installing a lot of baseboard these days, largely due to the popularity of the new "snap together" hardwood (composite) flooring. this is good for me!!! lotsa work.
problem that I run into fairly often, is that the floor is wavy, or humped at at least one place on the runs. If its high in the middle, not problem, I "balance" the baseboard (so both ends are the same height above the floor) and then scribe with a pencil/scriber from the end to the other end. I then cut it almost to the line, then finish up with a sanding block.
what really causes me grief and time is when the two ends touch the floor, and the middle has a gap!!!! grrrrrr
so what I was trained to do was put a sacraficial piece in, scribe it- cut- then cut that piece off (up about 1/2") so now I've got a chunk of baseboard that's 1/2" high on each end, flat on top, and convex in the middle (to match the floor) next I take another piece of baseboard, also cut 1/2" off of that.
Now take my custom piece, and glue/pin it onto the second piece, then install in the room.
Way too much work!!!! if its 1/16th or so I would just ignore it, or caulk, but when the gap approaches 3/8" (or more) I have to do something.
what do you all do in situations like this? Sometimes if its MDF baseboard I can force it down a little bit, but with finger joint? it won't move hardly at all.
what I have done occasionally is trim both ends, but then the matching piece of baseboard is now too high, so I cut that on a taper - makes for an interesting cope! LOL there's gotta be a better way to do this!
thx
Laurie.
www.lauriescustomfinishing.ca
