Crown Vaulted Ceilings?
Old 12-16-2007, 01:17 PM   #1
One man show.
kevbo's Avatar
Trade: Finish Carpenter
What miter devise do you use to calculate miters in vaulted ceilings? I know there are alot gizmos out there, but which one is the best for vaulted ceilings?
kevbo is online now
Old 12-16-2007, 03:34 PM   #2
wink's Avatar
Trade: carpentry
Re: Crown Vaulted Ceilings?
if you do a search on this site, TomR has some pretty good methods on crown, the only thing is if i remember correctly he puts his coping saw blade in backwards
wink is offline
Old 12-16-2007, 03:48 PM   #3
[QUOTE=wink;337990.... TomR has some pretty good methods on crown, the only thing is if i remember correctly he puts his coping saw blade in backwards[/QUOTE]
neolitic is offline
Old 12-16-2007, 04:40 PM   #4
Moderator
Double-A's Avatar
Kev do an advanced search on Tom R (member name) and "transition". (Found this one)
You'll have to have a transition piece to go from level areas of ceiling to the 'vaulting' areas.
Gary Katz also has a nice article on this available at http://www.garymkatz.com/TrimTechniq...ansitions.html
Good luck.
New York Times, July 20, 2006
Double-A is offline
Old 12-16-2007, 05:17 PM   #5
Good luck.
Nice link, thanks.
There is an old fashioned, no math way to figure the miter for odd angles.
Set the angle with the T-bevel.
Align the "handle" with the edge of a piece of paper.
Mark along the blade.
Fold the mark to the "handle edge".
You have divided the original angle in half, giving the miter angle.
If you're careful and accurate with the fold, it works every time....
even when the brain is too tired for real math.
neolitic is offline
Old 12-16-2007, 05:27 PM   #6
Tom R's Avatar
Wink, wink . . .
http://www.tr-built.com
Tom R is offline
Old 12-16-2007, 06:35 PM   #7
One man show.
kevbo's Avatar
Guh...so you do or you dont have to do the pie shaped transition piece for the change of slope and plane every time??
kevbo is online now
Old 12-16-2007, 06:40 PM   #8
Tom R's Avatar
Yes, to do it correctly, you do.
The only other options I can think of, - - are either 'corner blocks', - - or trying to mate different-sized crowns together (narrower crown on rake wall meets wider crown at eave wall).
The only other way is if you have a very low slope, - - and you make your crowns meet by slightly 'tweaking' (cheating) their sitting-angles.
Tom R is offline
Old 12-16-2007, 07:01 PM   #9
One man show.
kevbo's Avatar
Allright, thanx guys.
kevbo is online now
Old 12-18-2007, 12:53 PM   #10
Moderator
Double-A's Avatar
Give it a try, Kev, takes more time to tell you how to do it than it actually takes to do it.
Double-A is offline
How to install crown on vaulted ceiling sayoungws Finish Carpentry 3 11-24-2007 11:58 PM
Crown on a vaulted ceiling highlife77 Finish Carpentry 5 08-20-2007 11:40 PM
9 foot ceilings or 8 foot ceilings with treys? williefb General Discussion 1 02-11-2007 01:29 PM
Question about prices for cathedral and vaulted ceilings FleshnerDrywall Drywall 5 01-07-2007 03:31 PM
Crown questions... is there a consensus? El Dorado Wood Finish Carpentry 14 01-04-2007 08:50 PM
