled edge tutorial Gus Dering Finish Carpentry 17 09-15-2010 07:26 AM
Drip edge...over or under... Jambruins Roofing 17 08-13-2010 03:07 PM
Edge Tape KennMacMoragh Painting & Finish Work 9 04-23-2010 05:34 PM
