Deep Plunge With A Router
More of an equipment question.
Decorative corbel will cover a structural support. the support has a third leg/brace. Its narrow (~1/8) but will end up being deep inside the corbel (~6" from the right angle of the support) Is there a router bit (call it the "Narwhal") for this -- or is a table saw the only solution? B |
Re: Deep Plunge With A Router
even if there is a 6" router bit, I wouldn't want to be the person running it. how big is the corbel? you say it's gotta cut in 6" from the right angle, will your table saw get that deep?
Sounds like something one would
laminate. Rabbet out 1/16" ± from each of two pieces, then glue them together. Either that or a long narrow mortising chisel.....
You could rent one of these, - - but it looks like it won't even go that deep
http://www.toolbarn.com/product/port...FQquGgodnCNSYg |
Restoration Crazy
When I was about 19 years old I worked for a post and beam outfit in the shop. They used a hole cutter and chisels for those types of mortises.
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
#6 | |
Re: Deep Plunge With A RouterQuote:
Re: Deep Plunge With A Router |
#8 | |
I meant about laminating it? Maybe you could describe it better.
Restoration Crazy
She was one of the good things
in life.
| j-channel with 3" deep pocket. | thesidingpro | Windows, Siding and Doors | 20 | 07-10-2011 09:23 PM |
| This will make a deep pool of your backyard | woodmagman | General Discussion | 2 | 11-09-2008 10:56 PM |
| 33,000 rpm router bits | samthedog | Tools & Equipment | 16 | 11-08-2008 07:19 AM |
| Deep fill under garage slab | lazerguy | Masonry | 9 | 09-06-2008 02:23 PM |
| Craftsman Router | DWC | Tools & Equipment | 3 | 05-10-2008 11:01 AM |
