Build it better
Trade: General Contractor/Carpentry
Crown With Steel Studs?
just got a remodel job for several Dr's offices. I have never hung crown or for that matter installed base with steel studs. Does anybody have some suggestion for me? thanks...rick
Trade: Contractor
Re: Crown With Steel Studs?
1. Use fine thread trim screws and/or
2. put up some wood blocking before drywall and/or 3. angle your finish nails to make an "x" or "v" pattern. Fine thread screws is the best bet after you have it tacked, but gun trim nails will hold in metal studs. |
LRG WoodCrafting
Put up blocking using screws and adhesive. Then you just nail into that. Make sure you get paid for the extra work.
Lots of folks like to rip a 2X
to the spring angle, screw that to the studs, then nail the crown to the rip.
Trade: Carpentry & Remodeling
There is a nail gun i uesd before that shoots into steel stud. It has barbed nails that grab the steel. I have never seen one since i left that GC but i would do what Leo said.
Do what you would do, as if i won't Do anything after you Did It! |
Pompass Ass
Re: Crown With Steel Studs? |
Just noticed, "tandem posts" with
Leo! I'm honored.
Trade: trim carpenter
Good advice here already... just one thing to add, hold the backing back from the corners, so you can run a piece of crown straight into the corner and cope the next piece into it.
If you run backing into the corners, you have to cut it back out to cope, or miter (not the best idea). I also rip the backing just a skosh smaller than you think it needs to be, so you can adjust the crown...I allow an extra 1/8" of space between the back of the crown and the backing. |
#9 | |
Pompass Ass
Re: Crown With Steel Studs?Quote:
Good lookin out Bass!!
BIG D
Trade: Carpenter/Builder/Contractor
beat me to the punch bass! thats the best way to do it. no "fishing for joists". when i first started, i made the mistake of running it all the way to the corners..never did that again!
remember what you did right, then do it again! |
#12 | |
Sometimes it's hard to remember those important details until it's actually time to start. Then, with luck, those"Oops,been there before," moments come back to mind. I have usually put the rips up in 4'-5' pieces, not long contiuous rips. For the base, (just saw that part) trim screws or 15ga have worked for me, but you want to hit studs. Track can spoil your day.
#13 | |
Trade: Remodeling contractor
The strips look like they are in 2 pieces, yes? Any reason? Just curious. Thanks
Back in Maine Dubbin' Around Doin' good stuff ...... |
#16 | |
#17 | |
#18 |
This was backing for 6-1/2" crown and the small triangular piece that I ripped off of the 2x4 was waste... rather than toss it, I stacked it on the 2x backer, for better "backage."
#19 | |
| Condo's. hotels. When are steel stud's req'd? | puke | Commercial Construction | 9 | 03-15-2009 04:09 PM |
| Hanging vinyl siding on steel studs. | thesidingpro | Windows, Siding and Doors | 16 | 12-24-2008 06:38 PM |
| Hardiplank on steel studs | jetfxr | Windows, Siding and Doors | 9 | 11-07-2008 05:20 PM |
| ??? Whats the best way to spread the news about your company? | jmgrahamjr | Marketing & Sales | 21 | 06-24-2008 04:46 AM |
| Crown and steel studs | maddface | Finish Carpentry | 12 | 12-08-2007 02:14 PM |
