| View Poll Results: Cut crown flat or not | |||
| Flat |
6 | 17.65% |
| Upside down and angled to the fence |
28 | 82.35% |
| Voters: 34. You may not vote on this poll | |||
Trade: Handyman
Cutting Crown
Do you cut your crown upside down or flat on the saw.
Give me your reason in using your techniche Thanks much |
Trade: interior remodeling
Re: Cutting Crown
Faster
Trade: Guy who plays with wood
Re: Cutting Crown
Depends on the size of the crown. Most of the time upside down.
I did 2 house in Florida with 10" crown, I made sleds for my table saw to cut it. That was fun. |
Re: Cutting Crown
I cut mine upsidedown, for me its a lot quicker and less saw adjusting.
Dave |
Illusion of Perfection
Re: Cutting Crown
Flat - it is the way I was taught - practically know what the bevel and miter should read to adjust for out of square corners (but I used to have a laminate cheat sheet).
General Contractor
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Re: Cutting Crown
Both faster and easier.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Bill Everett - St. Petersburg, FL |
The Remodeler
Trade: Home Remodeler
Re: Cutting Crown
Usually upside down and backwards... I dont do a lot of crown over 5"... It's fast, easy, and also easy to adjust for out of square corners.
Ruane Woodworks,LLC
Trade: Finish and Custom Trim
Re: Cutting Crown
Cook, I would love to see that cheat sheet.
Upside down and backwards just like Gary taught me. ( 18 years too late) |
Re: Cutting Crown
flat!
KemoSabe
Re: Cutting Crown
Been cutting upside down and backwards since 10 years before I ever saw a compound miter saw. Flat cut it only if its to big to bed it against the fence.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
Re: Cutting Crown
Whenever possible, upside down. It's easier.
Here's one cheat sheet for laying flat. http://www.dewalt.com/us/articles/ar...odworking&ID=2 I've also seen calculators online that you just enter the spring angle and corner angle and it gives you the settings. A Bosch miter finder will also tell you the settings. |
I like Green things
Re: Cutting Crown
Nested, with this: (it's sweet little angle gauge makes any corner a snap)
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
Ruane Woodworks,LLC
Re: Cutting Crown
show off!
I like Green things
Re: Cutting CrownYou are right, I should keep it a secret since it has cut my crown install time in half!!
Re: Cutting Crown
Upside down.
Faster, less thinking. I cut my first crown before there was any such thing as an electric miter box.
Trade: Framing
Re: Cutting Crown
Flat... I don't see how this isn't faster and easier once you know your angles. First time i ever cut crown I did it upside-down and angled to the fence, I might have been doing it incorrectly but i found it hard to get my angles perfect.
LRG WoodCrafting
Re: Cutting Crown
Nested upside down. It is much faster. The only reason to do it flat is if your crown is to big to nest.
| Humps in cieling for crown and, and... | kevbo | Finish Carpentry | 16 | 05-03-2009 10:01 AM |
| cutting crown flat question | trimman2 | Finish Carpentry | 3 | 04-06-2009 07:10 PM |
| Ideas for transitions from one type of crown to another | john5mt | Finish Carpentry | 15 | 03-23-2009 11:58 PM |
| Crown questions... is there a consensus? | El Dorado Wood | Finish Carpentry | 14 | 01-04-2007 08:50 PM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
