Custom Range Hood Help
Old 03-11-2010, 07:43 AM   #1
AndersonsWworks's Avatar
Trade: Custom Cabinetry
I am getting ready to reface/rebuild a kitchen in natural cherry with shaker doors. The existing kitchen has a bank of cabinets hanging from the ceiling enclosing a range hood. This bank of cabinets and range counter separate the kitchen from the dining area. The HO wants to take out the cabinets and open up the area to have more vision into the dining area. I have not found a free standing range hood that will go with the rest of the kitchen or not be very expensive. The stove counter cannot be extended back any farther to incorporate a pop up vent. I have come up with an idea to enclose a standard range hood in a wood enclosure and anchor it to the ceiling. Has anyone seen this done? Any suggestions on how to better my idea? The HO is undecided as of yet to put short cabinets on either side of the range hood "tube".
Rocky
AndersonsWoodworks.com
AndersonsWworks is offline
Old 03-11-2010, 09:32 AM   #2
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Re: Custom Range Hood Help
If you end up building one, I would not use the under cabinet style hood. I would use a hood liner. Venta-hood makes a very good one as well as stand alone island hoods.
http://www.ventahood.com/specifications.jsp.
Gus Dering is offline
Old 03-11-2010, 10:31 AM   #3
genecarp's Avatar
There are many beautiful free hanging hoods on the market. If the customer does not want to pay, maybe he needs to rethink the design. I would rather have it correct, within my budget, than some cobbled together detail that will cheapen the whole project, GMOD
genecarp is offline
Old 03-11-2010, 10:44 AM   #4
mattsk8's Avatar
Trade: Building and remodeling
I made one once that an ho bought for his wall and I later found out it was an island hood so I had to incorporate this hood in his kitchen. It was a lot of work and looked pretty dumb IMOP. I tried to tell him to just get one designed for his kitchen but he didn't want to spend the $$$. He ended up paying me as much to make this thing work as he could have just bought one for and this is the problem w/ doing them this way.
Don't know what your time is worth but unless they have to have a perfect match w/ the detail, color and everything else it's cheaper to buy one. You can get nice ones for around 1500$ if you shop around.
If you must build it, you could build a box out of birch, then case it w/ the cherry surround. Just make sure the birch box is solid as a rock, has room for the vent, and that it will hold the weight of the range hood. Again, depends on what you're time's worth. As the builder I don't think it would be cheaper for the ho to have one custom made. If it was, we would all be building range hoods and selling them on ebay!!
mattsk8 is offline
Old 03-12-2010, 03:07 PM   #5
wannaBelkhuntin's Avatar
Trade: Trim Carpenter/Electrician/Tile Setter
I would build it as your pic shows [Minus the range hood fan] out of 3/4 Birch and then skin the entire assembly with 1/4" Cherry plywood. Then I would use 1/4" X 2 Cherry to trim all the panels to make them match your doors. As others have said they make an exhaust fan that you can mount inside. Also remember all you need room for up the chase is a 6" vent with a normal fan.
wannaBelkhuntin is offline
Old 08-12-2010, 08:41 PM   #6
DaveDettori's Avatar
Trade: Exterior Remodeling
i think you can just go with a regular island range hoods, there are lots of stores selling them on the net.
DaveDettori is offline
Old 08-12-2010, 08:57 PM   #7
Full Service Renovations
MAD Renovations's Avatar
Originally Posted by DaveDettori View Post
i think you can just go with a regular island range hood, there are lots of stores selling them on the net.
He probably has already finished.... This thread is almost 6 months old!!
MAD Renovations is offline
Old 08-18-2010, 05:38 PM   #8
Jordy3738's Avatar
Trade: Cabinetry
This method that you have designed would sure be less expensive than purchasing a pull-out hood. Those things are outrageously priced.
I think the idea is unique to the cabinet industry. I personally might try something like this in my own home, but not for a customer.
Jordy3738 is offline
Old 08-18-2010, 09:51 PM   #9
basswood's Avatar
Trade: trim carpenter
Here is one I built that could be adapted to meet the needs of the OP.
basswood is offline
range hood 60" above cooktop? Cache HVAC 17 08-16-2010 03:33 PM
What vent hood for custom wood hood vent?? jcs1984 Kitchens & Baths 6 12-15-2009 07:52 PM
Condensation dripping from range hood fan Big Rig Construction 5 02-24-2009 09:02 PM
How do you keep cold air out of a range hood? Mike(VA) HVAC 7 01-25-2009 05:16 PM
Venting large kitchen range hood ChuckEA HVAC 5 01-12-2006 11:53 PM
