Cutting Out Electrical Boxes
Old 11-15-2006, 08:41 PM   #1
gman's Avatar
Trade: framer
I am installing 1x8 3/4" Pine T&G on walls and ceiling , wanting to know the best way to cutout electrical boxes. I thought about using Zip drill bit/
Does anybody have a better idea or tricks
Thanks
gman is offline
Old 11-15-2006, 09:29 PM   #2
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
Re: Cutting Out Electrical Boxes
I've always just used a jig saw/sabre saw. I think that the zip bit would be slow.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 11-16-2006, 04:40 PM   #3
miterclamp.com
clampman's Avatar
Trade: interior trim/cabinets
For switchboxes and the like on walls and ceilings, I'd use a jig saw like Big Dave.
But for outlet boxes in baseboard, I would have the electrician run his wires long, and do all the cutouts with a router and template.
It is much, much faster and better for everybody.
Regards,
Jimc
clampman is offline
Old 11-16-2006, 07:30 PM   #4
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
I just ran some bead board in a house, and had to cut out the boxes. It was MDF, and my Roto Zip with a tracing/plunge blade worked like a charm. It got dull fast, and I dont think it would work very good on real woods, but it might.
Real nice guys
King of Crown is offline
Old 11-16-2006, 07:36 PM   #5
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Yeah, all the above or get fancy and make them works of art using a jig and a plunge router, or do em quick and dirty with a skill saw, plunging the blade and knocking out the corners with a chisel.
Mike Finley is offline
Old 11-16-2006, 10:13 PM   #6
troubleseeker's Avatar
The zip bits are too slow and don't last. Use a jig saw with a quality blade. If you have never used them, treat yourself to some Bosch blades, which are now available with the universal shanks. They will renew your faith in using a jigsaw.
troubleseeker is offline
Old 11-18-2006, 08:30 PM   #7
El Dorado Wood's Avatar
Trade: Cabinetry, carpentry.
I think I might be thinking about a different situation than ya'll... but when I need to cut a cabinet back, paneling or trim around an electrical outlet, the situation usually entails unscrewing the outlet from the box... pulling it through the panel, and screwing it back onto the panel.
Trick I use is two overlapping cuts with a 2" hole saw. Super fast... done in about 8 seconds. The plug pulls through easy and it leaves plenty of meat to screw the 'tabs' back onto.
El Dorado Wood is offline
Old 11-18-2006, 09:29 PM   #8
mdshunk's Avatar
I'm sure that trick is fast and easy, but it creates at least 3 code violations. 110.3(B), 314.20, and 314.25(B)
mdshunk is offline
Old 11-18-2006, 10:15 PM   #9
Heavy Weight Champ
MD, I had a discussion with an Electrician about this problem once. He told me that he wouldnt screw the outlet to the bead board, but instead that the holes for the screws needed to be exposed. Is that "code" or just what he wanted?
Real nice guys
Old 11-18-2006, 10:15 PM   #10
Hmmm...
That's the way I was taught... and the way everybody I've ever seen do it... assuming working with existing electrical.
Didn't learn anything was wrong with it prepping for my C-6 exam... I'll hafta look into that.
Question though. If you're paneling over existing electrical... do you cut out for the plate and inset it then? Or do you move the box out and cut around it? Or... use an extension?
Thanks for the tip... I'll definitely look into that.
Old 11-18-2006, 10:18 PM   #11
Wondering that too.
Using the hole saw like I do exposes the holes/screws to attach the outlet like it's "supposed" to be. Just don't usually use them again 'cause they're either too short, or missing after pulling the fixture. Plus... it's easier to just throw some hinge screws into the 'tabs'.
Old 11-18-2006, 10:20 PM   #12
Heavy Weight Champ
Yeah, if thats against code, why do they make those tabs anyway?
Real nice guys
Old 11-18-2006, 11:15 PM   #13
Teetorbilt's Avatar
Use the RotoZip blue. I never have used the ones for drywall. The blues will get you about 40" in 1/4-3/8" fiberglass and last forever in drywall.
Albert Einstein
Teetorbilt is offline
Old 11-19-2006, 01:32 AM   #14
Remodeler Extraordinare
A.W.Davis's Avatar
I use a rotozip with wood cutting bits.....thats all I use for cutting openings in the back of cabinets, it takes 15 seconds for me to cut an opening in 3/4" particle board for an adjustable electrical box.
Jigsaws take too long IMO........its all personal preferance though.
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 11-19-2006, 05:46 PM   #15
Steve Unkie's Avatar
Trade: REMODELING CONTRACTOR
I use my jigsaw. Only use my rotozip on drywall, I break way too many bits on anything else.
I used to just pull the outlet through my 1/4'' cabinet back and re-install, never got called on it and did'nt think there was a problem. Now I do know. I use extension boxes now. I believe code allows for a 1/4'' of noncombustable material between box and plate, no allowances for combustable materials.
So, am I correct or just blowin smoke?
Steve Unkie.
Steve Unkie is offline
Old 11-19-2006, 06:55 PM   #16
Teetorbilt's Avatar
Rotary saws definitely have a learning curve and (after 8 yrs.) I'm still learning. One of the best things is speed control, 30K RPM is just too fast for many applications. The bits just load, overheat and snap. You can also get a 1/4" collet but I wouldn't recommend going over a 1/4" bit, the machine is just too light.
Albert Einstein
Old 11-19-2006, 07:38 PM   #17
OsNap
Guest
OsNap's Avatar
Posts: n/a
Sawzall works good.
Old 11-19-2006, 07:42 PM   #18
Teetorbilt's Avatar
Jeez, I want to see this! Why am I thinking those oversized cover plates?
Albert Einstein
Old 11-19-2006, 07:58 PM   #19
mdshunk's Avatar
Originally Posted by OsNap View Post
Sawzall works good.
Yeah, sure. My Sawzall works good too, but not for this purpose. That's a little bit like suggesting that we all use a chainsaw to carve this Thanksgiving's turkey.
mdshunk is offline
Old 11-19-2006, 08:47 PM   #20
wackman's Avatar
Trade: Builder, Additions, large remodels...Lately also small remodels.......
Speaking of sawzalls, I had a new guy the other day grab a super sawzall to trim some subfloor hanging out in the way of our new deck ledger. The kid stuffed the entire 10" blade inside the wall and in about 5 seconds (of course right when I wasn't watching) he cut through a water supply, a 2" drain and the bath electrical.
Around here sawzall is a temporarily bad word.
He's the broom boy/gopher for a little while.
Wack
wackman is offline
Electrical License in PA ABLE1 Low Voltage 29 10-25-2010 12:20 PM
What the worst electrical safety issue you have seen? SuperiorBuilt Electrical 63 01-02-2010 12:28 AM
Cover electrical boxes when spraying? icfbunt Painting & Finish Work 14 12-16-2006 02:59 PM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 11:58 PM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
