Trade: carpentry
Drywalled Closet Door Openings
looking for different finishing ideas around the base of a drywalled closet door opening. installing trim first and then putting on the closet door always leaves big gaps between the door and cutting the trim around the floor mounted bracket looks like crap what are some general ideas to overcome this issue
Trade: Guy who plays with wood
Re: Drywalled Closet Door Openings
Have the taper finish the jamb all the way to the floor. Don't install any base on the jamb area.
Super B
Add a 1x6 bumper jamb and let the base die into it.
Why not just 45 the base and cap it off before the drywalled opening? Nice look and gap/other problems solved.
"please complete your profile, and continue to the intro page and tell us a little about yourself and your proffesional experiance, thankyou and welcome to ct"gmod
| The Following User Says Thank You to genecarp For This Useful Post: | madavis@insight (11-11-2009) |
Trade: carpentry
in this particuallar application its a new house i am just finishing up and the mudder never finished to the floor and the homeowner wants closets in now even tho theres no floor installed yet either. Iam just trying to work with what i was left with
Motorboatin' son of a ...
Either trim out the opening like a door with a jamb and casing, or add a wood bumper that runs down to the floor allowing the base molding to terminate into it.
Maxi-Pier Tech
Trade: foundation specialist
Re: Drywalled Closet Door Openings |
Trade: general contractor
We always trim around the perimeter of the door with cove mold or something similiar to cover the track and gap on the sides,if you did that you could run it to the floor and butt the base into it.
Trade: Handyman/Pressure Washing/Painting
I use a 1/2 in square molding (don't know what it is called) but it covers the track and side gaps.
David Emerald Coast Deluxe Services LLC www.deluxehandyman.webs.com |
Trade: carpentry
thanks or all the ideas i ended up just using flat stock on the flat and put trim all the way around. I would love to hear more ideas i really wanted to do something more creative than the same old same old.
#12 | |
Super B
Re: Drywalled Closet Door OpeningsQuote:
Put on your tin foil hat, pull up your pampers, get it done and post a picture. It's only a bumper jamb for sake.
Trade: Framing
I like this look, I also use that door stop trim to hide the gaps. I have also seen the side trim cut lower so the header trim covers the track for bi-fold doors
Trade: trim carpentry, light remodeling, handyman repairs
Not sure if I got what your question was. If you're looking to hide the gap between the door and the drywall, an easy cheap fix is to put 1x2 around the entire opening flush to outside wall of room, and then case this 1x2 with a quarter inch reveal as usual. The bifold door will then be recessed a bit and this tends to look nice from the interior of the room.
Trade: Railing
For a bi fold type door, just set the door about 1/8 to 3/16 behind the corner bead. Then picture frame the door with casing lapped over the door 1/4".
It looks clean, & if the casing is glued to wall, it holds up pretty well. For bi pass doors, I prefer the doors coped over the base, vs butting the base to the door. That way, there are no alignment problems, or small pieces of base comming off later. Joe |
| So I have a 3 YO house and someone else drywalled it... | Dougmt | Drywall | 19 | 05-02-2009 10:43 PM |
| Closet door idea | jcalvin | Windows, Siding and Doors | 3 | 03-27-2009 11:32 PM |
| hottub access panel location in closet | 72chevy4x4 | Plumbing | 4 | 03-09-2009 11:15 PM |
| Need Help w/ a Bathroom, closet, and laundry layout in addition | TurnkeyConst | Remodeling | 8 | 12-16-2008 12:50 AM |
| Damp cedar closet | AbeBarker | General Discussion | 4 | 01-20-2008 02:26 PM |
